GD05
Rev 1.2, 05/2015
The UneoTM pressure sensor series is a Wall Street Journal Technology Award and Edison Award-winning
ultrathin flexible force sensing sensor suitable for a wide range of human-machine interface measurement
from a gentle finger touch to full-body weighing scales. The patented sensor technology employs the latest
advances in piezoresistive polymer composite processing and printing-based micromachining technology to
enable simple and high-quality linear output in the form of variable conductance (inverse of resistance) that
is proportional to the input force.
Features
> Linearity Exceeding 99% over 0 to 10N
> Capable of up to 10 Million Actuations
> Wide Temperature Range -40°C ~ 65°C
> Compatible with Simple Voltage-Divider Readout
> Environmentally-Friendly Fabrication
ORDERING INFORMATION
Device Name
Force Range
Sensor Type
Connector Type
Uneo GD05
0 – 10N
Resistive
Crimpflex
Package
Uneo GD05
© Uneo Inc., 2015. All rights reserved.
1
GD05 a
Operating Characteristics
Table 1. Operating Characteristics (TA = 25°C unless otherwise noted, F is positive)
Characteristic
Symbol
Min
Max
Unit
FOP
N
Repeatability(3)
±2
Hysteresis(4)
±2
6
%/log(s)
tR
0.1
ms
Y/T
0.35
%/°C
Force Range(1)
Linearity
Drift
Typ
(2)
0.99
(5)
Response Time(6)
Temperature Sensitivity
(7)
1.
The equivalent pressure on sensor can be computed as the force on sensing area divided by the sensor area. Depending on the
2.
Linearity indicates how well force vs. sensor conductance is correlated linearly. It is computed by taking the coefficient of
application, the usable force range could be higher than 10N.
2
determination, or R , of measurements in sensor's operating force range.
3.
Repeatability accounts for how well the sensor can reproduce a reading when the same force is applied within the rated operating
4.
Hysteresis is the difference between sensor output values when force is added or removed continuously from the sensor. The
force range using precision actuation systems. Results could vary depending on the stability of mechanical setup.
value is defined by the maximum difference in sensor output values, at the same force, during the loading and unloading of force in
the rated operating force range.
5.
Drift is the gradual shift the sensor output while the sensor is subjected to a fixed force, and is defined as percentage of shift
relative to initial reading over time. Typically, the sensor conductance will increase gradually with time, so such factor should be
considered to derive accurate force measurement.
6.
Response time (tR) is defined as the time for the incremental change in the output to get from 10% to 90% of the final value when
subjected to a change in applied force.
7.
Temperature Sensitivity is measured by the percentage change in output conductance per change in operating temperature. The
rating is only applicable when sensor is operated within conditions described in Table 2.
Maximum Ratings
Table 2. Maximum Ratings
Rating
Symbol
Value
Unit
Storage Temperature
Tstg
-40 to +90
°C
Operating Temperature
TA
-40 to +65
°C
Operating beyond the specified limits could change the sensor output characteristic permanently.
2
GD05 a
Measurement Circuit
Two methods to measure UNEO sensor is shown below:
1. Using an operational amplifier (OP-AMP) in an inverting configuration to obtain a voltage output that varies
linearly with respect to force input. Use this circuit if high output linearity is desired.
2. Using a fixed resistor R1 in a voltage divider configuration for an output V2 that increases with respect to
added force. Use this circuit topology for budget or power-conscious applications.
Note:
1. R1 is 1Kohm to 100Kohm
2. V2 is 0 to +Vr
3
GD05 a
Nominal Dimension
DIM
Millimeters
A
5.00
B
8.6
C
15.3
D
0.2
E
2.54
4
GD05 a
How to Reach Us:
Uneo Inc. Website:
www.uneotech.com
Web Support:
uneo@uneotech.com
Uneo Inc.:
Address: 9F., No. 667, Bannan Rd.,
Zhonghe District, New Taipei City 235, Taiwan
Telephone:+886-2-22252018
Facsimile:+886-2-22252056
Information in this document is provided solely to enable system and software
implementers to use Uneo Incorporated products. There are no express or implied
copyright licenses granted hereunder to design or fabricate any integrated circuits or
integrated circuits based on the information in this document. Uneo Incorporated
reserves the right to make changes without further notice to any products herein. Uneo
Incorporated makes no warranty, representation or guarantee regarding the suitability
of its products for any particular purpose, nor does Uneo Incorporated assume any
liability arising out of the application or use of any product or circuit, and specifically
disclaims any and all liability, including without limitation consequential or incidental
damages. "Typical” parameters that may be provided in Uneo Incorporated data
sheets and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals”, must
be validated for each customer application by customer’s technical experts. Uneo
Incorporated does not convey any license under its patent rights nor the rights of
others. Uneo Incorporated products are not designed, intended, or authorized for use
as components in systems intended for surgical implant into the body, or other
applications intended to support or sustain life, or for any other application in which the
failure of the Uneo Incorporated product could create a situation where personal injury
or death may occur. Should Buyer purchase or use Uneo Incorporated products for
any such unintended or unauthorized application, Buyer shall indemnify and hold
Uneo Incorporated and its officers, employees, subsidiaries, affiliates, and distributors
harmless against all claims, costs, damages, and expenses, and reasonable attorney
fees arising out of, directly or indirectly, any claim of personal injury or death
associated with such unintended or unauthorized use, even if such claim alleges that
Uneo Incorporated was negligent regarding the design or manufacture of the part.
Uneo™ and the Uneo logo are trademarks of Uneo Incorporated. All other product or
service names are the property of their respective owners.
5
GD05 a
很抱歉,暂时无法提供与“GD05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+40.924821+5.32010
- 5+36.692625+4.76993
- 10+35.1215410+4.56569
- 25+33.2449925+4.32175
- 50+31.9589150+4.15456
- 100+30.78140100+4.00149
- 500+28.41247500+3.69353
- 1000+27.529941000+3.57881
