GBJ2010
GBJ2010
    BAOCHENG(宝乘)
    GBJ-6
    耐压:1000V 电流:20A
GBJ2010 数据手册
GBJ/KBJ20005 thru GBJKBJ2010 20. 0 A Single-Phase Silicon Bridge Rectifier Rectifier Reverse Voltage 50 to 1000V Features Ideal for printed circuit board mounting This series is UL listed under the Recognized Component Index The plastic material used carries Underwriters Laboratory flammability recognition 94V-0 Built-in printed circuit board stand-offs High case dielectric strength High temperature soldering guaranteed 260 /5 seconds at 5 lbs (2.3kg) tension Mechanical Data Case: Reliable low cost construction utilizing molded plastic technique Terminals: Plated leads solderable per MIL-STD-202, Method 208 Mounting Position: Any Dimensions in inches and (milimeters) Maximum Ratings & Thermal Characteristics Rating at 25 C ambient temperature unless otherwise specified, Resistive or Inductive load, 60 Hz. For Capacitive load derate current by 20%. CHARACTERISTICS SYMBOL GBJ/KBJ GBJ/KBJ GBJ/KBJ GBJ/KBJ GBJ/KBJ GBJ/KBJ GBJ/KBJ UNIT 20005 2001 2002 2004 2006 2008 2010 Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 30 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current (with heatsink Note 2) I(AV) @ TC=100℃ (without heatsink) 20.0 A 3.5 Peak Forward Surage Current 8.3ms Single Half Sine-Wave IFSM 240 A VF 1.1 V Super Imposed on Rated Load (JEDEC Method) Maximum Forward Voltage at 10.0A DC Maximum DC Reverse Current @ TJ=25℃ at Rated DC Blocking Voltage @ TJ=125℃ Typical Thermal Resistance (Note2) Operating Temperature Range Storage Temperature Range IR 10 uA 500 RθJC 1.5 ℃/W TJ -55 to +150 ℃ TSTG -55 to +150 ℃ NOTES: 1.Measured at 1.0MHz and applied reverse voltage of 4.0V DC. 2.Device mounted on 300mm*300mm*1.6mm cu plate heatsink. www.baocheng-ic.com -1- o Rating and Characteristic Curves ( TA=25 C Unless otherwise noted ) GBJ/KBJ20005 thru GBJ/KBJ2010 PEAK FORWARD SURGE CURRENT , AMPERES FIG.1-FORWARD CURRENT DERATING CURVE AVERAGE FORWARD CURRENT AMPERES 20 WITH HEATSINK 16 SINGLE PHASE HALF WAVE 60Hz RESISTIVE OR INDUCTIVE LOAD 12 8 WITHOUT HEATSINK 4 0 0 20 40 60 100 80 120 140 FIG.2-MAXMUN NON-REPETITIVE SURGE CURRENT 300 TJ=150℃ SINGLE -SINE- WAVE (JEDEC METHOD) 200 100 Single Half-Sine- Wave (JEDEC METHOD) 0 1 2 2 50 100 FIG.4-TYPICAL FORWARD CHARACTERISTICS FIG.3-TYPICAL JUNCTION CAPACITANCE INSTANTANEOUS FORWARD CURRENT, (A) 100 10 TJ=25℃,f=1MHZ 10 1.0 TJ = 25°C PUSE WIDH 300us 0.1 1.0 1.0 10.0 REVERSE VOLTAGE,(VOLTS) 0.01 100 0 1.0 1.4 0.2 0.4 0.6 0.8 1.2 1.6 1.8 INSTANTANEOUS FORWARD VOLTAGE, VOLTS FIG.5-TYPICAL REVERSE CHARACTERISTICS 1000 INSTANTANEOUS REVERSE CURRENT ,(uA) CAPACITANCE,(pF) 10 NUMBER OF CYCLES AT 60Hz CASE TEMPERATURE,℃ 100 5 TJ=125℃ 100 TJ=100℃ 10 TJ=50℃ 1.0 TJ=25℃ 0.1 0 20 40 60 80 100 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) www.baocheng-ic.com -2-
GBJ2010 价格&库存
很抱歉,暂时无法提供与“GBJ2010”相匹配的价格&库存,您可以联系我们找货
GBJ2010
  • 1+3.88854
  • 10+3.24216
  • 30+2.96514
  • 100+2.61630
  • 500+2.46240
  • 1000+2.37006
库存:705
