GBU806(95MIL)
GBU806(95MIL)
    BAOCHENG(宝乘)
    GBU
    GBU806(95MIL)
GBU806(95MIL) 数据手册
GBU8005 thru GBU810 8. 0 A Single-Phase Silicon Bridge Rectifier Rectifier Reverse Voltage 50 to 1000V Features Ideal for printed circuit board mounting This series is UL listed under the Recognized Component Index, file number E142814 The plastic material used carries Underwriters Laboratory flammability recognition 94V-0 Built-in printed circuit board stand-offs High case dielectric strength High temperature soldering guaranteed 260 /5 seconds at 5 lbs (2.3kg) tension Mechanical Data Case: Reliable low cost construction utilizing molded plastic technique Terminals: Plated leads solderable per MIL-STD-202, Method 208 Mounting Position: Any Dimensions in inches and (milimeters) Maximum Ratings & Thermal Characteristics Rating at 25 C ambient temperature unless otherwise specified, Resistive or Inductive load, 60 Hz. For Capacitive load derate current by 20%. GBU GBU GBU GBU GBU GBU Parameter Symbol 8005 801 802 804 806 808 VRRM 200 400 800 Maximum repetitive peak reverse voltage 50 100 600 Maximum RMS bridge input voltage Maximum DC blocking voltage Maximum average forward rectified output current at TC=100 C (with heatsink) VRMS VDC 35 50 70 140 280 100 200 400 GBU unit 810 1000 V 420 560 700 V 600 800 1000 V IF(AV) 8.0 A Peak forward surge current single sine-wave superimposed on rated load (JEDEC Method) IFSM 175 A I t 127 A sec TJ, TSTG -55 to + 150 Rating for fusing ( t
GBU806(95MIL) 价格&库存
很抱歉,暂时无法提供与“GBU806(95MIL)”相匹配的价格&库存,您可以联系我们找货
GBU806(95MIL)
    • 1+0.99290
    库存:30
