GS7119ST-3P3-R
GS7119ST-3P3-R
    GSTEK(登丰微)
    SOT23-5
    GS7119是一款CMOS线性稳压器,具有超高电源抑制比、低输出电压噪声、低压差、低静态电流和快速瞬态响应等特性。它可保证提供300mA的输出电流,支持预设1.2V、1.3V、1.5V、1.7V、1....
GS7119ST-3P3-R 数据手册
Low Noise 300mA LDO Regulator GS7119 Features General Description  Low Supply Current~55uA (Typ.) The GS7119 is a CMOS linear regulator. It is  Low Shutdown Current ~0.1uA (Typ.) featuring ultra-high power supply rejection ratio,  Output Current ~300mA low output voltage noise, low dropout voltage, low  High Power Supply Rejection Ratio quiescent current and fast transient response. It ~75dB@1KHz guarantees delivery of 300mA output current, and  1.7~5.5V Operation supports preset 1.2V, 1.3V, 1.5V, 1.7V, 1.8V,  ±1.5% Initial Voltage Accuracy 1.85V, 1.9V, 2.0V, 2.3V, 2.5V, 2.6V, 2.7V, 2.8V,  Low Temperature Drift Coefficient ~50ppm 2.85V, 2.9V, 3.0V, 3.1V, 3.3V output voltage  Line Regulation ~0.02%/V(Typ.) versions.  Low ESR Capacitor ~1.0uF ceramic capacitor Based on its low quiescent current consumption  WDFN4-1.2x1.6、TDFN6-1.8x2、SOT-23-5、 and its less than 1uA shutdown mode, the SOT-89-3、MSOT-23 and SOT-353 package GS7119 is ideal for battery- powered applications. Green Product (RoHS, Lead-Free, The high power supply rejection ratio of the Halogen-Free Compliant) GS7119 holds well for low input voltages typically  encountered in battery- operated systems. The Applications regulator is stable with small ceramic capacitive  Portable communication equipment loads (1µF typical).  Notebook Computer  Battery Powered Systems Typical Application VDD 1uF 4 VDD VOUT 1 EN VOUT GS7119 3 EN GND 2 1uF Figure 1 Typical Application of GS7119 This document is GStek's confidential information. Anyone having confidential obligation to GStek shall keep this document confidential. Any unauthorized disclosure or use beyond authorized purpose will be considered as violation of confidentiality and criminal and civil liability will be asserted. Green Solution Technology Co.,LTD. Rev.:1.47 1 Nov-14 Low Noise 300mA LDO Regulator GS7119 Function Block Diagram VDD VOUT - EN EN Control EN + 0.3uA Vref Current Limit GND Figure 2a with auto discharge function (default) VDD VOUT - EN EN Control EN + 0.3uA Vref Current Limit GND Figure 2b without auto discharge function (special order) Figure 2 Function Block Diagram Green Solution Technology Co.,LTD. Rev.:1.47 2 Nov-14 Low Noise 300mA LDO Regulator GS7119 Pin Configuration VOUT 1 4 VDD VDD EN 6 5 4 2 3 VDD 7 NC 5 GND GND 2 3 EN 1 VOUT Figure 3a WDFN4-1.2x1.6 Package VOUT 5 VOUT GND Figure 3b TDFN6-1.8x2 package NC 4 VDD 3 1 2 3 1 2 3 1 2 VDD GND EN GND VDD VOUT GND VOUT Figure 3c SOT-23-5 Figure 3d SOT-89-3 Package /SOT-353 Package Figure 3e MSOT-23 Package Pin Descriptions No SOT-23-5/ WDFN4-1.2x1.6 TDFN6-1.8x2 SOT-353 SOT-89-3 MSOT-23 Name I/O type Description 1 1, 2 5 3 2 VOUT O Output pin 2, 5 3 2 1 1 GND O Ground pin 3 4 3 EN I Enable Pin 4 5,6 1 VDD I Input Pin 7 4 Green Solution Technology Co.,LTD. Rev.:1.47 2 3 NC 3 Nov-14 Low Noise 300mA LDO Regulator GS7119 Ordering Information GS7119PP-XXX- R 1. Package No 3. Shipping 2. Output Voltage Item Contents UD: WDFN4-1.2x1.6 TD: TDFN6-1.8x2 1 Package ST: SOT-23-5 S9: SOT-89-3 SR: MSOT-23 C5: SOT-353(SC-75) 1P2: 1.2V, 1P3: 1.3V, 1P5: 1.5V, 1P7:1.7V, 1P8: 1.8V, 185: 1.85V, 1P9: 1.9V, 2 Output Voltage 2P0: 2.0V, 2P3: 2.3V, 2P5: 2.5V, 2P6: 2.6V, 2P7: 2.7V, 2P8: 2.8V, 285: 2.85V, 2P9: 2.9V, 3P0: 3.0V, 3P1: 3.1V, 3P3: 3.3V 3 Shipping R: Tape & Reel Example: GS7119 2.5V SOT-23-5 Tape & Reel ordering information is “GS7119ST-2P5-R” Green Solution Technology Co.,LTD. Rev.:1.47 4 Nov-14 Low Noise 300mA LDO Regulator GS7119 Absolute Maximum Rating (Note 1) Parameter Symbol Limits Units VIN to GND VIN -0.3 < VIN< 6 V VEN to GND VEN -0.3 < VEN< 6 V Output Voltage VOUT -0.3 < VOUT
GS7119ST-3P3-R 价格&库存
很抱歉,暂时无法提供与“GS7119ST-3P3-R”相匹配的价格&库存,您可以联系我们找货
