GS7108ST-3P3-R
GS7108ST-3P3-R
    GSTEK(登丰微)
    SOT23-5
    3.3V 150MA 6.5V
GS7108ST-3P3-R 数据手册
Low Noise 150mA LDO Regulator GS7108 General Description Features  Low Supply Current ~ 36uA (Typ.) The GS7108 is a CMOS linear regulator. It is  Low Shutdown Current ~0.1uA (Typ.) featuring ultra-high power supply rejection ratio,  Output Current ~150mA low output voltage noise, low dropout voltage, low  High Power Supply Rejection Ratio quiescent current and fast transient response. It ~78db@1KHz guarantees delivery of 150mA output current, and  1.7~6.5V Operation supports preset 1.2V, 1.3V, 1.5V, 1.8V, 1.85V,  ±1.0% Initial Voltage Accuracy 1.9V, 2.0V, 2.3V, 2.5V, 2.6V, 2.7V, 2.8V, 2.85V,  Low Temperature Drift Coefficient ~50ppm 2.9V, 3.0V, 3.1V, 3.3V, 3.8V, 4.0V, 4.2V, 4.5V,  Line Regulation ~0.02%/V(Typ.) 4.75V, 4.8V, 5.0V output voltage versions.  Low ESR Capacitor ~0.47uF ceramic  capacitor Based on its low quiescent current consumption uDFN4-1x1、xDFN4-1x1、SOT-23-5、SC-82、 and its less than 1uA shutdown mode, the MSOT-23 package GS7108 is ideal for battery- powered applications. The high power supply rejection ratio of the  Green Product (RoHS, Lead-Free, GS7108 holds well for low input voltages typically Halogen-Free Compliant) encountered in battery- operated systems. The regulator is stable with small ceramic capacitive Applications  Portable communication equipment  Notebook Computer  Battery Powered Systems loads (0.47µF typical). Typical Application Figure.1 Typical Application of GS7108 This document is GStek's confidential information. Anyone having confidential obligation to GStek shall keep this document confidential. Any unauthorized disclosure or use beyond authorized purpose will be considered as violation of confidentiality and criminal and civil liability will be asserted. Green Solution Technology Co.,LTD. Rev.:1.62 1 Feb-13 Low Noise 150mA LDO Regulator GS7108 Function Block Diagram VDD EN VOUT EN Control 0.3uA EN + Vref Current Limit GND Figure 2a with auto discharge function (default) VDD EN VOUT EN Control 0.3uA EN + Vref Current Limit GND Figure 2b without auto discharge function (special order) Figure 2 Function Block Diagram Green Solution Technology Co.,LTD. Rev.:1.62 2 Feb-13 Low Noise 150mA LDO Regulator GS7108 Pin Configuration VDD VDD EN EN “Pin5 do not connect to NC other wires or land patterns VOUT GND GND VOUT Figure 3a uDFN4-1x1/xDFN4-1x1 Package 5 1 4 2 3 Figure 3b SOT-23-5 Package 4 3 1 2 3 1 Figure 3c SC-82 Package 2 Figure 3d MSOT-23 Package Pin Descriptions No uDFN4-1x1/xDFN4-1x1 SOT-23-5 SC-82 MSOT-23 Name I/O type Description 1 5 3 2 VOUT O Output pin 2 2 2 1 GND O Ground pin 3 3 1 EN I Enable Pin 4 1 4 VDD I Input Pin 5 4 Green Solution Technology Co.,LTD. Rev.:1.62 3 NC 3 Feb-13 Low Noise 150mA LDO Regulator GS7108 Ordering Information GS7108PP-XXX- R 1. Package 3. Shipping 2. Output Voltage No Item Contents UD: uDFN4-1x1 XD: xDFN4-1x1 1 Package ST: SOT-23-5 SC: SC-82 SR: MSOT-23 1P2: 1.2V, 1P3: 1.3V, 1P5: 1.5V, 1P8: 1.8V, 185: 1.85V, 1P9: 1.9V, 2P0: 2.0V, 2 Output Voltage 2P3: 2.3V, 2P5: 2.5V, 2P6: 2.6V, 2P7: 2.7V, 2P8: 2.8V, 285: 2.85V, 2P9: 2.9V, 3P0: 3.0V, 3P1: 3.1V, 3P3: 3.3V, 3P8: 3.8V, 4P0: 4.0V, 4P2: 4.2V, 4P5: 4.5V, 475: 4.75V, 4P8: 4.8V, 5P0: 5.0V 3 Shipping R: Tape & Reel Example: GS7108 SC-82 2.5V Tape & Reel ordering information is “GS7108SC-2P5-R” Absolute Maximum Rating (Note 1) Parameter Symbol Limits Units VIN to GND VIN -0.3 < VIN< 7 V VEN to GND VEN -0.3 < VEN< 7 V Output Voltage VOUT -0.3 < VOUT2.0V x0.99 x1.01 V VOUT≤2.0V -20 20 mV x1.015 V 30 mV VOUT>2.0V x0.985 VOUT≤2.0V -30 Feb-13 Low Noise 150mA LDO Regulator Dropout Voltage (Note 5) VDROP Line Regulation △VLNR Load Regulation △VLDR Ripple Rejection Rate PSRR GS7108 IOUT=150mA 1.2V≤VOUT
GS7108ST-3P3-R 价格&库存
很抱歉,暂时无法提供与“GS7108ST-3P3-R”相匹配的价格&库存,您可以联系我们找货
