GU-SH-124D
GU-SH-124D
    GOODSKY(国兴)
    插件,27.5x32.1mm
    24V
GU-SH-124D 数据手册
GU MAIN FEATURE 1. Single contact Form (SPST) series Relay offers switching capacity 30A in small size. 2. Dust cover, sealed & unclosed cover types are available. 3. UL Class F insulation available. 4. Halogen Free series available. 5. Comply with RoHS and REACH regulations. CONTACT RATING Load Type Rated Load (Resistive) Contact Capacity NO NC Rated Carrying Current Max. Allowable Voltage Max. Allowable Current Max. Allowable Power Force Contact Material Contact Form GU (DM) GU (DB) GU (D) GU (D1) 30A 120VAC 30A 240VAC 30A 30VDC TV-8 120VAC 1-1/2HP 240VAC 30A AC 240V 30A 7,200VA 900W Ag Alloy SPST 10A 240VAC 10A 30VDC 1/2HP 240VAC 10A AC 240V 10A 2,400VA 300W Ag Alloy SPST NC: 20A 240VAC 10A 30VDC NO: 30A 240VAC 20A 30VDC TV-8 120VAC 1-1/2HP 240VAC 1/2HP 240VAC 30A AC 240V 30A 7,200VA 600W Ag Alloy SPDT NC: 10A 240VAC 10A 30VDC NO: 20A 240VAC 20A 30VDC TV-8 120VAC 1-1/2HP 240VAC 1/2HP 240VAC 20A AC 240V 20A 4,800VA 600W Ag Alloy SPDT APPLICATION Domestic Appliances, Heating, Ventilating and Conditioning System, Car Control Switching Box, General Power Switching Applications. PERFORMANCE (AT INITIAL VALUE) Contact Resistance ..............100m Max.@1A,6VDC Operate Time........................15 mSec. Max. Release Time .......................10 mSec. Max. Dielectric Strength: Between Coil & Contact....... 1,500VAC at 50/60 Hz for one minute Between Contacts ................1,500VAC at 50/60 Hz for one minute Insulation Resistance ...........100 Mega Min. at 500VDC Max. On/Off Switching: Electrical ...............................6 Cycles per Minute Mechanical............................300 Cycles per Minute Temperature Range ........ -25 +55°C Humidity Range ............... 45 85% RH. Coil Temperature Rise .... 60°C Max. Vibration: Destruction ...................... 10 to 55 to 10 Hz,0.75 mm single amplitude (1.5mm double amplitude) Malfunction ...................... 10 to 55 to 10 Hz,0.75 mm single amplitude (1.5mm double amplitude) Shock: Destruction ...................... 1,000 m/S 2 Malfunction ...................... 50 m/S 2 Life Expectancy: 7 Mechanical ...................... 10 Operations at No Load condition 5 Electrical .......................... 10 Operations at Resistive Load Weight ............................. Flow Solder Type: 27.2g Open Type: 21.6g SAFETY STANDARD & FILE NUMBER UL & C-UL ....................... E141060 98 GU COIL SPECIFICATION (AT 20°C) Power Nominal Coil Resistance Consumption Current (mA) (Ω±10%) (W) Nominal Voltage (VDC) 5 6 9 12 15 18 24 36 48 110 GU-D 185 150 93 77 59 47 36 25.8 19.4 8.5 27 40 97 155 255 380 660 1,390 2,480 13,000 Abt. 0.93 Pull-In Voltage Drop-Out (VDC) Voltage (VDC) 80% Maximum 5% Minimum Maximum Allowable Voltage (VDC) GU Coil Sensitivity 150% (for short time carrying current) ORDERING INFORMATION GU - SS - 1 12 D M CF 1 -5 Terminal Type: Nil: 2 Common 5: 1 Common Load rated(For GU-D Series only): Nil: NO:30A/NC:20A. 1: NO:20A/NC:10A. Insulation System: Nil: Standard Class CF: Class F Nil: One Form C M: One Form A B: One Form B D: Standard DC 05: 5V, 06: 6V, 09: 9V, 12: 12V, 15: 15V, 18: 18V, 24: 24V, 36: 36V, 48: 48V, 110: 110V 1: One Pole Nil: RT 0 Unclosed SS: RT II Flux Proofed SH: RT III Wash Tight GU Contact Form: Coil Type: Coil Voltage: Number of Pole: Type of Sealing: Type: CLASSIFICATION Model Insulation System Contact Form Unclosed Relay Flux Proofed Type 1C GU-1 D(CF)(1) GU-SS/SH-1 D(CF)(1) GU Nil: Standard Class / CF: Class F 1A DM(CF) GU-1 GU-SS/SH-1 DM(CF) 1B DB(CF) GU-1 GU-SS/SH-1 DB(CF) V.01EZ www.goodsky.com.tw 99 GU DIMENSION ( ≤ 5mm ± 0.2mm, > 5mm ± 0.3mm, the tolerance of PCB thru hole: +0.1mm) 15.2 7.6 2.5 4.0 10.2 1.4 4.8 Ø0.7 1.2 0.8 15.2 15.2 7.6 32. 1 17.8 27.5 0.8 1.2 2.54 2.5 8.9 14 4- Ø2 4.8 1.2 1.2 8.9 17.8 20 3.8 GU-D : 2 Common terminals : 6 PIN .1 1.1 2-Ø 15.2 2.54 Bottom View P.C.B Layout Bottom View 15.2 7.6 2.5 4.0 1.2 10.2 1.4 4.8 0.8 1.2 15.2 7.6 32. 1 17.8 27.5 0.8 14 3- 4.8 Ø0.7 17.8 20 3.8 GU-D : 1 Common terminal : 5 PIN Ø2 .1 1.1 2.54 2-Ø 2.5 2.54 Bottom View P.C.B Layout Bottom View 4.0 8.9 10.2 1.4 4.8 Ø0.7 1.2 15.2 15.2 32. 1 17.8 27.5 0.8 1.2 2.54 10.1 8.9 14 15.2 3- Ø 2.1 4.8 1.2 1.2 17.8 20 3.8 GU-DM : 2 Common terminals : 5 PIN 1.1 2-Ø 15.2 2.54 Bottom View P.C.B Layout Bottom View 15.2 4.0 1.2 10.2 17.8 27.5 100 1.4 4.8 0.8 1.2 15.2 32. 1 2.54 10.1 14 2- Ø 4.8 Ø0.7 17.8 20 3.8 GU-DM : 1 Common terminal : 4 PIN 2.1 1.1 2-Ø 2.54 P.C.B Layout Bottom View Bottom View GU GU-D Unclosed: 2 Common terminals : 6 PIN 7.6 3.8 4- 1.2 10.2 17.8 1.4 8.9 1.2 Ø0.7 3.55 .1 15.2 15.2 0.8 1. 1 3.2 1.2 0.8 2� 1.2 ø2 17.8 14 16.8 5.9 8.9 GU 15.2 28.2 23.0 15.24 7.6 2.54 2.54 Bottom View P.C.B Layout Bottom View GU-D Unclosed: 1 Common terminal : 5 PIN 15.2 28.2 7.6 3- 3.2 10.2 17.8 1.4 .1 0.8 0.8 3.2 Ø0.7 3.55 15.2 15.2 1. 1.2 1 17.8 14 1.2 Bottom View � 8.9 1.2 ø2 2- 5.9 16.8 3.8 23.0 2.54 7.6 2.54 P.C.B Layout Bottom View GU-DM Unclosed: 2 Common terminals : 5 PIN 15.2 28.2 3- 1.4 .1 Ø0.7 3.55 15.2 15.2 1 3.2 1.2 1. 1.2 0.8 � 8.9 1.2 10.2 17.8 15.24 2- 5.9 1.2 ø2 17.8 14 16.8 8.9 3.8 23.0 2.54 Bottom View P.C.B Layout Bottom View 2.54 GU-DM Unclosed: 1 Common terminal : 4 PIN 15.2 28.2 1.2 3.2 10.2 17.8 3.55 Ø0.7 15.2 15.2 1 3.2 1.2 0.8 2.54 1. 1.2 � 1.4 2- 5.9 17.8 14 16.8 1 2. 8.9 ø 2- 3.8 23.0 P.C.B Layout Bottom View 2.54 Bottom View V.01EZ www.goodsky.com.tw 101
GU-SH-124D 价格&库存
很抱歉,暂时无法提供与“GU-SH-124D”相匹配的价格&库存,您可以联系我们找货
