GQ-SH-112LM1F
GQ-SH-112LM1F
    GOODSKY(国兴)
    DIP
    陶瓷谐振器 DIP
GQ-SH-112LM1F 数据手册
GQ MAIN FEATURE 1. Miniature size with low power consumption for rated loading to 12A. 2. Surge Strength up to 10,000V. 3. Operating temperature up to 105°C. 4. Halogen Free series available. 5. UL Class F insulation available. 6. Comply with RoHS and REACH regulations. CONTACT RATING Load Type Rated Load (Resistive) Contact Capacity Rated Carrying Current Max. Allowable Voltage Max. Allowable Current Max. Allowable Power Force Contact Material Contact Form GQ (LM) GQ (LM1) 5A 250VAC 5A 30VDC 5A AC 250V DC 30V 5A 1,250VA 150W Ag Alloy SPST 10A 250VAC 12A 125VAC 10A 30VDC 10A 277VAC TV-5 120VAC 10A AC 250V DC 30V 12A 2,500VA 300W Ag Alloy SPST APPLICATION Domestic Appliances, Office Machines, Audio Equipment, etc. PERFORMANCE (AT INITIAL VALUE) Contact Resistance ..............100m Max.@1A,6VDC Operate Time........................10 mSec. Max. Release Time .......................5 mSec. Max. Dielectric Strength: Between Coil & Contact....... 4,000VAC at 50/60 Hz for one minute Between Contacts ................1,000VAC at 50/60 Hz For one minute Surge Strength .....................10,000V (between coil & contact 1.2x50μSec.) Insulation Resistance ...........100 Mega Min. at 500VDC Max. On/Off Switching: Electrical ...............................6 Cycles per Minute Mechanical............................300 Cycles per Minute Temperature Range .............-40 +105°C Humidity Range ....................45 85% RH. Coil Temperature Rise .........40°C Max. 66 Vibration: Destruction ...................... 10 to 55 to 10 Hz,0.75 mm single amplitude (1.5mm double amplitude) Malfunction ...................... 10 to 55 to 10 Hz,0.75 mm single amplitude (1.5mm double amplitude) Shock: Destruction ...................... 1,000 m/S 2 2 Malfunction ...................... 100 m/S Life Expectancy: 7 Mechanical ....................... 10 Operations at no Load condition 5 Electrical .......................... 10 Operations at Rated Resistive Load 4 2.5x10 Operations at TV Rated Load Weight............................... About 9.0 g SAFETY STANDARD & FILE NUMBER LM: UL & C-UL ........................... E141060 TÜV ................................ R50121172 VDE ................................ 40025456 LM1: UL & C-UL ....................... E141060 TÜV ................................ R50121172 CQC.................................. 14002112636 GQ COIL SPECIFICATION (AT 20°C) Nominal Voltage (VDC) GQ 3 5 6 9 12 15 18 24 48 Power Nominal Coil Resistance Consumption Current (mA) (Ω±10%) (W) 67 40 33.3 22.5 16.7 13.3 11.1 8.3 4.2 45 125 180 400 720 1,125 1,620 2,880 11,520 Pull-In Voltage Drop-Out (VDC) Voltage (VDC) 80% Maximum Abt. 0.20 Maximum Allowable Voltage (VDC) 5% Minimum GQ Coil Sensitivity 110% ORDERING INFORMATION GQ - SS - 1 12 L M 1 F Contact Form: Nil: Standard Class F: Class F Nil: 5A 1: 10A M: One Form A Coil Sensitivity: L: High DC Coil Voltage: 03: 3V, 05: 5V, 06: 6V, 09: 9V, 12: 12V Insulation System: Rated Carrying Current: 15: 15V, 18: 18V, 24: 24V, 48: 48V Number of Pole: 1: One Pole SS: RT II Flux Proofed SH: RT III Wash Tight GQ Type of Sealing: Type: CLASSIFICATION Model Rated Carrying Current Flux Proofed Wash Tight GQ 5A GQ-SS-1 GQ-SH-1 10A LM1/F GQ-SS-1 LM1/F GQ-SH-1 LM LM 4.1 14.9 DIMENSION ( ≤ 5mm ± 0.2mm, > 5mm ± 0.3mm, the tolerance of PCB thru hole: +0.1mm) Bottom View P.C.B Layout Bottom View V.01EZ www.goodsky.com.tw 67
GQ-SH-112LM1F 价格&库存
很抱歉,暂时无法提供与“GQ-SH-112LM1F”相匹配的价格&库存,您可以联系我们找货
