EMI-SH-224A
EMI-SH-224A
    GOODSKY(国兴)
    插件,12.6x29mm
    24VAC
EMI-SH-224A 数据手册
EMI-2P MAIN FEATURE 1. Low power consumption; AC/DC coil available. 2. Proper insulation distance with 5,000VAC dielectric strength. 3. UL Class F insulation available. 4. In accordance with IEC 60335-1 and IEC 60730-1. 5. Halogen Free series available. 6. Comply with RoHS and REACH regulations CONTACT RATING Load Type Rated Load (Resistive) Contact Capacity Rated Carrying Current Max. Allowable Voltage Max. Allowable Current Max. Allowable Power Force Contact Material Contact Form EMI (DM/DB) EMI (D) EMI (AM/AB) EMI (A) EMI (FM/FB) 8A 250VAC 8A 250VAC 8A 250VAC 8A 250VAC 8A 250VAC 8A 30VDC 8A 30VDC 8A 30VDC 8A 30VDC 8A 30VDC 1/2HP 250VAC Pilot Duty R300 8A 8A 8A 8A 8A AC 250V AC 250V AC 250V AC 250V AC 250V DC 300V DC 300V DC 300V DC 300V DC 300V 8A 8A 8A 8A 8A 2,000VA 2,000VA 2,000VA 2,000VA 2,000VA 240W 240W 240W 240W 240W Ag Alloy Ag Alloy Ag Alloy Ag Alloy Ag Alloy DPST DPST DPDT DPST DPDT EMI (F) 8A 250VAC 8A 30VDC 1/2HP 250VAC Pilot Duty R300 8A AC 250V DC 300V 8A 2,000VA 240W Ag Alloy DPDT Max Allowable Voltage: 300VDC@0.2A APPLICATION Cooking Appliance, Audio Equipment, Domestic Appliance and Controlling Equipment…etc. PERFORMANCE (AT INITIAL VALUE) Contact Resistance ..............100 m Max.@1A,6VDC Operate Time........................12 mSec. Max. (DC coil only) 20 mSec. Max. (AC coil only) Release Time .......................8 mSec. Max. (DC coil only) 20 mSec. Max. (AC coil only) Dielectric Strength: Between Coil & Contact....... 5,000VAC at 50/60 Hz for one minute Between Contacts ................1,000VAC at 50/60 Hz for one minute Surge Strength: ....................10,000V (between coil & contact 1.2x50μSec.) Insulation Resistance ...........100M Min at 500VDC Max. On/Off Switching: Electrical ...............................6 Cycles per Minute Mechanical............................300 Cycles per Minute Temperature Range .............-40~+85 °C Humidity Range ....................45~85% RH. Coil Temperature Rise .........30 °C Max. 46 Vibration: Destruction ...................... 10 to 55 to 10 Hz,0.75 mm single amplitude (1.5mm double amplitude) Malfunction ...................... 10 to 55 to 10 Hz,0.75 mm single amplitude (1.5mm double amplitude) Shock: Destruction ...................... 1,000 m/S 2 Malfunction ...................... 100 m/S Life Expectancy: 5 Electrical .......................... 10 Operations at Rated Resistive Load 7 Mechanical ...................... 10 Operations at No load condition Weight ............................. About 12.5 g ACCESSORIES & SOCKETS PI-50BE ........................... See Page 171 PI-50BE/3 ......................... See Page 171 PI-50-0 .............................. See Page 173 SAFETY STANDARD & FILE NUMBER UL & C-UL………………… E141060 TÜV ……………………… R50008958 VDE ……………………… 40009648 CQC ……………………… 02001002511 EMI-2P COIL SPECIFICATION (AT 20°C) 50HZ 5 6 9 12 15 18 24 48 60 110 24 115 230 EMI DC Coil EMI AC Coil 29.75 7.65 3.42 60HZ 80 66.7 44.6 33.3 26.6 22.3 16.7 8.7 8.2 4.1 Power Consumption (DC: W; AC: VA) Coil Resistance (Ω±10%) 50HZ 62.5 90 202 360 560 810 1,440 5,520 7,340 26,530 350 8,100 32,500 25.35 6.3 2.72 60HZ Pull-In Voltage Drop-Out Voltage Abt. 0.40 5% Minimum 80% Maximum EMI-2P Coil Sensitivity Nominal Current (mA) Nominal Voltage (VAC/VDC) Maximum Allowable Voltage 130% Abt. 0.50 0.61 0.73 0.63 0.71 0.88 0.79 15% Minimum ORDERING INFORMATION EMI - SS - 2 12 F M I F Insulation System: Contact Material: Contact Form: Type: Coil Voltage: Number of Pole: Type of Sealing: Model Name: Nil: Standard Class F: Class F Nil: AgNi N: AgSnO2 I: AgSnO2+ In (new) J: AgSnO2+In Gilded (new) S: AgSnO2 Gilded Nil: Form C M: Form A B: Form B F: New Structure DC Coil, Pinning 5.0mm, 8A D: Standard DC Coil A: Standard AC Coil VDC ( 05: 5V, 06: 6V, 09: 9V, 12: 12V, 15: 15V, 18: 18V, 24: 24V, 48: 48V, 60: 60V, 110: 110V) VAC (24: 24V, 115: 115V, 230: 230V) 2: Two Poles SS: RT II Flux Proofed SH: RT III Wash Tight EMI CLASSIFICATION Model Coil Sensitivity Contact Form Flux Proofed Flux Proofed- New Wash Tight Wash Tight- New EMI – 2P DC Coil 2C AC Coil 2A 2B 2C EMI-SS-2 D EMI -SS-2 DM EMI -SS-2 DB EMI-SS-2 F EMI -SS-2 FM EMI -SS-2 FB EMI-SH-2 D EMI -SH-2 DM EMI -SH-2 DB EMI-SH-2 F FM FB EMI -SH-2 EMI -SH-2 EMI -SS-2 EMI -SH-2 - 2A A 2B EMI -SS-2 AM EMI -SS-2 - - A EMI -SH-2 AM EMI -SH-2 - - AB AB www.goodsky.com.tw 47 EMI-2P DIMENSION ( ≤ 5mm ± 0.2mm, > 5mm ± 0.3mm, the tolerance of PCB thru hole: +0.1mm) 15.8 7.6 EMI-2P-SS/SH 8-5 1.3 3.2 Ø 0.45 5 0.5 0.8 5 7.6 5 20 29 5 Bottom View 20 P.C.B Layout Bottom View 12.6 7.6 15.8 EMI-SS/SH-2D/AM 1.3 3.2 6-Ø 0.45*0.45 2.65 0.5 0.8 0.8 20 5 0.5 7.6 Bottom View P.C.B. Layout Bottom View 12.6 29 5 20 7.6 15.8 EMI-SS/SH-2D/AB 1.3 3.2 6-Ø 0.45*0.45 0.5 0.5 5 2.65 5 20 0.8 0.8 Bottom View 7.6 20 P.C.B. Layout Bottom View 12.6 29 7.6 17.45 EMI-2P-SS/SH (New Structure DC Coil) 3.5 20 29.4 48 1.3 0.9 5 5 8-5 Ø0.5 5 0.3 20 7.6 12.8 P.C.B Layout Bottom View 5 Bottom View EMI-2P EMI-2P 3.5 7.6 17.5 EMI-SS/SH-2FM(New Structure) 1.3 8-Ø Ø 0.5 0.3 0.3 20 29 .4 5 P.C.B Layout Bottom View 7. 6 5 20 0. 9 0. 9 12. 8 Bottom View 3.5 7.6 17.5 EMI-SS/SH-2FB(New Structure) 1.3 Ø 0.5 0.3 0.4 5 20 29 .4 8-Ø 0. 9 0. 9 7. 6 12. 8 20 5 P.C.B Layout Bottom View Bottom View REFERENCE DATA V.01EZ www.goodsky.com.tw 49
EMI-SH-224A 价格&库存
很抱歉,暂时无法提供与“EMI-SH-224A”相匹配的价格&库存,您可以联系我们找货
