GW11048-1
GW11048-1
    GATEWORKS
    GATEWORKS - GW11048-1 - Computer Board, GW7200, i.MX8M Family, 64bit, ARM Cortex-A53
GW11048-1 数据手册
​ Venice GW7200-00 Single Board Computer ​ DOC#11000544-01 A 70x100mm i.MX8M Mini SBC with 2 Mini-PCIe Slots, Two GbE Ethernet, PoE, GPS and MIPI-CSI & MIPI-DSI The GW7200-00 is a member of the Gateworks 7th generation Venice family of single board computers targeted for rugged and industrial embedded applications. The GW7200-00 features the 64-bit NXP™ i.MX8M Mini Quad Core ARM® Cortex™-A53 SoC processor operating at 1.6GHz, 1GBytes of LPDDR4 DRAM, and 8GBytes of eMMC System Flash. Two Mini-PCIe expansion sockets can be used for PCI Express peripherals such as 802.11ax/ac/b/g/n WiFi radios, 5G/4G/3G/CATM1 cellular modems. Peripheral headers support Digital I/O, Analog Input, RS232/RS485/TTL Serial, I2C and SPI. A combined MIPI-DSI/CSI header with I2S audio offers video input/output. A MicroSD & Nano SIM slot are standard. A 3-Axis accelerometer is standard. An optional GPS is available. The Gateworks System Controller provides embedded features such as real time clock, voltage and temperature monitor, programmable pushbutton, and programmable board shut-down and wake-up for remote applications. A wide-range DC input power supply provides up to 15W of power. Power is applied through a dedicated barrel jack or an Ethernet port in an active 802.3af/at or passive Power over Ethernet (PoE) architecture. Ubuntu Linux BSP is supported. SBC GW7200-00 GW7200-01 GW7201-00 GW7201-01 CPU Quad 1.6GHz Quad 1.6GHz Quad 1.6GHz Quad 1.6GHz DRAM 1GByte 4GByte 1GByte 4GByte eMMC 8GBytes 64GBytes 8GBytes 64GBytes GPS No No Yes Yes WiFi/BLE Use Mini-PCIe Slot Use Mini-PCIe Slot Use Mini-PCIe Slot Use Mini-PCIe Slot FEATURES NXP™ 64-bit i.MX8M Mini 1.6GHz Quad Core ARM ® Cortex™-A53 SoC Processor 1GByte LPDDR4 DRAM Memory 8GBytes eMMC Flash System Memory Two High-Power Gen 2 Mini-PCIe Sockets with USB 2.0 and Nano SIM MicroSD & Nano SIM slot Two GbE Ethernet Ports supporting 802.3at/af and Passive PoE Optional u-blox GPS Receiver with MMCX Antenna Connector ● Digital I/O & Analog Port, I2C & SPI Port ● RS232/RS485 and TTL Serial Port ● USB 2.0 OTG Port ● MIPI-DSI and MIPI-CSI Port, I2S Audio ● Digital 3-axis MEMS Accelerometer ● Real Time Clock with Battery Backup ● Voltage and Temperature Monitor ● Serial Configuration EEPROM ● Programmable Watchdog Timer ● 8 to 60VDC Input Voltage Range ● Power Through Dedicated Connector or Ethernet with 802.3af/at Active or Passive PoE ● 6W@25°C Typical Operating Power ● 15W Available for Mini-PCIe Sockets ● Reverse Voltage Protection ● -40°C to +85°C Operating Temperature ● Ubuntu Linux Board Support Package ● 1 Year Warranty ● ● ● ● ● ● ● GATEWORKS.COM 3026 S. Higuera St. San Luis Obispo, CA 93401 USA P:(805)781-2000 sales@gateworks.com ​ Venice GW7200-00 Single Board Computer ​ DOC#11000544-01 Venice GW7200-00 Block Diagram SPECIFICATIONS Electrical ORDERING OPTIONS Input Voltage ● 8 to 60VDC Barrel Jack or Active PoE Operating Current ● 163mA Typical @ 24VDC Mechanical Dimensions ● 70x100x21mm (2.75x3.9x0.8in) Weight ● 2.8 oz (80g) See table at beginning of datasheet Development Kit - GW11048-1-A ● ● ● ● ● ● GW7200 Single Board Computer U-Boot Boot Loader Ubuntu Linux Board Support Package Ethernet & Accessory Cables Power Supply JTAG Programmer Product Customization Environmental Operating Parameters ● Temperature: -40°C to +85°C ● *Note: -25C to +85C for -01 Models ● Humidity (non-condensing): 20% to 90% ● MTBF: 31.8 Years at 55°C Storage Parameters The GW7200 can be customized for volume applications. Contact the factory for additional information. ● i.MX8M Mini processor type and speed ● LPDDR4 DRAM up to 4GBytes ● System Flash up to 64GBytes ● GPS ● Removing peripherals to achieve lowest cost ● Temperature: -40°C to +85°C ● Humidity (non-condensing): 5% to 95% GATEWORKS.COM 3026 S. Higuera St. San Luis Obispo, CA 93401 USA P:(805)781-2000 sales@gateworks.com
GW11048-1 价格&库存
很抱歉,暂时无法提供与“GW11048-1”相匹配的价格&库存,您可以联系我们找货
