GW16141
GW16141
    GATEWORKS
    GATEWORKS - GW16141 - Adapter Card, Mini-PCIe to M.2 Cellular Modem, Gateworks Single Board Computer...
GW16141 数据手册
​GW16140/1​ ​Mini-PCIe to M.2 Cellular Adapters DOC#11000812-02 Mini-PCIe to M.2 Cellular Modem Adapter Cards The GW16140/GW16141 are Mini-PCIe to M.2 Adapters designed to allow support of M.2 Cellular Modems on Gateworks single board computers. Embedded Cellular Modems come in many form factors, including Mini-PCIe and M.2. These adapters allow M.2 B-Key Cellular Modem cards to be plugged into a Mini-PCIe slot on a Gateworks Single Board Computer. The adapters feature dual Nano SIM slots for redundancy and switching between networks. Many Cellular Modems typically have pin signal conflicts with standard specifications, so these adapters only pass through the minimum required signalling to avoid these conflicts. The adapters come in different variants for different signalling. The GW16140 is used for modems that support USB 2.0 signals and the GW16141 is used for higher bandwidth modems that require USB 3.0 signalling. Please consult the SBC Mini-PCIe slots compatibility for USB 2.0 or 3.0 support. The adapters support M.2 cards in the following M.2 sizes: 2242 (22mm x 42mm), 3042 (30mm x 42mm), 3050 (30mm x 50mm), and 3052 (30mm x 52mm). The following sizes are also available: 1630, 2230, 3030. FEATURES ● Mini-PCIe to M.2 Cellular Modem Adapter ● M.2 B-Key Support ● Supports M.2 Sizes: 1630, 2230, 3030 2242, 3042, 3050, 3052 ● Dual Nano SIM Sockets on back side ● Minimal signalling to avoid pin conflicts ● GW16140 Supports USB 2.0 Modems Ventana/Venice Families - Verify Slot ● GW16141 Supports USB 3.0 Modems Newport Family - Verify Slot ● Customized variations also available to support other M.2 peripherals ● -40°C to +85°C Operating Temperature ● Made in USA ● 1 Year Warranty SPECIFICATIONS Electrical ORDERING OPTIONS Product Customization Input Voltage ● 3.3V From Mini-PCIe Edge Connector Operating Current ● Not Applicable Mechanical The GW16140/1 can be customized for high volume applications. Contact the factory for information. ● Removing resistors to achieve compatibility ● Alternative M.2 Keys, A-Key, E-Key Dimensions ● 30.0x66x6.2mm (1.18x2.59x0.24in) Weight ● .2 oz (5.7g) Environmental Operating Parameters ● Temperature: -40°C to +85°C ● Humidity (non-condensing): 20% to 90% ● MTBF: TBD Years at 55°C Storage Parameters ● Temperature: -40°C to +85°C ● Humidity (non-condensing): 5% to 95% GATEWORKS.COM 3026 S. Higuera St. San Luis Obispo, CA 93401 USA P:(805)781-2000 F:(805)781-2001
GW16141 价格&库存
很抱歉,暂时无法提供与“GW16141”相匹配的价格&库存,您可以联系我们找货
