GW16130
GW16130
    GATEWORKS
    GATEWORKS - GW16130 - Expansion Card, Satellite Modem Module, 9603N, Mini-PCIe, ARM Cortex-A53
GW16130 数据手册
GW16130 Mini-PCIe Satellite Modem DOC#11000569-00 INNOVATIONS FOR EMBEDDED DESIGNS A Mini-PCIe Satellite Modem for IoT Applications The GW16130 is a Mini-PCIe Satellite Modem that provides cost-effective, short burst satellite connectivity for asset tracking, fleet management, telemetry, oceanographic data, grid monitoring and Internet of Things (IoT) applications. The GW16130 features an Iridium 9603N satellite transceiver which allows two-way communications anywhere in the world with a clear line of sight to the sky. The Iridium network consists of 66 satellites and provides 24/7 world wide coverage. The 9603N module is used for short burst data packets (340bytes uplink, 270bytes downlink) and perfect for IoT remote sensor applications with minimal non-realtime data requirements. The GW16130 modem will work in a full size Mini-PCIe socket that includes a USB 2.0 interface. See the Gateworks website for suggested single board computers that can be used with this modem. Serial communication to the module is through an onboard FTDI USB to UART bridge. All power conditioning circuitry is contained on the board in addition to a u.Fl antenna connector for connecting an external satellite antenna. Note that an Iridium approved satellite antenna must be used when operating on the Iridium network. The GW16130 modem requires a monthly data plan which can be established with a number of 3 rd party providers. Typical data charges are ~$20 USD per month with 12Kbytes of data included. See the Gateworks Support Wiki for more information on recommended antennas and data plans. FEATURES         Iridium 9603N SBD Satellite Transceiver Small lightweight module for embedded applications Offers low cost, low bandwidth satellite communications Max Message payload: 340 bytes upload, 270 bytes download Automatic message notification on incomming messages Operates anywhere on earth including North & South Poles Supports E-mail messages or HTTP POST Simple UART AT command interface Operating frequency: 1616MHz to 1626.5MHz 1.6W Average transmit power -117dBm Receiver sensitivity Full industrial temperature operation No SIM card required Onboard u.Fl antenna port for antenna connection Full size Mini-PCIe mechanical form factor Utilizes Mini-PCIe USB 2.0 channel for communications See Gateworks website for compatible SBCs 3.3V Operating Voltage from Mini-PCIe Connector 7.2W@25°C Peak Operating Power (Transmit) 0.85W@25°C Average Operating Power (Receive/Idle) -40C to +85C Operating Temperature 1 Year Warranty G A T E W O R K S. CO M 3 0 2 6 S. H i g u e r a St . Sa n L ui s O b i s p o , CA 9 3 4 0 1 P:(805)781-2000 s a l e s @g a t e w o r k s . c o m GW16130 Mini-PCIe Satellite Modem DOC#11000569-00 INNOVATIONS FOR EMBEDDED DESIGNS USB2.0 FTDI USB to UART UART Iridium 9603N Satellite Tranceiver u.Fl Ant. Mini-PCIe 3.3VDC Boost DC/DC 5VDC & RST GW16130 Satellite Modem Block Diagram SPECIFICATIONS Environmental Electrical Operating Parameters Input Voltage  3.3V Mini-PCIe Edge Connector Operating Current   2.2A Peak Transmit 0.3A Average Receive/Idle Dimensions 30.00 x 50.95 x 11.60 mm (1.18 x 2.00 x 0.46 in) Weight  0.67oz (19.0g) G A T E W O R K S. CO M Temperature: -40C to +85C Humidity (non-condensing): 20% to 90% MTBF: TBD Years (MIL-HDBK-217) Storage Parameters   Mechanical     Temperature: -40C to +85C Humidity (non-condensing): 5% to 95% ORDERING OPTIONS Standard Configuration – GW16130 3 0 2 6 S. H i g u e r a St . Sa n L ui s O b i s p o , CA 9 3 4 0 1 P:(805)781-2000 s a l e s @g a t e w o r k s . c o m
GW16130 价格&库存
很抱歉,暂时无法提供与“GW16130”相匹配的价格&库存,您可以联系我们找货
GW16130
    库存:5
