GW16146
GW16146
    GATEWORKS
    GATEWORKS - GW16146 - WiFi Radio Board, FT232H, Mini-PCIe, ARM Cortex-A53
GW16146 数据手册
GW16146 802.11ah Mini-PCIe WiFi Radio ​ DOC#11000908-00 802.11AH Mini-PCIe WiFi Radio The GW16146 is a low power, long range, 900MHz 802.11ah full size Mini-PCIe WiFi radio designed to provide Wi-Fi HaLow wireless communication utilizing Gateworks Single Board Computers. The 802.11ah radio is targeted towards Internet of Things (IoT) applications. The GW16146 features a Silex SX-NEWAH 802.11ah module that is powered by the NRC7292 System-on-Chip from Newracom. The radio operates in the 900MHz license-exempt band which allows it to penetrate buildings, walls and foliage much better than standard 2.4G/5G WiFi radios. Additionally, 802.11ah provides much greater range (1km+) and higher bandwidth (up to 4Mbps) over other Sub 1GHz protocols like LoRa and Sigfox. Other advantages include a higher client count (100+) and lower power. Standard WiFi IP connectivity software, including Linux tools, commands and interfaces are also supported allowing for quick application integration. An onboard FTDI SPI to USB bridge allows a Gateworks Single Board Computer to communicate to the module using USB 2.0 signaling which is supported on many Mini-PCIe connector interfaces. A MHF-1 antenna connector allows for a variety of external antenna choices. Antenna and cables sold separately. FEATURES ● Silex SX-NEWAH 802.11ah Module ○ Based on Newracom NRC7292 System-on-Chip ○ IEEE 802.11ah WiFi HaLow ○ Simultaneous GATT Server & Client ○ FOTA Support ○ Up to 4Mbps data rate ○ Supports 1/2/4 MHz bandwidth ○ Access point and station mode ○ Security: OPEN, WPA2-PSK(AES), WPA3-OWE, WPA3-SAE ○ 902.0 ~ 928.0 MHz Frequency ○ +23dBm Transmit Power ○ MHF-1 Antenna port ○ Uses standard Linux IP framework ○ FCC Certified ● FTDI FT232H USB to SPI ● Mini-PCIe Form Factor with USB 2.0 High Speed Signaling ● -40°C to +85°C Operating Temperature ● Made in USA ● 1 Year Warranty SPECIFICATIONS Electrical Input Voltage ● 3.3V From Mini-PCIe Edge Connector Typical Operating Current ● 75mA @ 3.3V Environmental Operating Parameters ● Temperature: -40°C to +85°C ● Humidity (non-condensing): 20% to 90% Mechanical Dimensions Storage Parameters ● 30.0x50.95x3.5mm (1.18x2.0x0.14in) ● Temperature: -40°C to +85°C ● Humidity (non-condensing): 5% to 95% Weight ● 0.22 oz (6.2g) GATEWORKS.COM 3026 S. Higuera St. San Luis Obispo, CA 93401 USA P:(805)781-2000 F:(805)781-2001
GW16146 价格&库存
很抱歉,暂时无法提供与“GW16146”相匹配的价格&库存,您可以联系我们找货
