GW7300-00
GW7300-00
    GATEWORKS
    GATEWORKS - GW7300-00 - Single Board Computer, GW7300, i.MX8M Family, ARM Cortex-A53, 1GB LPDDR4 RAM
GW7300-00 数据手册
​ Venice GW7300-00 Single Board Computer ​ DOC#11000552-03 A 105x100mm i.MX8M Mini SBC with 3 Mini-PCIe Slots, Two GbE Ethernet, PoE, Wifi/BLE and MIPI-CSI & MIPI-DSI The GW7300-00 is a member of the Gateworks 7th generation Venice family of single board computers targeted for rugged and industrial embedded applications. The GW7300-00 features the 64-bit NXP™ i.MX8M Mini Quad Core ARM® Cortex™-A53 SoC processor operating at 1.6GHz, 1GBytes of LPDDR4 DRAM, and 8GBytes of eMMC System Flash. Two Mini-PCIe expansion sockets can be used for PCI Express peripherals such as 802.11ax/ac/b/g/n WiFi radios and 5G/4G/3G/CATM1 cellular modems. A third Mini-PCIe socket supports only USB for modems. Peripheral headers support Digital I/O, Analog Input, RS232/RS485/TTL Serial, I2C and SPI. A combined MIPI-DSI/CSI header with I2S audio offers video input/output. A MicroSD & Nano SIM slot are standard. A 3-Axis accelerometer is standard. An optional GPS and onboard Laird Sterling 802.11b/g/n WiFi/Bluetooth module are available. The Gateworks System Controller provides embedded features such as real time clock, voltage and temperature monitor, programmable pushbutton, and programmable board shut-down and wake-up for remote applications. A wide-range DC input power supply provides up to 15W of power. Power is applied through a dedicated barrel jack or an Ethernet port in an active 802.3af/at or passive Power over Ethernet (PoE) architecture. Ubuntu Linux BSP is supported. SBC GW7300-00 GW7300-01 GW7301-00 GW7301-01 CPU Quad 1.6GHz Quad 1.6GHz Quad 1.6GHz Quad 1.6GHz DRAM 1GByte 4GByte 1GByte 4GByte eMMC 8GBytes 64GBytes 8GBytes 64GBytes GPS No No Yes Yes WiFi/BLE No No Yes Yes FEATURES ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● NXP™ 64-bit i.MX8M Mini 1.6GHz Quad Core ARM ® Cortex™-A53 SoC Processor 1GByte LPDDR4 DRAM Memory 8GBytes eMMC Flash System Memory Two High-Power Gen 2 Mini-PCIe Sockets with PCIe and USB 2.0 One High-Power Mini-PCIe Socket with only USB 2.0 and Nano SIM MicroSD & Nano SIM slot Two GbE Ethernet Ports supporting 802.3at/af and Passive PoE Optional Laird Sterling 802.11b/g/n WiFi & BLE v4.2 Module Optional u-blox GPS Receiver with MMCX Antenna Connector Digital I/O & Analog Port, I2C & SPI Port RS232/RS485 and TTL Serial Port USB 2.0 Host and OTG Ports MIPI-DSI and MIPI-CSI Port, I2S Audio Digital 3-axis MEMS Accelerometer Real Time Clock with Battery Backup Voltage and Temperature Monitor Serial Configuration EEPROM Programmable Watchdog Timer 8 to 60VDC Input Voltage Range Power Through Dedicated Connector or Ethernet with 802.3af/at Active or Passive PoE 6W@25°C Typical Operating Power 15W Available for Mini-PCIe Sockets Reverse Voltage Protection -40°C to +85°C Operating Temperature Ubuntu Linux Board Support Package 1 Year Warranty GATEWORKS.COM 3026 S. Higuera St. San Luis Obispo, CA 93401 USA P:(805)781-2000 sales@gateworks.com ​ Venice GW7300-00 Single Board Computer ​ DOC#11000552-03 Venice GW7300-00 Block Diagram SPECIFICATIONS Electrical ORDERING OPTIONS Input Voltage ● 8 to 60VDC Barrel Jack or Active PoE Operating Current ● 250mA Typical @ 24VDC Mechanical Dimensions ● 105x100x21mm (4.1x3.9x0.8in) Weight ● 3.8 oz (110g) See table at beginning of datasheet Development Kit - GW11049-1-A ● ● ● ● ● ● GW7300 Single Board Computer U-Boot Boot Loader Ubuntu Linux Board Support Package Ethernet & Accessory Cables Power Supply JTAG Programmer Product Customization Environmental Operating Parameters ● Temperature: -40°C to +85°C ● *Note: -25C to +85C for -01 Models ● Humidity (non-condensing): 20% to 90% ● MTBF: 31.7 Years at 55°C Storage Parameters The GW7300 can be customized for volume applications. Contact the factory for additional information. ● i.MX8M Mini processor type and speed ● LPDDR4 DRAM up to 4GBytes ● System Flash up to 64GBytes ● GPS & WiFi/BLE ● Removing peripherals to achieve lowest cost ● Temperature: -40°C to +85°C ● Humidity (non-condensing): 5% to 95% GATEWORKS.COM 3026 S. Higuera St. San Luis Obispo, CA 93401 USA P:(805)781-2000 sales@gateworks.com
GW7300-00 价格&库存
很抱歉,暂时无法提供与“GW7300-00”相匹配的价格&库存,您可以联系我们找货
