HSW221M2WP30M
HSW221M2WP30M
    JAMICONTEAPO(凯美)
    插件,D30xL30mm
    220UF ±20% 450V
HSW221M2WP30M 数据手册
LARGE CAN TYPE HS Wide Temperature Range Series • Withstanding 2000 hours application of high ripple current at 105°C. • Corresponding product to RoHS SPECIFICATION Item Characteristic Operation Temperature Range -40 ~ +105°C Rated Working Voltage 16 ~ 500VDC Capacitance Tolerance (120Hz 20°C) Leakage Current (20°C) Surge Voltage (20°C) Dissipation Factor (tan ) (120Hz 20°C) ±20%(M) I 0.02CV or 3 ( mA ) *Whichever is smaller after 5 minutes I : Leakage Current( µA) C : Rated Capacitance( µF) V : Working Voltage(V) W.V. 16 25 35 50 63 80 100 160 180 200 250 350 400 450 500 S.V. 20 32 44 63 79 100 125 200 225 250 300 400 450 500 550 Rated Voltage (V) 16 25 50 35 63 80 100 Capacitance 33,000 47,000 33,000 47,000 22,000 27,000 6,800 10,000 6,800 10,000 3,300 4,700 3,300 4,700 tan  160 __ 0.50 0.60 0.40 0.50 0.35 0.40 0.30 0.35 0.25 0.35 0.20 0.25 0.20 0.25 0.15 Impedance ratio at 120Hz Low Temperature Stability Rated Voltage (V) 16 25 35 50 63~100 160~250 350~500 -25°C / +20°C 6 6 6 4 3 -40°C / +20°C 15 15 10 8 6 4 __ 6 __ After 2000 hours application of W.V. at +105°C the capacitor shall meet the following limits. Load Life Shelf Life Capacitance Change ±20% of initial value Dissipation Factor 175% of initial specified value Leakage current initial specified value At +105°C, no voltage application after 1000 hours, the capacitor shall meet the limits for load life characteristics. (With voltage treatment) TERMINAL TYPE LARGE CAN TYPE P.C.B. TERMINAL (SNAP IN) Code 11~13 : S1A (22~35) P.C.B. TERMINAL Code 11~13 : LBA (25~30), LCA (35) (25~30) (35) A.B. blank terminals RIPPLE CURRENT COEFFICIENTS Temperature(°C) Multiplier ※ For 45 dimension, refer to page 16. 170 D 22 25 30 35 P 8 10 10 14 LUG TERMINAL Code 11~13 : LTA (22~35) Frequency(Hz) W.V. 100V 160V 40 2.50 60 0.80 0.80 60 2.20 70 2.00 400 1k Multiplier 1.00 1.10 1.20 1.00 1.10 1.30 120 85 1.80 10k 1.20 1.40 105 1.00 HS Series Case size :DxL (mm) Max ripple current : A (rms) (R.C.) : 105°C 120Hz CASE SIZE & MAX RIPPLE CURRENT V(DC) D µF 22 25 16 30 35 45 22 25 25 30 35 45 22 25 35 30 35 45 1500 25 1.17 30 25 1.43 1.36 35 30 25 1.65 1.58 1.56 50 40 30 25 2.09 1.94 1.82 1.96 50 35 30 2.24 2.03 2.20 50 40 2.79 2.92 2200 25 1.36 35 30 1.74 1.67 45 35 25 2.09 1.92 1.77 45 35 30 2.29 2.17 2.36 45 35 2.86 2.97 25 1.34 30 25 1.58 1.51 35 30 25 1.85 1.78 1.75 45 35 30 25 2.19 2.01 2.00 2.15 45 35 30 2.54 2.41 2.61 45 40 3.24 3.55 50 4.21 50 4.78 3300 4700 6800 10000 15000 22000 50 4.49 55 5.16 27000 33000 47000 56000 V(DC) D µF 22 25 63 30 35 50 5.24 55 5.65 45 22 25 80 30 35 50 5.24 60 6.17 45 22 25 100 30 35 45 390 470 560 680 820 30 25 1.04 0.99 30 25 1.11 1.06 30 25 1.14 1.08 35 30 25 1.28 1.23 1.21 40 35 25 1.44 1.39 1.29 35 30 25 1.40 1.35 1.33 45 40 30 25 1.77 1.72 1.61 1.73 50 40 30 25 1.72 1.60 1.50 1.61 50 40 30 1.97 1.78 1.93 45 35 1.77 1.68 45 35 2.07 2.15 50 35 30 2.03 1.84 2.00 45 40 2.20 2.41 50 40 2.11 2.31 50 2.72 45 2.52 1800 2200 3300 6800 8200 10000 50 2.87 12000 15000 18000 60 3.95 65 4.48 60 3.95 65 4.57 22 25 0.88 30 1.03 30 1.14 35 1.32 40 1.55 45 1.79 25 25 1.03 25 1.13 30 1.33 35 1.57 40 1.82 45 2.12 50 2.43 160 30 25 1.38 25 1.53 30 1.80 35 2.12 35 2.32 45 2.88 35 45 25 1.84 25 2.04 30 2.39 35 2.84 40 3.28 50 4.52 55 5.11 3900 4700 55 4.62 65 5.49 LARGE CAN TYPE 25 0.91 1200 1500 45 L(mm) R.C. 330 1000 50 22 25 30 35 25 1.05 30 25 1.31 1.25 35 30 25 1.58 1.52 1.50 45 35 30 25 1.90 1.74 1.73 1.86 50 35 30 2.19 1.98 2.15 45 40 2.39 2.62 50 3.52 60 3.27 65 3.73 L(mm) R.C. 171 HS Series Case size :DxL (mm) Max ripple current : A (rms) (R.C.) : 105°C 120Hz CASE SIZE & MAX RIPPLE CURRENT V(DC) D µF 22 25 180 30 35 45 220 270 330 390 470 560 680 820 1000 1200 1500 1800 25 0.80 30 0.95 30 1.03 35 1.21 40 1.40 45 1.63 50 1.88 25 0.95 25 1.04 30 1.22 30 1.34 35 1.57 40 1.83 45 2.12 25 1.27 25 1.39 30 1.64 30 1.80 35 2.12 40 2.45 50 2.91 25 1.68 25 1.85 30 2.18 30 2.39 35 2.74 40 3.17 22 25 0.85 25 0.94 30 1.12 35 1.31 40 1.52 45 1.75 50 2.02 25 25 1.12 25 1.22 30 1.45 35 1.68 40 1.96 45 2.27 50 2.63 200 30 25 1.50 30 1.76 30 1.94 35 2.26 40 2.64 45 3.04 35 45 25 1.98 30 2.33 30 2.58 35 3.00 45 3.58 50 4.10 2200 2700 3300 LARGE CAN TYPE 3900 172 55 4.70 65 5.48 50 4.43 60 5.28 22 30 0.91 35 1.07 35 1.19 40 1.37 50 1.66 25 25 0.91 25 1.01 30 1.20 35 1.39 40 1.61 45 1.85 50 2.14 250 30 25 1.24 25 1.35 30 1.59 35 1.85 35 2.04 45 2.49 35 45 25 1.63 25 1.78 30 2.10 35 2.45 40 2.86 45 3.29 50 3.68 55 4.29 65 5.10 L(mm) R.C. HS Series Case size :DxL (mm) Max ripple current : A (rms) (R.C.) : 105°C 120Hz CASE SIZE & MAX RIPPLE CURRENT V(DC) D µF 22 25 350 30 35 45 22 25 400 30 35 45 47 25 0.47 30 0.56 30 0.61 35 0.72 40 0.85 45 0.98 68 82 100 120 150 180 220 270 330 390 470 560 25 0.43 30 0.51 30 0.55 35 0.66 40 0.77 50 0.94 25 0.51 25 0.55 30 0.67 35 0.78 40 0.91 45 1.07 50 1.23 25 0.69 30 0.82 30 0.90 35 1.06 40 1.24 45 1.42 25 0.92 30 1.10 30 1.21 35 1.40 40 1.62 45 1.86 25 0.56 25 0.61 30 0.73 35 0.86 40 1.00 45 1.17 50 1.35 25 0.75 30 0.90 30 0.99 35 1.16 40 1.36 45 1.58 25 1.01 30 1.20 30 1.33 35 1.56 40 1.79 45 2.07 50 2.36 680 820 1000 2200 55 2.59 65 4.12 50 2.72 60 3.24 22 25 0.39 30 0.50 35 0.59 40 0.69 45 0.80 25 25 0.50 30 0.60 35 0.70 35 0.77 45 0.96 50 1.10 450 30 25 0.68 30 0.80 35 0.96 35 1.05 40 1.22 50 1.49 35 45 25 0.82 30 0.99 30 1.08 35 1.27 40 1.48 45 1.72 50 1.96 22 25 0.27 30 0.35 35 0.41 40 0.47 50 0.57 25 25 0.35 30 0.41 35 0.48 40 0.56 45 0.66 50 0.75 500 30 30 0.50 35 0.59 40 0.69 40 0.76 45 0.88 50 1.02 35 45 25 0.56 30 0.68 35 0.79 40 0.92 45 1.07 50 1.23 55 2.49 65 2.93 L(mm) R.C. LARGE CAN TYPE 173
HSW221M2WP30M 价格&库存
很抱歉,暂时无法提供与“HSW221M2WP30M”相匹配的价格&库存,您可以联系我们找货
