HMW391M2EN35M
HMW391M2EN35M
    JAMICONTEAPO(凯美)
    嵌入,22x35mm
    390UF ±20% 250V
HMW391M2EN35M 数据手册
LARGE CAN TYPE HM Series Snap-in Terminal Type, Small Sized • Small case sized than HS series. • Withstanding 2000 hours application of high ripple current at 105°C. • Corresponding product to RoHS SPECIFICATION Item Characteristic Operation Temperature Range -25 ~ +105°C Rated Working Voltage 160 ~ 450VDC Capacitance Tolerance (120Hz 20°C) Leakage Current (20°C) ±20%(M) I 0.02CV or 3 ( mA ) *Whichever is smaller after 5 minutes I : Leakage Current( µA) C : Rated Capacitance( µF) V : Working Voltage(V) 160 W.V. Surge Voltage (20°C) Dissipation Factor (tan ) (120Hz 20°C) S.V. 200 250 350 400 450 200 250 300 400 450 500 Rated Voltage (V) 160 200 250 350 400 450 tan  0.15 0.15 0.15 0.15 0.15 0.15 Impedance ratio at 120Hz Low Temperature Stability Rated Voltage (V) -25°C / +20°C 160~250 350~450 4 6 After 2000 hours application of W.V. and +105°C ripple current value, the capacitor shall meet the following limits. (DC + ripple peak voltage  rate working voltage) Load Life Shelf Life Capacitance Change ±20% of initial value Dissipation Factor 175% of initial specified value Leakage current initial specified value At +105°C, no voltage application after 1000 hours, the capacitor shall meet the limits for load life characteristics. (With voltage treatment) TERMINAL TYPE LARGE CAN TYPE P.C.B. TERMINAL (SNAP IN) Code 11~13 : S1A (22~35) P.C.B. TERMINAL Code 11~13 : LBA (25~30), LCA (35) (25~30) (35) A.B. blank terminals RIPPLE CURRENT COEFFICIENTS Temperature(°C) Multiplier Frequency(Hz) W.V. 160V 174 D 22 25 30 35 P 8 10 10 14 LUG TERMINAL Code 11~13 : LTA (22~35) 40 2.50 60 0.80 60 2.20 70 2.00 400 1k Multiplier 1.00 1.10 1.30 120 85 1.80 10k 1.40 105 1.00 HM Series Case size :DxL Max ripple current : A(rms) CASE SIZE & MAX RIPPLE CURRENT 160 V(DC) µF D 22 25 35 22 25 30 35 220 270 330 390 25 1.44 30 1.48 30 1.63 35 1.84 40 2.10 470 560 680 820 1000 1200 1500 1800 25 1.63 30 1.85 35 2.13 40 2.30 45 2.42 50 2.56 25 1.92 25 2.07 30 2.27 35 2.41 40 2.58 45 2.89 50 3.13 2200 2700 3300 D 25 1.48 30 1.75 35 1.98 45 2.37 50 2.54 22 25 25 1.92 30 2.22 35 2.42 40 2.55 45 2.71 25 2.28 30 2.49 30 2.49 40 2.82 45 3.16 35 22 25 150 180 220 270 330 390 470 560 680 820 25 0.73 30 0.87 30 0.92 40 1.15 45 1.31 50 1.42 25 1.12 25 1.21 30 1.36 35 1.49 40 1.73 45 1.93 25 0.95 30 1.13 35 1.31 35 1.36 45 1.55 50 1.79 30 1.40 35 1.53 40 1.78 45 1.97 25 1.41 25 1.44 30 1.71 35 1.92 40 2.19 45 2.35 35 25 1.75 30 1.98 30 2.13 35 2.32 45 2.56 50 2.71 35 25 0.80 30 0.90 35 1.06 40 1.18 45 1.37 50 1.56 25 1.03 30 1.16 35 1.37 40 1.58 45 1.72 50 1.85 25 1.19 30 1.41 30 1.54 35 1.69 40 1.84 45 2.12 22 25 0.47 30 0.55 30 0.61 35 0.71 40 0.85 45 0.93 25 25 0.61 30 0.72 30 0.81 40 0.95 45 1.10 50 1.21 30 25 0.84 30 0.93 30 1.03 40 1.22 45 1.42 50 1.61 35 25 1.06 30 1.19 35 1.40 40 1.60 45 1.75 50 1.88 LARGE CAN TYPE 25 0.61 30 0.72 30 0.80 35 0.89 45 1.10 50 1.21 100 30 450 30 82 25 0.58 30 0.71 30 0.73 35 0.87 40 0.96 45 1.12 25 400 30 68 120 22 25 0.89 25 0.94 30 1.12 35 1.30 40 1.42 45 1.54 50 1.78 L(mm) R.C. 350 V(DC) µF 25 2.33 30 2.49 30 2.52 35 2.85 40 3.11 50 3.77 25 1.29 30 1.44 30 1.48 40 1.84 45 2.05 50 2.31 (mm) 120Hz 250 200 30 105°C L(mm) R.C. 175
HMW391M2EN35M 价格&库存
很抱歉,暂时无法提供与“HMW391M2EN35M”相匹配的价格&库存,您可以联系我们找货
