CHM221M1HG10W
CHM221M1HG10W
    JAMICONTEAPO(凯美)
    SMD,D10xL10.2mm
    220UF ±20% 50V
CHM221M1HG10W 数据手册
Parts number system SPECIAL REQUIREMENTS STANDARD NUMBER 1 2 3 9 10 11 12 13 14 15 16 S K R 2 2 1 M 1 C F B B M - - E SERIES Series Code Type SS PT SH NC PH SL RV PC NS LP PF SK HP PB SM LS CS HS UK CA TM HM CN NK LT CR LL LK CT MZ HT CE TB HV CP TP HL CH WL HF CL WG KP MP CK TZ GP CZ TC RP CD TH XP CJ TX BP CB TJ FP SV TF EP ST TA NT WB Description Bulk P Taping (Ammo Pack) C Lead Cut F Lead Forming Cut B Lead Forming Only Y Lead Snap in W G Snap in Terminal V G Type Terminal V Type Terminal S Screw Terminal Type M Chip TL CAPACITANCE (µF) Screw CF 6 R Lug CU WJ HX 5 Radial PS TK TYPE 4 Surface Mount Type 7 CAP. TOL. 8 VOLTAGE (W.V.) CAP (µF) Code CASE SIZE (Dmm) (L.mm)-Length of AI.case Tolerance Code (%) 0.1 OR1 +10 0.22 R22 -10 0.33 R33 +15 0.47 R47 -15 1 010 +20 2.2 2R2 -20 3.3 3R3 +100 4.7 4R7 -0 10 100 +30 22 220 -10 33 330 +20 47 470 -0 100 101 +50 220 221 -10 330 331 +75 470 471 -10 1000 102 +20 2200 222 -10 3300 332 +20 4700 472 -5 10000 103 +30 22000 223 -0 33000 333 +100 47000 473 -10 K L M P Q R T U V H F W Voltage Diameter Length Code (W.V.) Code () (L) Code Code Dascription Without 2.5 0E 3 A 11 11 4 0G 3.8 S 11.5 BB 6.3 0J 4 C 12.5 BC 1~9 Customer 10 1A 5 D 31.5 DB A~Z Assign 13 1P 6 W 35.5 DF a~ Brand 16 1C 6.3 E 100 1H 20 1D 7 Y 110 1A 25 1E 8 F 115 1K 35 1V 10 G 120 1B 40 1G 12 H 121 1M 50 1H 12.5 I 130 1C 63 1J 13 J 131 1P 80 1K 16 K 140 1D 100 2A 18 L 144 1Q 125 2B 20 M 150 1E 160 2C 22 N 155 1N 180 2M 25 O 157 1R 200 2D 30 P 160 1F 250 2E 35 Q 170 1G 315 2F 40 R 180 1I 330 2U 51 V 190 1J 350 2V 64 1 196 1S 400 2G 77 2 215 1L 450 2W 90 3 236 1T 500 2H W Sleeve Code Dascription E PET Sleeve
CHM221M1HG10W 价格&库存
很抱歉,暂时无法提供与“CHM221M1HG10W”相匹配的价格&库存,您可以联系我们找货
