ACC-930-033-R
ACC-930-033-R
    LANTRONIX
    LANTRONIX - ACC-930-033-R - Antenna, PremierWave 2050 Enterprise Wi-Fi IoT Module, 2.4 GHz, 5 GHz, 2...
ACC-930-033-R 数据手册
PremierWave 2050 Enterprise Wi-Fi® IoT Module Integration Guide Part Number 900-731-R Revision C February 2017 Intellectual Property © 2017 Lantronix, Inc. All rights reserved. No part of the contents of this publication may be transmitted or reproduced in any form or by any means without the written permission of Lantronix. Lantronix and PremierWave are registered trademarks of Lantronix, Inc. in the United States and other countries. Patented: http://patents.lantronix.com; additional patents pending. Wi-Fi is a registered trademark of Wi-Fi Alliance Corporation. Ethertronics is a trademark of Ethertronics, Inc. Exar is a trademark of Exar Integrated Systems Corporation. SEMTECH is a trademark of Semtech Corporation. All other trademarks and trade names are the property of their respective holders. Contacts Lantronix, Inc. 7535 Irvine Center Drive, Suite 100 Irvine, CA 92618, USA Toll Free: 800-526-8766 Phone: 949-453-3990 Fax: 949-453-3995 Technical Support Online: www.lantronix.com/support Sales Offices For a current list of our domestic and international sales offices, go to the Lantronix web site at www.lantronix.com/about/contact Disclaimer All information contained herein is provided “AS IS.” Lantronix undertakes no obligation to update the information in this publication. Lantronix does not make, and specifically disclaims, all warranties of any kind (express, implied or otherwise) regarding title, non-infringement, fitness, quality, accuracy, completeness, usefulness, suitability or performance of the information provided herein. Lantronix shall have no liability whatsoever to any user for any damages, losses and causes of action (whether in contract or in tort or otherwise) in connection with the user’s access or usage of any of the information or content contained herein. The information and specifications contained in this document are subject to change without notice. This equipment has to be tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 2 If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one of the following measures: 1. Reorient or relocate the receiving antenna. 2. Increase the separation between the equipment and receiver. 3. Connect the equipment into an outlet on a circuit different from that to which the receiver is connected. 4. Consult the dealer or an experienced radio/TV technician for help. This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. This device is intended only for OEM Integrators. The OEM integrator should be aware of the following important considerations. Labeling of the End Product The label on the end product incorporating the PremierWave 2050 module must clearly state that it contains an FCC-approved RF module. Canada and Japan also require a similar statement. For example, “This product contains RF transmitter ID # (put FCC, IC, CMIIT, and/or Japan module grant numbers here).” The label must include the ID numbers for the regions where the end product is installed. The grant numbers are below. ♦ PremierWave 2050 FCC ID number: R68PW2050 ♦ PremierWave 2050 IC ID number: 3867A-PW2050 ♦ PremierWave 2050 Japan ID numbers: 201-152843 ♦ PremierWave 2050 China SRRC CMIIT ID: 2015AJ6847 (M) RSS-GEN Sections 7.1.4 and 7.1.5 Statement for Devices with Detachable Antennas This device has been designed to operate with the antennas listed in the Certificate, and having a maximum gain of 5.5 dBi. Antennas not included in this list or having a gain greater than 5.5 dBi are strictly prohibited for use with this device, unless system level approval is gained. The required antenna impedance is 50 ohms. To reduce potential radio interference to other users, the antenna type and its gain should be so chosen that the equivalent isotropically radiated power (EIRP) is not more than that required for successful communication. PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 3 Integration Notes This module is authorized under limited module approval specific to mobile host equipment. The antenna must be installed with a 20 cm space maintained between the antenna and users. The transmitter module may not be co-located with any other transmitter or antenna. As long as the two conditions above are met, further transmitter testing will not be required. However, the OEM integrator is still responsible for testing their end product for any additional compliance requirements required with this module installed (for example, digital device emission, PC peripheral requirements, etc.) In the event that these conditions cannot be met (for example certain laptop configurations, general purpose PCMCIA or similar cards, or co-location with another transmitter) and obtaining a separate FCC authorization will be required, then the FCC authorization is no longer considered valid and the FCC ID cannot be used on the final product (including the transmitter). Changes or modifications to this device not explicitly approved by Lantronix will void the user's authority to operate this device. Note: With the purchase of any PremierWave 2050 family product, the OEM agrees to an OEM firmware license agreement that grants the OEM a non-exclusive, royalty-free firmware license to use and distribute the binary firmware image provided, only to the extent necessary to use the PremierWave 2050 hardware. For further details, please see the PremierWave 2050 OEM firmware license agreement. Note: Please refer to the PremierWave 2050 Enterprise Wi-Fi IoT Module Datasheet, available at www.lantronix.com/support/documentation, for the full compliance specification and requirements. Warranty For details on the Lantronix warranty policy, please go to our Web site at www.lantronix.com/support/warranty. Revision History Date Rev. Comments February 2016 A Initial document. May 2016 B Added the “Sample Solder Process Using 5 Mil Stencil” section. February 2017 C Updated the DEFAULT#, WAKE and SHDN signal descriptions. For the latest revision of this product document, please check our online documentation at www.lantronix.com/support/documentation. PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 4 Table of Contents Intellectual Property _________________________________________________________ Contacts __________________________________________________________________ Disclaimer ________________________________________________________________ Labeling of the End Product __________________________________________________ RSS-GEN Sections 7.1.4 and 7.1.5 Statement for Devices with Detachable Antennas ____ Integration Notes ___________________________________________________________ Warranty _________________________________________________________________ Revision History ____________________________________________________________ Table of Contents __________________________________________________________ List of Figures _____________________________________________________________ List of Tables ______________________________________________________________ 1: Introduction 2 2 2 3 3 4 4 4 5 6 7 8 About the Integration Guide___________________________________________________ 8 Additional Documentation ____________________________________________________ 9 2: Functional Description PremierWave 2050 Features_________________________________________________ PremierWave 2050 Block Diagram ____________________________________________ Signal Descriptions ________________________________________________________ Antenna Interface _________________________________________________________ Antenna Placement ________________________________________________________ Serial Interface ___________________________________________________________ Ethernet Interface _________________________________________________________ USB Device Port __________________________________________________________ USB Host Port ____________________________________________________________ LEDs ___________________________________________________________________ General Purpose I/O Pins ___________________________________________________ Reset Pins _______________________________________________________________ 3: PCB Footprint and Module Dimensions Access CAD Files _________________________________________________________ Reflow Profile Guideline ____________________________________________________ Sample Solder Process Using 5 Mil Stencil _____________________________________ 1. Introduction _________________________________________________________ 2. Scope _____________________________________________________________ 3. Assembly Process____________________________________________________ 4. Solder Paste and Stencil Design ________________________________________ 5. Solder Paste Printing _________________________________________________ PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 10 10 12 13 17 19 20 22 24 25 26 26 27 28 28 30 32 32 32 32 32 32 5 6. Component placement ________________________________________________ 7. Pre-Reflow Inspection _________________________________________________ 8. Reflow _____________________________________________________________ 9. Post Reflow Inspection ________________________________________________ MSD (Moisture Sensitive Device) Control for the Module ___________________________ Product Information Label ___________________________________________________ Evaluation Board Schematic _________________________________________________ 34 34 37 37 39 40 41 List of Figures Figure 2-1 PremierWave 2050 Dimensions and Views ____________________________ Figure 2-2 PremierWave 2050 Block Diagram ___________________________________ Figure 2-3 PremierWave 2050 Pin Locations ____________________________________ Figure 2-4 Reverse-SMA to U.FL (Long) (Lantronix Part Number 500-180-R-ACC)______ Figure 2-5 U.FL to U.FL Cable (Lantronix Part Number 500-181-R-ACC) _____________ Figure 2-6 Reverse-SMA to U.FL (short) (Lantronix Part Number 500-182-R-ACC)______ Figure 2-7 Module with Chip Antenna Board Edge Mounting _______________________ Figure 2-8 Serial Port Example ______________________________________________ Figure 2-9 Ethernet Connections to an External 10/100 RJ45 Magnetic Jack (J5) _______ Figure 2-10 USB Device Interface Example (PremierWave 2050 Wi-Fi only) ___________ Figure 2-11 USB Host Interface Connections ___________________________________ Figure 2-12 Recommended Use of SHDN Signal to Shut Off External Power Rail _______ Figure 3-1 PremierWave 2050 Module Dimensions_______________________________ Figure 3-2 PremierWave 2050 Recommended Footprint __________________________ Figure 3-3 Recommended Reflow Profile ______________________________________ Figure 3-4 SMT Process Flow ________________________________________________ Figure 3-5 SPI Rectangle Pad 2876.5 mm Inspection Result ________________________ Figure 3-6 SPI Square Pad 3850.7 mm Inspection Result __________________________ Figure 3-7 X-Ray Machine Pre-Reflow Inspection ________________________________ Figure 3-8 X-Ray Machine Post Reflow Inspection ________________________________ Figure 3-9 PremierWave 2050 Product Label ____________________________________ Figure 3-10 Evaluation Board Schematic (1 of 7) ________________________________ Figure 3-11 Evaluation Board Schematic (2 of 7) ________________________________ Figure 3-12 Evaluation Board Schematic (3 of 7) ________________________________ Figure 3-13 Evaluation Board Schematic (4 of 7) ________________________________ Figure 3-14 Evaluation Board Schematic (5 of 7) ________________________________ Figure 3-15 Evaluation Board Schematic (6 of 7) ________________________________ Figure 3-16 Evaluation Board Schematic (7 of 7) ________________________________ PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 11 12 16 18 18 18 19 21 23 24 25 27 28 29 31 32 33 34 35 37 40 41 42 43 44 45 46 47 6 List of Tables Table 1-1 PremierWave 2050 Integration Guide Sections ___________________________ 8 Table 2-1 PremierWave 2050 Part Numbers ____________________________________ 10 Table 2-2 PremierWave 2050 PCB Interface Signals _____________________________ 13 Table 2-3 PremierWave 2050 Wi-Fi On Module Antenna __________________________ 17 Table 2-4 PremierWave 2050 Wi-Fi External Antenna Options via On Module U.FL _____ 17 Table 2-5 PremierWave 2050 Serial Port Signals ________________________________ 20 Table 2-6 Example RS232 Connections (Serial Transceiver Required) _______________ 21 Table 2-7 Example RS422/485 Connections (Serial Transceiver Required) ____________ 22 Table 2-8 Ethernet Port Signals ______________________________________________ 23 Table 2-9 USB Device Port Signals ___________________________________________ 24 Table 2-10 USB Host Port Signals ____________________________________________ 25 Table 2-11 PremierWave 2050 Wi-Fi Status LED Output Signals ____________________ 26 Table 2-12 Ethernet Interface PremierWave 2050 Serial Port Signals ________________ 26 Table 2-13 PremierWave 2050 Reset Signals ___________________________________ 27 Table 3-1 Oven Setting _____________________________________________________ 37 PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 7 1: Introduction About the Integration Guide This user guide provides the information needed to integrate the Lantronix® PremierWave® 2050 family of products into customer-printed circuit boards. This manual is intended for engineers responsible for integrating the PremierWave 2050 enterprise Wi-Fi® IoT module into their product. This document provides instruction for connecting to the various module pin function groups as well as general module placement and mounting. For detailed technical and compliance specifications please refer to the PremierWave 2050 Enterprise Wi-Fi IoT Module Datasheet available at www.lantronix.com/support/documentation. The table below describes the integration guide sections. Table 1-1 PremierWave 2050 Integration Guide Sections Section Description PremierWave 2050 Features PremierWave 2050 Block Diagram Signal Descriptions Antenna Interface Antenna Placement Using the RF1 Signal Pin Provides an overview of the module functions and mechanical drawing Shows the module functional blocks Serial Interface Ethernet Interface USB Device Port USB Host Port LEDs General Purpose IO Pins Reset Pins Mounting Instructions and PCB Footprint Product Information Label Evaluation Board Schematic Provides signal descriptions and pinout information Lists the antennas pre-certified for use with the module Provides a general recommendation for antenna placement This section is reserved for a future off module antenna connection option Provides an example on how to connect the unit to external RS232/485/422 networks Gives an example on how to connect the module Ethernet Provides an example on how to connect the unit up as a USB device port Provides an example on how to connect the module USB host ports Describes the module LED connections Describes the module GPIO connections Describes the module RESET, DEFAULT, and WAKE pins Provides the module PCB footprint and solder profile Provides an image and description of the unit label contents Provides the PremierWave 2050 evaluation board schematic. PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 8 1: Introduction Additional Documentation Visit the Lantronix web site at www.lantronix.com/support/documentation for the latest documentation and the following additional documentation. Document Description PremierWave 2050 Enterprise Wi-Fi IoT Module Datasheet PremierWave 2050 Enterprise Wi-Fi IoT Module User Guide PremierWave 2050 Enterprise Wi-Fi IoT Module Evaluation Kit Quick Start Guide PremierWave 2050 Enterprise Wi-Fi IoT Module Evaluation Kit User Guide Notification Soldering Profile and Washing Provides a unit description and all technical and compliance specifications for the module Provides information needed to configure, use, and update the PremierWave 2050 firmware. Provides the steps for getting the PremierWave 2050 and PremierWave 2050 evaluation kit up and running. Provides a detailed description of the PremierWave 2050 evaluation kit hardware Provides guidance in developing a manufacturing assembly process for various Lantronix embedded products. PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 9 2: Functional Description Designed for quick integration with minimal engineering effort, the chip-sized PremierWave 2050 module provides simplicity and flexibility making it the easiest and fastest networkingenabling module on the market. PremierWave 2050 modules are extremely compact networking solutions that enable Ethernet or wireless connectivity on virtually any device with a serial interface. The included industryproven Lantronix module application and full IP stack allow seamless remote access to device data simplifying design integration while providing robust connectivity. The PremierWave 2050 modules can be utilized in designs typically intended for chip solutions. A key difference with the PremierWave 2050 module is that there is virtually no need to write a single line of code, translating to a much lower development cost and faster time-tomarket. Table 2-1 PremierWave 2050 Part Numbers Part Number Description PW205010001B PremierWave 2050, 802.11ac enterprise Wi-Fi module, dual U.FL, ind. temp, Bulk PW205020001B PremierWave 2050, 802.11ac enterprise Wi-Fi module, chip ant +U.FL, ind. temp, Bulk PW205010001S PremierWave 2050, 802.11ac enterprise Wi-Fi module, dual U.FL, ind. temp, Sample PW205020001S PremierWave 2050, 802.11ac enterprise Wi-Fi module, chip ant + U.FL, ind. temp, Sample PWGG2051000K PremierWave 2050 evaluation Kit, 802.11ac enterprise Wi-Fi module, dual U.FL PWGG2052000K PremierWave 2050 evaluation kit, 802.11ac enterprise Wi-Fi module, chip ant PremierWave 2050 Features The PremierWave 2050 module is built around a 400 Mhz ARM9 processor with 32 MB of DDR2 DRAM and 128 MB of embedded flash memory. Network connections are provided by a dual band 802.11 ac/b/g/n WLAN radio and 10/100Mbps Ethernet MAC and PHY. The PremierWave 2050 module also supports the following: ♦ 400 Mhz ARM9 CPU ♦ 32 MB DDR2 DRAM ♦ 128 MB NAND Flash ♦ 802.11 ac/bgn wireless with option for on module antenna or on module U.FL ♦ On module 10/100 Mbps Ethernet MAC/PHY. External magnetic and RJ45 required. ♦ One USB 2.0 high speed host/device interface. PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 10 2: Functional Description ♦ One USB 2.0 high speed host only port ♦ One USB 2.0 full speed host only port ♦ Two 3.3V serial interface ♦ 13 configurable I/O pins ♦ Power supply filters ♦ Reset circuit ♦ Integrated wake up and shutdown for sleep and standby states ♦ Interface for connection to an external JTAG software debugger. ♦ Dedicated two wire serial port for debug The PremierWave 2050 module requires +5V DC power and is designed to operate in an extended temperature range. (See the PremierWave 2050 Enterprise Wi-Fi IoT Module Datasheet available at www.lantronix.com/support/documentation for all technical specifications.) Figure 2-1 PremierWave 2050 Dimensions and Views PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 11 2: Functional Description PremierWave 2050 Block Diagram The following drawing is a block diagram of the PremierWave 2050 module showing the relationships of the components. Figure 2-2 PremierWave 2050 Block Diagram PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 12 2: Functional Description Signal Descriptions The PremierWave 2050 module has a serial interface compatible with data rates up to 921,600 bps. All of the logic IO pins are 3.3V tolerant. The serial signals usually connect to an internal device, such as a UART. For applications requiring an external cable running with RS-232 or RS422/485 voltage levels, the PremierWave 2050 must interface to a serial transceiver chip. An on-module 10/100 Mbps Ethernet MAC and PHY are included on the module. For connection to an external Ethernet network, external magnetics and an RJ45 are required. The module has options for an on-module chip antenna and an external antenna via an onmodule U.FL connection. Table 2-2 PremierWave 2050 PCB Interface Signals Signal Name PremierWave 2050 Pin # Primary Function RF1 2 Reserved for future use. Do not connect RF2 4 Reserved for future use. Do not connect CP3/MISO 12 Configurable GPIO / SPI master serial data input, SPI slave serial data output CP4/MOSI 13 Configurable GPIO / SPI master serial data output, SPI slave serial data input CP7/SCK 14 Configurable GPIO / SPI clock CP8/CS 15 Configurable GPIO, multiplexed with SPI interface chip select CP5 16 Configurable GPIO / I2C data 10K PU CP6 17 Configurable GPIO / I2C clock 10K PU USB1+/DDP 18 USB (Positive) USB high speed host/device port USB1-/DDM 19 USB (Negative) USB high speed host/device port USB2+ 21 USB (Positive) USB high speed host port USB2- 22 USB (Negative) USB high speed host port RTS2 24 UART2 serial ready to send output CTS2 25 UART2 clear to send input CP9 26 Configurable GPIO DBTX 27 Debug UART serial transmit data output PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide Reset State Internal Pull-up /Pulldown Driver Strength 13 2: Functional Description Signal Name PremierWave 2050 Pin # Primary Function DBRX 28 Debug UART serial receive data input ETXP (ETH1+) 34 Ethernet TX (Positive) Future Gbit pair 1 (pos) ETXM (ETH1-) 35 Ethernet TX (Negative) Future Gbit pair 1 (net) TXCT (ECT1)_ 37 Center tap connection for Ethernet TX pair RXCT (ECT2) 38 Center tap connection for Ethernet RX pair ERXP (ETH2+) 40 Ethernet RX (Positive) Future Gbit pair 2 (pos) ERXM (ETH2-) 41 Ethernet RX (Negative) Future Gbit pair 2 (neg) ETH3+ 43 Reserved for future Gbit Ethernet pair 3 (Positive) ETH3- 44 Reserved for future Gbit Ethernet pair 3 (Negative) ETH4+ 46 Reserved for future Gbit Ethernet pair 4 (Positive) ETH4- 47 Reserved for future Gbit Ethernet pair 4 (Negative) ECT3 49 Reserved for future Gbit center tap 3 connection ECT4 50 Reserved for future Gbit center tap 4 connection USB3+ 52 USB (Positive) USB full speed host port USB3- 53 USB (Negative) USB full speed host port SPEED_LED 56 Ethernet speed LED, active low for 100 Mbps CP13 57 Configurable GPIO CP12 58 Configurable GPIO CP11 59 Configurable GPIO CP10 60 Configurable GPIO WAKE 65 CPU wake up input. Module wakes from low power state on a rising edge DEFAULT# 66 Unit reset to default, active low. Drive low for xx seconds to reset unit to default settings. PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide Reset State Internal Pull-up /Pulldown Driver Strength 10K PU 100K PU 14 2: Functional Description Signal Name PremierWave 2050 Pin # Primary Function SYS_LED 67 System status LED, active high CP2/INT 68 Configurable GPIO / SPI interrupt external interrupt input CP1 71 Configurable GPIO LINK_ACT 72 Ethernet link/activity LED active low for link. toggle for activity. WLAN LED 73 LED function for WLAN link indication, active low RESET# 77 Unit hardware reset, active low. Drive low to reboot unit RXD2 78 UART2 serial receive data input TXD2 79 UART2 serial transmit data output CTS1 80 UART1 clear to send input RTS1 81 UART1 serial ready to send output RXD1 82 UART1 Serial receive data input TXD1 83 UART1 serial transmit data output SHDN 88 Indicates when module is in standby state. Use to power off external devices RF1_CTL 97 Reserved for future use. Do not connect TRST 100 TRST signal for external debugger TDO 101 TDO signal for external debugger TDI 104 TDI signal for external debugger TCK 105 TCK signal for external debugger TMS 106 TMS signal for external debugger VCC 29,30,31 5V power input GND 1,3,5,20,23,32, 33,36,39,42,45, 48,51,54,55,61, 64,84,86,87,94, 95,96,98,99,102, 103,107,108,109, Signal ground PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide Reset State Internal Pull-up /Pulldown Driver Strength 35K PU 15 2: Functional Description Signal Name PremierWave 2050 Pin # Primary Function Reset State Internal Pull-up /Pulldown Driver Strength 110,111,112,113, 114,115,116,117, 118,119,120,121, 122,123,124 RSVD 2,4,6,7,8,9,10,11, 43,44,46,47,49,50, 62,63,69,70,74, 75,76,85,89,90, 91,92,93, Reserved for future use. Leave disconnected. Note1: The current module supports 10/100 Mbps Ethernet. Additional pins have been called out for a future Gigabit Ethernet module. Note2: The logic IO pins are 3.3V tolerant. Note3: Pins 109 to 124 are the large ground pads under the module. These pads should be connected to ground. These pads also provide thermal relief for the module. It is recommended that multiple vias for each pad be used to connect the ground pads to the ground plane. Figure 2-3 PremierWave 2050 Pin Locations Note: Pins 109 to 124 are the large pads under the module. Pins 109 to 124 should be connected to GND. The pads in yellow are for future module revisions and should be left disconnected. PCB Strip Antenna Area 108 1 GND GND 2 RF1 3 GND 4 RF2 5 GND 6 SDCK 7 SDCMD 8 SDIO0 9 SDIO1 10 SDIO2 11 SDIO3 12 CP3/MISO 13 CP4/MOSI 14 CP7/SCK 15 CP8/CS 16 CP5/I2CDATA 17 CP6/I2CCLK 18 USB+ 19 USB20 GND 21 USB2+ 22 USB223 GND 24 RTS2 25 CTS2 26 CP9 27 DBTX 28 DBRX 29 VCC3 30 VCC3 31 VCC3 32 GND GND 33 107 GND 106 TMS 105 TCK 104 TDI 103 GND 102 GND 101 TDO 100 TRST GND 99 98 GND 97 RF1_CTL 96 GND 95 GND GND 94 93 VCC2 92 VCC2 91 VCC2 90 VCC2 89 VCC2 88 SHDN GND 87 ETH447 GND 48 ECT3 49 ECT4 50 GND 51 USB3+ 52 USB353 GND 54 Golden2050 GateModule PremierWave ETX+ 34 ETX35 GND 36 TXCT 37 RXCT 38 GND 39 ERX+ 40 ERX41 GND 42 ETH3+ 43 ETH344 GND 45 ETH4+ 46 PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide GND 86 RF3/GPS 85 GND 84 TXD1 83 RXD1 82 RTS1 81 CTS1 80 TXD2 79 RXD2 78 RESET# 77 VCC 76 VCC 75 VCC 74 LED0/LNK 73 LED1/ACT 72 CP1 71 SPARE1 70 SPARE2 69 CP2/INT 68 SYS_LED 67 DEFAULT# 66 WAKE 65 GND 64 ADC1 63 ADC2 62 GND 61 CP10/TXD3 60 CP11/RXD3 59 CP12/RTS3 58 CP13/CTS3 57 SPEED LED 56 GND 55 16 2: Functional Description Antenna Interface The PremierWave 2050 module has been certified using the external antennas listed below. Per FCC guidelines, the PremierWave 2050 Wi-Fi certification remains valid if using an antenna of similar type to the antennas below. If using an antenna of similar type to one of the antennas below, but from a different manufacturer part number the antenna gain must be equal to or less than specified in the table. Refer to the PremierWave 2050 Enterprise Wi-Fi IoT Module Datasheet, available at www.lantronix.com/support/documentation, for full compliance instructions and information. Consult with your certification lab for more details. Table 2-3 PremierWave 2050 Wi-Fi On Module Antenna Antenna Type Peak Gain Typical Lantronix Part Number Vendor Vendor Part Number Approved Region Ceramic Antenna 2.17dBi, 2.4 GHz to 2.5 GHz 2.74 dBi, 4.9 GHz to 5.8 GHz N/A N/A N/A FCC, IC, EU, AUS/NZS, JPN, China, Mexico Table 2-4 PremierWave 2050 Wi-Fi External Antenna Options via On Module U.FL Antenna Type Peak Gain Typical Lantronix Part Number Vendor Vendor Part Number Approved Region PCB Strip Antenna with 50 mm cable to U.FL connector With tape backing PCB Strip Antenna with 50 mm cable to U.FL connector Without tape backing Swivel type antenna, with RPSMA(M) connector 2.5dBi, 2.39 GHz to 2.49 GHz 5 dBi, 4.9 GHz to 5.9 GHz 2.5dBi, 2.39 GHz to 2.49 GHz 5dBi, 4.9Ghz to 5.9Ghz XPW100A003 -01-B 50 piece bulk pack Ethertronics® 1001077 Ethertronics 1000668 FCC, IC, EU, AUS/NZS, JPN, China, Mexico FCC, IC, EU, AUS/NZS, JPN, China, Mexico 2 dBi, 2.4 GHz to 2.5 GHz, 2 dBi, 5.15 GHz to 5.85 GHz 3.8 dBi, 2.4Ghz to 2.5Ghz, 5.5 dBi, 4.9 GHz to 5.8Ghz 930-033-RACC 50 piece bulk pack Wanshih WSS002 Taoglas GW.71.5153 (Not for EU use) Swivel type antenna, with RPSMA(M) connector FCC, IC, EU, AUS/NZS, JPN, China, Mexico FCC, IC, AUS/NZS, JPN, China, Mexico Note: The PCB strip antenna is available from Ethertronics with or without adhesive tape backing for mounting to a plastic case. The antennas Lantronix supplies include an adhesive backing. For the component without tape backing a non-conductive double sided adhesive tape can be used to fix the antenna in place. The Ethertronics part numbers listed above come with a 50 mm U.FL cable attached to the PCB strip antenna. The 50 mm cable length is the minimum allowed cable length for use with the PremierWave 2050 module. For similar PCB strip antennas with longer cables consult with Ethertronics (www.ethertronics.com). Lantronix provides a U.FL to Reverse SMA antenna cable in with the evaluation board and sample kits for development work. These cables can be purchased from Lantronix for production or supplied by an RF cable manufacturer. External antennas can be purchased from an antenna vendor. Components for cable design should be selected for low loss over the entire 2.4 GHz to 5.9 GHz signal range. The cable target impedance should be 50 ohms. PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 17 2: Functional Description Figure 2-4 Reverse-SMA to U.FL (Long) (Lantronix Part Number 500-180-R-ACC) Figure 2-5 U.FL to U.FL Cable (Lantronix Part Number 500-181-R-ACC) Figure 2-6 Reverse-SMA to U.FL (short) (Lantronix Part Number 500-182-R-ACC) PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 18 2: Functional Description Antenna Placement When designing the PremierWave 2050 module to a mating board, it is important to consider the final installation of the module and its location with respect to connecting access points. The antenna should be placed so that it has as clear as possible path to the connecting access point for maximum range. Avoid placing the antenna such that it is blocked by metal walls or ground planes of adjacent circuit boards. When using the on board chip antenna it is recommended to place the module such that the antenna region is along the edge of the board or extending outward from the edge of the board. The area under the chip antenna region should be voided of all signals and planes See the figure images below showing recommended placement with the module chip antenna. Figure 2-7 Module with Chip Antenna Board Edge Mounting Void region in red 6mmx23mm Edge of PCB Example PCB Placement Note: The chip antenna region of the module shown in red above is at the top edge of the PCB. The area in red should be voided to optimize antenna performance. PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 19 2: Functional Description Serial Interface The PremierWave 2050 modules has two external serial interfaces. The signal levels on the serial interface are 3.3V tolerant. The serial interfaces require an external transceiver in order to connect to external RS232, RS485, or RS422 networks. The signals of the Serial Ports may be connected as shown in the reference schematic below. The transceiver shown in the reference schematic is of type Exar, part number SP336. This transceiver is a multiprotocol RS232, RS485, RS422 transceiver. Single protocol transceivers may be used as required. The PremierWave 2050 interface may also be directly connected to the UART interface of an external CPU. Table 2-5 PremierWave 2050 Serial Port Signals Signal Module Pin Description TXD1 83 Serial transmit data output RTS1 81 Serial ready-to-send / serial transmit enable output RXD1 82 Serial receive data input CTS1 80 Serial clear-to-send input TXD2 79 Serial transmit data output 2 RTS2 24 Serial ready-to-send / serial transmit enable output RXD2 78 Serial receive data input 2 CTS2 25 Serial clear-to-send input PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 20 2: Functional Description Figure 2-8 Serial Port Example Table 2-6 Example RS232 Connections (Serial Transceiver Required) PremierWave 2050 Signal DTE Connector DCE Connector Signal (Logic) RXDx TXDx RTSx CTSx CPx CPy DB9 2 3 7 8 1 4 DB9 3 2 8 7 4 1 Description Data In Data Out H/W Flow Control Output H/W Flow Control Input Modem Control Input Modem Control Output DB25 3 2 4 5 8 20 Signal RXDx TXDx RTSx CTSx DCDx DTRx PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide DB25 2 3 5 4 20 8 Signal TXDx RXDx CTSx RTSx DTRx DCDx 21 2: Functional Description Table 2-7 Example RS422/485 Connections (Serial Transceiver Required) PremierWave 2050 Signal (logic) Description RS485 Signal DB25 4 Wire DB25 2 Wire DB9 4 wire DB9 2 wire TXDx TXDx RXDx RXDx RTSx CPx CPy Data Out Data Out Data In Data In TX Enable RS485 Select RS485 2-wire TX+485 TX-485 RX+485 RX-485 14 15 21 22 14 15 14 15 7 3 2 8 7 3 7 3 Note: The IO pins for PremierWave 2050 module are set to floating input on power up until configured by unit firmware. An external 100K ohm pull-up may be required on the serial transmit signal to prevent downstream UART devices from detecting false characters on initial power up. Ethernet Interface The unit provides a 10/100 Mbps Ethernet interface for connection to an external network through external magnetics and an external RJ45. The figure below shows the Ethernet connections to a 10/100 Ethernet RJ45 Jack with Magnetics, J5 in the figure. The RJ45 Magnetic Jack is Belfuse part number 08B0-1D1T-06-F. The Ethernet differential pair signals, ERXM/ERXP and ETXM/ETXP should be routed as 100ohm differential pairs on a layer next to the signal ground plane. The use of vias on these signals should be minimized. Center tap signals RXCT and TXCT should be routed with at least 20 mil trace thickness. The area underneath the RJ45 magnetic jack should be void of all signals and planes. The connector shield should be connected to chassis. It is recommended that 1206 resistor pads from chassis ground to signal ground be placed next to each of the shield tabs. The resistor pads allow for 0 ohm jumper, ferrite beads, or decoupling caps to be installed as needed for EMI/EMC improvement. The Ethernet LED signals should be routed to discrete LEDs or to the LED pins on the RJ45 through 220 ohm or larger resistors. The LED signals are active low. Also shown in the figure is an optional active choke that can be used to improve ESD, EFT, and EMI/EMC performance in harsh environments. The device is shown as U22 in the figure and is Akros part number AS1602. This device features route through pin assignments allowing for the Ethernet differential signal pairs to be routed without altering the trace impedance or adding vias. Due to this routing the device could be installed or depopulated as needed. Lantronix has performed all certification to FCC Class B without U22 populated. The Ethernet signals may be left disconnected if unused. See the Lantronix app note, How to Connect a Lantronix Embedded Module to a Wired Ethernet Port for more details on Ethernet connection and routing, http://www.lantronix.com/pdf/appnotes/Connect-LTRX-Embed-Module-to-WiredEthernet_AN.pdf. PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 22 2: Functional Description Table 2-8 Ethernet Port Signals Pin Name Description PremierWave 2050 Pins Signal Requirement RJ45 MagJack Belfuse, 08B0-1D1T06-F Pin assignment ERXM Ethernet Receive Negative signal. 41 5 EXRP Ethernet Receive Positive signal. 40 ETXM Ethernet Transmit Negative signal. Ethernet Transmit Positive signal. 35 RXCT TXCT Chassis E_LNKACT Center tap for receive pair. Center tap for transmit pair Unit chassis Link / activity LED. Active low. Solid for link, blink for activity. 38 37 72 E_SPEED Link Speed Active low for 100Mbps, Off (high) for 10Mbps. 56 3V3 3.3 V power 3V3 100 ohm differential pair with ERXP 100 ohm differential pair with ERXM 100 ohm differential pair with ETXP 100 ohm differential pair with ETXM Route > 20 mil width Route > 20 mil width RJ45 connector shield Route to LED cathode through 220 ohm or greater. Route to LED cathode through 220 ohm or greater. 3.3V power, connect to LED anodes. ETXP 34 4 3 2 6 1 Shield tabs 9 7 8, 10 Figure 2-9 Ethernet Connections to an External 10/100 RJ45 Magnetic Jack (J5) PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 23 2: Functional Description USB Device Port The PremierWave 2050 module has one USB 2.0 device port interface for connection to an upstream USB device. The port consists of a differential pair, signals DDP and DDM. These signals should be routed as a 90 ohm differential pair on a signal layer next to the signal ground plane. The use of vias should be minimized on these signals. The USB signals can be connected to a USB Mini Type B USB port or directly to an IC with a USB host port. If connecting to an external port that is user accessible it is recommended to add a TVS diode array to the signal nets for ESD protection. The ESD array shown in the figure is of type SEMTECH RCIamp0502A. This device features through pin routing to minimize trace impedance changes and simplify routing. The footprint for the TVS array can be added to the PCB and the part can be depopulated if it is not needed. It is recommended that the power drawn off the USB Mini Type B connector be limited to less than 500 mA per USB requirements. If the USB device port is unused the DDP and DDM pins may be left disconnected. Table 2-9 USB Device Port Signals Pin Name Description Module Pins Signal Requirement Mini Type B USB Device Connector Pin USB+/DDP USB Device Port Positive pin 18 3 USB-/DDM USB Device Port Negative pin 19 5V 5V power from USB cable Signal Ground Route as 90 ohm differential pair with DDM signal Route as 90 ohm differential pair with DDP signal Current limit to 500 mA per port Ground plane Ground Ground 2 1 5 Figure 2-10 USB Device Interface Example (PremierWave 2050 Wi-Fi only) PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 24 2: Functional Description USB Host Port The PremierWave 2050 module has two USB 2.0 host port interfaces for connection to downstream USB devices. Each port consists of a differential pair. Port USB 2 is a high speed port and port USB 3 is a full speed port. These signals should be routed as 90 ohm differential pairs on a signal layer next to the signal ground plane. The use of vias should be minimized on these signals. The USB signals can be connected to a USB type A dual USB port as shown in the figure below or directly to an IC with a USB device port. If connecting to an external port that is user accessible it is recommended to add a TVS diode array to the signal nets for ESD protection. The ESD array shown in the figure is of type NXP, IP4234CZ6. If connecting to an off board device that needs power add a USB power switch to current limit the 5V power connection at the connector. USB requires that each port be limited to 500 mA maximum sustained current. If using the USB host ports the end system must take into account the amount of power consumed by the PremierWave 2050 module and each USB device connected to the host ports. The schematic below shows how to connect 5V to a USB host connector using an ST, STMPS2151 power distribution switch. The USB host port 5V power is not provided by the PremierWave 2050 module. If the USB host ports are unused their pins may be left disconnected. Table 2-10 USB Host Port Signals Pin Name Description PremierWave 2050 Pins Signal Requirement Type A USB Host connector pin USB2+/HHSDPB USB HS Host Port A Positive pin USB HS Host Port A Negative pin USB FS Host Port B Positive pin USB FS Host Port B Negative pin 5V power for USB connector Signal Ground 21 Route as 90 ohm differential pair Route as 90 ohm differential pair Route as 90 ohm differential pair Route as 90 ohm differential pair Current limit to 500 mA per port Ground plane B3 USB2-/HHSDPM USB3+/HFSDPC USB3-/HFSDMC 5V(User supplied) Ground 22 52 53 Ground B2 A3 A2 A1, B1 A4, B4 Figure 2-11 USB Host Interface Connections PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 25 2: Functional Description LEDs The PremierWave 2050 module contains several external signals that are intended to drive external status LEDs. The LEDs are listed below. The signals may be connected as shown in the reference schematic figure below. Note: The System LED usually remains on. When the Default button is pressed for 5-6 seconds, the System LED starts blinking every second to indicate the default button can be released to complete resetting the unit to factory default. The unit reboots after release of the Default button. A lit WLAN LED indicates the STA interface is associated with an access point. Table 2-11 PremierWave 2050 Wi-Fi Status LED Output Signals Signal Pin Description WI-FI LED 73 Wi-Fi Status LED, active low SYS_LED 67 System status LED, active high ETH SPEED 56 Ethernet 100Mbps ON (Active low), 10Mbps OFF ETH LINK/ACT 72 Ethernet link ON (Active low) Ethernet activity Blink (toggle) General Purpose I/O Pins PremierWave 2050 module contains 13 pins which may be used as configurable inputs or outputs. Listed below are the configurable I/O pins. These pins are 3.3V tolerant. Table 2-12 Ethernet Interface PremierWave 2050 Serial Port Signals Signal Pin Description PremierWave 2050 Reset State CP1 71 Configurable I/O Input CP2/INT 68 Configurable I/O-SPI interrupt input Input CP3 12 Configurable I/O- SPI MISO Input CP4 13 Configurable I/O-SPI MOSI Input CP5 16 Configurable I/O Input CP6 17 Configurable I/O Input CP7 14 Configurable I/O-SPI Clock Input CP8 15 Configurable I/O-SPI Chip Select Input CP9 26 Configurable I/O Input CP10 60 Configurable I/O Input CP11 59 Configurable I/O Input CP12 58 Configurable I/O Input CP13 57 Configurable I/O Input PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 26 2: Functional Description Reset Pins PremierWave 2050 modules have two signals for use as reset signals. Signal EXT_RESET# is a hardware controlled input signal that will reboot the PremierWave 2050 processor when asserted low. Signal DEFAULT# is polled by the PremierWave 2050 software. When DEFAULT# is asserted low for six seconds, the unit will reset the system to the default manufacturing settings and reboot the unit. PremierWave 2050 has an additional signal that can be used to wake up the unit processor when the unit is in a sleep or power down state. The SHDN signal is active when the module is in the shutdown state. Use the SHDN signal to gate off external logic when the module is in the shutdown state to minimize power Table 2-13 PremierWave 2050 Reset Signals Signal Pin Description Reset State EXT_RESET# 77 Unit hardware reset, active low. Drive low for 50ms to reboot unit. Signal should be driven high or left floating after reset. Input DEFAULT# 66 Unit reset to default, active low. Drive low for 6 seconds or longer to reset unit to default settings. Input WAKE 65 CPU wake up input. Module wakes from low power state on a rising edge. Refer to user guide for WAKE pin configuration options. Input SHDN 88 Indicates when module is in Standby state. Use to power off external devices. See evaluation board schematic for recommended connections. Figure 2-12 Recommended Use of SHDN Signal to Shut Off External Power Rail PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 27 3: PCB Footprint and Module Dimensions The module recommended footprint is shown below. The antenna region should ideally be placed on the edge of the board. The area under the antenna region should be void of all signals and planes. The antenna location inside of the end unit and installation should be chosen such that the antenna has as clear as possible line of site to the connecting WLAN devices. The antenna path should be as clear as possible from metal, ground and power planes from adjacent PCBs and other objects that can interfere with the signal path to the connecting WLAN devices. Access CAD Files 1. Go to http://www.lantronix.com/products/cad-visio.html. 2. Click Download CAD files here to access the Registration Form. Figure 3-1 PremierWave 2050 Module Dimensions PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 28 3: PCB Footprint and Module Dimensions Figure 3-2 PremierWave 2050 Recommended Footprint The pads on the PremierWave 2050 module are pre-bumped with solder. Lantronix recommends using non-solder-mask defined pads (NSMD). Lantronix recommends using ENIG finish for the PremierWave 2050 module pads. The internal ground pads are used for module signal ground and thermal relief. The outer layers should be flooded with ground and the ground pads should have many vias to the internal ground layers. Soldering coverage should be maximized and checked via x-ray for proper design. There is a trade-off between providing enough soldering for conductivity and applying too much, which allows the module to “float” on the pads creating reliability issues. Lantronix recommends 80% or more full contact solder coverage on each of the internal ground pads after reflow. PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 29 3: PCB Footprint and Module Dimensions Note: The recommended stencil thickness is 4-5 mil. The stencil aperture should not exceed the size of the pad. Solder volume must be controlled. It is recommended that the aperture be set to 1:0.8 of the pad size. For example, the 0.8x0.6 mm pad would use a 0.64x0.48 mm stencil. Thicker stencils will require further reduction in stencil aperture. First article and routine inspection of the printing quality is necessary to ensure high yield. At a minimum, visually inspect the unit utilizing a magnifier with 10x magnification; otherwise inspection with a solder paste inspection (SPI) machine is preferred. Lantronix recommends a final standoff height after reflow of 75 to 100 um. Reflow Profile Guideline The reflow profile is dependent on many factors including flux selection, solder composition, and the capability of the user's reflow equipment. Lantronix does not recommend a specific reflow profile but provides the following general guidelines: ♦ The solder composition typically sets the peak temperatures of the profile. ♦ Lantronix recommends lead free solder pastes SAC305: Type 4. Water soluble or noclean solder pastes are acceptable. ♦ Reflow equipment is needed at nine heater zones at minimum. Lantronix recommends a forced air type reflow oven with nitrogen. ♦ Lantronix recommends that the peak temperature at the solder joint be within 235°C ~ 245°C, and the maximum component temperature should not exceed 260°C. ♦ Lantronix recommends that the solder joint heating time above 217°C last between 40-90 seconds, and at a minimum of 40 seconds. ♦ Excessive ramp/cooling rates (>3°C/s) should be avoided. ♦ To develop the reflow profile, Lantronix recommends that the user place thermocouples at various locations on the assembly to confirm that all locations meet the profile requirements. The critical locations are the module solder joints. ♦ When developing the reflow profile, Lantronix recommends that a fully loaded assembly be used to assure that the total thermal mass is accounted for. PremierWave® 2050 Enterprise Wi-Fi® IoT Module Integration Guide 30 3: PCB Footprint and Module Dimensions Figure 3-3 Recommended Reflow Profile (1) Solder paste alloy: SAC305(Sn96.5/Ag3.0/Cu0.5)(Lead free solder paste is recommended by Lantronix.) (2) A-B. Temp.(Pre-heat): 150~200 °C; soak time:60~120 seconds. (3) C. Peak temp:
ACC-930-033-R 价格&库存
很抱歉,暂时无法提供与“ACC-930-033-R”相匹配的价格&库存,您可以联系我们找货
