AP1286S
AP1286S
    RFIC(朗弗)
    QFN16_3X3MM_EP
    2.4到2.5 GHZ ISM频段射频前端模块
AP1286S 数据手册
AP1286S RFIC Technology Corporation 2.4 to 2.5 GHz RF FEM www.rfintc.com RFIC 2019.05 Update Rev1.2 Tx: The AP1286S is a linear, low current consumption RF Front-End Module (FEM) which consists of power amplifier, low noise amplifier and two T/R switches for ISM band wireless application. It offers highly integrated Input / Output matching on chip to reduce the bill of material. This RF FEM is developed for portable product of ISM band, and compact device or embedded module application of IoT with stable and outstanding performance. AP1286S is housed in a 3 x 3 (mm), 16-pin, QFN leadless package, a high performance FEM. • Low current : 37mA for 10dBm 3.3V FSK application 75mA for 18dBm 3.3V FSK application 91mA for 20dBm 3.3V FSK application Rx: • Low current : 13mA for 3.3V application • Low Noise Figure : 2dB Pin Details Pin Number Major Applications Description Name 1 NC No-used pin • 2.4 GHz ISM Band portable device 2 GND Connected to ground • 2.4 GHz IoT Gateway device 3 GND Connected to ground 4 TX/RX RF signal from/to transceiver 5 TX_EN Control signal input for TX path enable 6 RX_EN Control signal input for RX path enable 7 NC No-used pin 8 GND Connected to ground 9 GND Connected to ground 10 ANT Antenna connection pin 11 GND Connected to ground 12 GND Connected to ground 13 FL Keep Floating 14 VDD_TX Supply voltage connection pin for TX 15 NC No-used pin 16 VDD_C Supply voltage connection pin for TX/RX 17 Center GND IC center pad connected to ground • RF4CE application Pin Assignment VDD_C NC VDD_TX FL 16 NC 15 14 13 12 NC 1 PA GND 2 GND 3 11 GND 10 ANT LNA TX/RX 9 GND 4 5 6 7 TX_ENRX_EN NC 8 GND QFN-16pin, 3x3 (mm) For more information,please contact us at: © 2006 RFIC Technology Corporation All rights reserved. Sales Dept. Tel: +886-2-2698-1022 e-mail: sales@rfintc.com RFIC Technology Corp. reserved the right to make any changes to the specifications without notice. 1 of 7 AP1286S • 802.15 PANs extended range device AP1286S RFIC Technology Corporation 2.4 to 2.5 GHz RF FEM www.rfintc.com RFIC 2019.05 Update Rev1.2 Tx Electrical Characteristics for general ISM band application VDD_C = VDD_TXTX_EN = 3.3V; RX_EN = 0V; CW signal; TA = 25C; unless otherwise noted. Specification Parameter Min Freq Typ. 2.4 Max 2.5 Units GHz Input return loss 10 dB Output return loss 5.5 dB P1dB 20.5 dBm Saturation Power Notes 22 dBm 26 dB Small Signal Gain 23 PAE 35 % nd 2 Harmonics -23 dBm/MHz @ Pout = 20dBm 3rdHarmonics -22 dBm/MHz @ Pout = 20dBm Iref 0.25 mA @ Pout = P1dB 91 mA @ Pout = 20dBm Current Consumption @ Pout = P1dB 75 @ Pout = 18dBm 56 @ Pout = 15dBm 37 @ Pout = 10dBm Rx Electrical Characteristics for general ISM band application VDD_C = RX_EN = 3.3V; TX_EN = 0V; CW signal; TA = 25C; unless otherwise noted. Specification Parameter Min Freq Typ. 2.4 Max 2.5 Units Notes GHz 13 dB Noise Figure 2 dB Current Consumption 12 mA Input Return Loss 5 dB Output Return Loss 9 dB OP1dB 7 dBm AP1286S Small Signal Gain Caution: ESD Sensitive Appropriate precaution in handling, packaging And testing devices must be observed. For more information,please contact us at: © 2006 RFIC Technology Corporation All rights reserved. Sales Dept. Tel: +886-2-2698-1022 e-mail: sales@rfintc.com RFIC Technology Corp. reserved the right to make any changes to the specifications without notice. 2 of 7 AP1286S RFIC Technology Corporation 2.4 to 2.5 GHz RF FEM www.rfintc.com RFIC 2019.05 Update Rev1.2 Absolute Maximum Ratings Logic Control Table Parameter Rating Unit TX_EN RX_EN State DC Power Supply For Drain +4 V 1 0 TX Active DC Supply Current For Drain 300 mA 0 1 RX Active RF Input Power +5 dBm Operating Ambient Temperature -40~85 ˚C “1” = +3V to +3.3V Storage Temperature -40~125 ˚C “0” = +0V to +0.2V ESD (HBM, JESD22-A114, all pins) 300 V Moisture Sensitivity MSL3 Note: ISM Band General Application Reference Circuit R1 value is 24k ohm~16k ohm For more information,please contact us at: © 2006 RFIC Technology Corporation All rights reserved. Sales Dept. Tel: +886-2-2698-1022 e-mail: sales@rfintc.com RFIC Technology Corp. reserved the right to make any changes to the specifications without notice. 3 of 7 AP1286S Note: Pin13 has to be NC. AP1286S RFIC Technology Corporation 2.4 to 2.5 GHz RF FEM www.rfintc.com RFIC 2019.05 Update Rev1.2 Suggested PCB Layout I/O Pin, Central PAD Layout Thermal PAD Via Design Zx 0.7 mm Gx 0.7 mm Sx . Sy Gy Zy θ 0.3mm Y P X PCB Footprint Dimension (mm) P X Y Sx Sy Gx Gy Zx Zy 0.5 0.3 0.85 1.5 1.5 2.1 2.1 3.8 3.8 AP1286S For more information,please contact us at: © 2006 RFIC Technology Corporation All rights reserved. Sales Dept. Tel: +886-2-2698-1022 e-mail: sales@rfintc.com RFIC Technology Corp. reserved the right to make any changes to the specifications without notice. 4 of 7 AP1286S RFIC Technology Corporation 2.4 to 2.5 GHz RF FEM www.rfintc.com RFIC 2019.05 Update Rev1.2 Package Outline Top View Bottom View 3.00 + 0.1 1.50 0.40 MARKING 1.50 0.23 T YP. 0.23 TYP. 0.5 TYP. 3.00 + 0.1 0.40 0.5 TYP. Unit: mm 0.75 MAX. 0.25 0.50 0.0 ~ 0.05 Side View C SEATING PLANE AP1286S Note: 1. Dimension and tolerance conform to ASME Y14.5M-1994. 2. Refer to JEDEC STD. MO-220 WEED-2 ISSUE B For more information,please contact us at: © 2006 RFIC Technology Corporation All rights reserved. Sales Dept. Tel: +886-2-2698-1022 e-mail: sales@rfintc.com RFIC Technology Corp. reserved the right to make any changes to the specifications without notice. 5 of 7 RFIC Technology Corporation AP1286S 2.4 to 2.5 GHz RF FEM www.rfintc.com RFIC 2019.05 Update Rev1.2 Recommended Solder Reflow Profile AP1286S For more information,please contact us at: © 2006 RFIC Technology Corporation All rights reserved. Sales Dept. Tel: +886-2-2698-1022 e-mail: sales@rfintc.com RFIC Technology Corp. reserved the right to make any changes to the specifications without notice. 6 of 7 RFIC Technology Corporation AP1286S 2.4 to 2.5 GHz RF FEM www.rfintc.com RFIC 2019.05 Update Rev1.2 The product is designed and manufactured for consumer application only and is not intended for any application listed below which requires especially high reliability for the prevention of such defect which could lead to personal injury, death, physical or environmental damage.  Aircraft equipment.  Aerospace equipment.  Undersea equipment.  Medical equipment.  Life-saving or life-sustaining applications  Transportation equipment (vehicles, trains, ships, etc.).  Traffic signal equipment.  Disaster prevention / crime prevention equipment.  Application of similar complexity and/ or reliability requirements to the applications listed in the above. AP1286S For more information,please contact us at: © 2006 RFIC Technology Corporation All rights reserved. Sales Dept. Tel: +886-2-2698-1022 e-mail: sales@rfintc.com RFIC Technology Corp. reserved the right to make any changes to the specifications without notice. 7 of 7
AP1286S 价格&库存
很抱歉,暂时无法提供与“AP1286S”相匹配的价格&库存,您可以联系我们找货
