AP1076
AP1076
    RFIC(朗弗)
    QFN-16-EP(3x3)
    2.4~2.5GHZ高功率放大器
AP1076 数据手册
AP1076 RFIC Technology Corporation 2.4~2.5 GHz High Power Amplifier www.rfintc.com RFIC Preliminary 2018.01 Rev3.0 KEY FEATURES DESCRIPTION The AP1076 is a 2.4~ 2.5 GHz linear power amplifier MMIC (Microwave Monolithic Integrated Circuit) fabricated with InGaP HBT process. Input match and a power detector are incorporated on-chip for ease of use, while external output match is used to provide the flexibility the users with the flexibility in system optimization. The device is intended for use in WLAN IEEE802.11b/g/n/ac applications. It also serves as a general purpose PA solution for ISM band wireless systems requiring high power and/or high linearity. 5V Condition Performance • Quiescent Current 270mA • High Linearity: 26dBm @ EVM = 3 %, with 64QAM OFDM • High PAE: 17% @ 26dBm The AP1076 is provided in a 3x3 mm, 16 pin QFN (Quad Flat No-leads) package. l a i t n • High Gain: 32dB Power Gain Major Applications Pin Details Name 1 RF IN 2 EN 3 GND 4 VCC_BIAS 5 GND Ground. 6 GND Ground. 7 DET Detector output voltage. VCC2 8 NC 13 9 GND 10 RF OUT RF output 11 RF OUT RF output 12 GND Ground. 13 VCC2 PA 2nd stage supply voltage. 14 NC 15 VCC1 PA 1st stage supply voltage. 16 GND Ground. Pkg Base Center Metal C I F Pin Assignment R 16 VCC1 15 NC 14 o C 1 12 GND EN 2 11 RF OUT GND 3 10 RF OUT 4 9 5 GND 6 7 GND DET 8 NC GND Description RF input. Power Amplifier Enable Ground. Supply voltage for bias circuit. No connection Ground. No connection The package ground provides circuit ground as well as heat dissipation path for the power amplifier. QFN-16pin, 3x3 (mm) For more information,please contact us at: © 2006 RFIC Technology Corporation All rights reserved. Sales Dept. Tel: +886-2-2698-1022 e-mail: sales@rfintc.com RFIC Technology Corp. reserved the right to make any changes to the specifications without notice. 1 of 7 AP1076 RF IN VCC_BIAS e d i f n Pin Number • IEEE 802.11b/g/n • IEEE 802.11ac 256QAM • 2.4 GHz ISM Band Application • Suitable for high power WLAN applications • High power WLAN AP Router applications • Portable/ Embedded RF module GND • On Chip Detector AP1076 RFIC Technology Corporation 2.4~2.5 GHz High Power Amplifier www.rfintc.com RFIC Preliminary 2018.01 Rev3.0 Electrical Characteristics (VCC = 5V, Vref = 1.8V, TA = 25℃ as Measured on the Evaluation Board , Unless Otherwise Noted) Specification Parameter Min Typ. Units Max Notes Frequency 2.4 2.5 GHz Input return loss 15 20 dB ︱S11| Output return loss 10 15 dB ︱S22| OP1dB 33 dBm Power Gain 30 32 34 dB Linear Power 23 23.5 18 24 dBm Harmonics 26 28 27 29 28 -55 -50 -50 -47 Iref o C 1 Idle current 260 C I F Current Consumption R Gain flatness PAE 360 300 450 280 400 360 510 1 11.2 15.6 Detector output 12.4 17.7 1.5 MCS8, HT40, 1.8% EVM MCS8, HT40, 1.25% EVM MCS7, HT20, 3% EVM MCS0, HT20, mask MCS0, HT40, mask e d i f n 27 -42 -42 l a i t n CW signal dBm/ MHz mA 2fo @ 29dBm, CCK signal, BT = 0.045 3fo @ 29dBm, CCK signal, BT = 0.045 @ Idle current mA mA @ 23.5 dBm, MCS8, HT40, 1.8% EVM @ 18 dBm, MCS8, HT40, 1.25% EVM @ 26 dBm, MCS7, HT20, 3% EVM dB 100MHz bandwidth % @ 23.5 dBm, MCS8, HT40, 1.8% EVM @ 26 dBm, MCS7, HT20, 3% EVM V @ 26dBm, OFDM signal, MCS7, HT20 mode Note 1: Performance is guaranteed only under the conditions listed in this Table. AP1076 For more information,please contact us at: © 2006 RFIC Technology Corporation All rights reserved. Sales Dept. Tel: +886-2-2698-1022 e-mail: sales@rfintc.com RFIC Technology Corp. reserved the right to make any changes to the specifications without notice. 2 of 7 AP1076 RFIC Technology Corporation 2.4~2.5 GHz High Power Amplifier www.rfintc.com RFIC Preliminary 2018.01 Rev3.0 Electrical Characteristics Charts Vcc = 5V Current Consumption vs. Output Power Gain vs. Output Power 40 600 2.4GHz 2.5GHz 39 2.4GHz 2.5GHz 550 l a i t n Current Consumption (mA) 38 37 Gain (dB) 36 35 34 450 400 350 e d i f n 33 32 300 250 31 200 30 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 Output Power (dBm) R 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 0 C I F 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 Output Power (dBm) o C PAE vs. Output Power 8.0 2.4GHz 2.5GHz 7.5 7.0 PA EVM vs. Output Power 2.4GHz 2.5GHz 6.5 6.0 5.5 PA EVM (%) PAE (%) 500 5.0 4.5 4.0 3.5 3.0 2.5 2.0 1.0 0.5 0.0 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 Output Power (dBm) Output Power (dBm) For more information,please contact us at: © 2006 RFIC Technology Corporation All rights reserved. Sales Dept. Tel: +886-2-2698-1022 e-mail: sales@rfintc.com RFIC Technology Corp. reserved the right to make any changes to the specifications without notice. 3 of 7 AP1076 1.5 AP1076 RFIC Technology Corporation 2.4~2.5 GHz High Power Amplifier www.rfintc.com RFIC Preliminary 2018.01 Rev3.0 AP1076 Evaluation Board Schematic Diagram for 5V Application Vcc(5 V) C1 4.7uF C6 1 uF C2 1 uF C4 1uF l a i t n C3 100nF C7 1.1pF C5 1 .1 pF TL1 TL2 L1 3.9nH Size: 0603 Toko 16 J1 15 14 1 12 2 11 3 10 RF_ IN R1 130 ohm 5 C8 4 .7 nF 6 C I F C9 47nF R2 100 ohm R TL3 o C 9 4 e d i f n 13 7 C11 3 .3 pF TL4 C 12 2 .2 pF TL5 C 13 0 .3 pF C14 20 pF TL6 L2 2.2nH J2 RF _ OUT C 15 2.4pF C16 1.3pF 8 C 10 22pF Vbias (5 V) R3 9.1 kohm Det Vref(1.8V ) Physical Length (mm) Length Measurement TL1 0.78 IC edge to C7 center TL2 0.78 IC edge to C5 center TL3 1.35 C11 center to C12 center TL4 1.76 C12 center to C13 center TL5 0.86 C13 center to C14 center TL6 0.8 C14 center to C15 center For more information,please contact us at: © 2006 RFIC Technology Corporation All rights reserved. Sales Dept. Tel: +886-2-2698-1022 e-mail: sales@rfintc.com RFIC Technology Corp. reserved the right to make any changes to the specifications without notice. 4 of 7 AP1076 Transmission Line (50Ω) AP1076 RFIC Technology Corporation 2.4~2.5 GHz High Power Amplifier www.rfintc.com RFIC Preliminary 2018.01 Rev3.0 Package Outline Top View Bottom View l a i t n e d i f n C I F Side View R o C Unit: mm AP1076 Note: 1. Dimension and tolerance conform to ASME Y14.5M-1994. 2. Refer to JEDEC STD. MO-220 WEED-2 ISSUE B For more information,please contact us at: © 2006 RFIC Technology Corporation All rights reserved. Sales Dept. Tel: +886-2-2698-1022 e-mail: sales@rfintc.com RFIC Technology Corp. reserved the right to make any changes to the specifications without notice. 5 of 7 AP1076 RFIC Technology Corporation 2.4~2.5 GHz High Power Amplifier www.rfintc.com RFIC Preliminary 2018.01 Rev3.0 Suggested PCB Layout I/O Pin, Central PAD Layout Thermal PAD Via Design Zx l a i t n e d i f n Sx Sy C I F P R X Gy 0.7 mm 0.7 mm Gx . Zy o C θ 0.3mm Y PCB Footprint Dimension (mm) P X Y Sx Sy Gx Gy Zx Zy 0.5 0.3 0.85 1.5 1.5 2.1 2.1 3.8 3.8 AP1076 For more information,please contact us at: © 2006 RFIC Technology Corporation All rights reserved. Sales Dept. Tel: +886-2-2698-1022 e-mail: sales@rfintc.com RFIC Technology Corp. reserved the right to make any changes to the specifications without notice. 6 of 7 AP1076 RFIC Technology Corporation 2.4~2.5 GHz High Power Amplifier www.rfintc.com RFIC Preliminary 2018.01 Rev3.0 The product is designed and manufactured for consumer application only and is not intended for any application listed below which requires especially high reliability for the prevention of such defect which could lead to personal injury, death, physical or environmental damage.  Aircraft equipment.  Aerospace equipment.  Undersea equipment.  Medical equipment.  Life-saving or life-sustaining applications  Transportation equipment (vehicles, trains, ships, etc.). l a i t n  Traffic signal equipment.  Disaster prevention / crime prevention equipment.  Application of similar complexity and/ or reliability requirements to the applications listed in the above. R C I F e d i f n o C AP1076 For more information,please contact us at: © 2006 RFIC Technology Corporation All rights reserved. Sales Dept. Tel: +886-2-2698-1022 e-mail: sales@rfintc.com RFIC Technology Corp. reserved the right to make any changes to the specifications without notice. 7 of 7
AP1076 价格&库存
很抱歉,暂时无法提供与“AP1076”相匹配的价格&库存,您可以联系我们找货
