E6C0606RYGC2UDA
E6C0606RYGC2UDA
    EKINGLUX(亿晶源)
    SMD-4P,1.6x1.6mm
    发光二极管/LED 红色,黄绿色 SMD-4P,1.6x1.6mm 568nm,620nm 150mcd,70mcd
E6C0606RYGC2UDA 数据手册
1.6*1.6*0.6mm SMD CHIP LED E6C0606RYGC2UDA LIGHT EMITTING DIODE SPECIFICATION DESCRIPTION: E6C0606RYGC2UDA REVISION: V2.2 ISSUE DATE: 2022-03-03 Contains trade secret information which is the property of Ekinglux and shall not be made available to, or copied or used by anyone outside Ekinglux without its written authorization. Copyright © 2017 Ekinglux Optoelectronics Technology Co., Ltd. All rights reserved www.ekingluxs.com Tel:021-59909181 021-59909182 1 Sales@ekingluxs.com 1.6*1.6*0.6mm SMD CHIP LED E6C0606RYGC2UDA Features: ●Long operating life ●Low Power Consumption ●Wide Viewing Angle ●Low voltage DC operated ●RoHS Compliant Application: ●Backlight ●Decoration lighting ●motormeter ●Indicator Part Number E6C0606RYGC2UDA Dice Material AlGaInP-GaP Emitted Color Red-Yellow Green Lens Color Water Clear Electro-Optical Characteristics(Ta=25℃, @20mA) Parameter Luminous Intensity Radiation Bandwidth Forward Voltage Dominant Wavelength Viewing Angle Reverse Current Color ■ ■ ■ ■ ■ ■ ■ ■ - Symbol Min. 70 30 1.90 1.90 620 570 - IV △λ VF λd 2θ1/2 IR Typ. 100 40 15 30 2.00 2.00 625 572 120 - Max. 150 70 2.40 2.40 630 575 10 Unit mcd nm v nm deg uA Absolute Maximum Ratings(Ta=25℃) Parameter Peak Forward Current(1/10 Duty Cycle, 0.1ms Pulse Width) Forward Current Reverse Voltage Electrostatic Discharge Operating Temperature Range Storage Temperature Range Reflow Soldering www.ekingluxs.com Tel:021-59909181 Symbol IFP IF VR ESD Topr Tstg Tsld 021-59909182 2 Max. Unit 100 mA 20 mA 5 v 2000 v o -40to+90 C o -40to+90 C 260℃for 10secs Sales@ekingluxs.com 1.6*1.6*0.6mm SMD CHIP LED E6C0606RYGC2UDA Optical & Electrical Characteristics Relative Intensity vs.Wavelength 100% Relative lntensity(%) Ta=25°c 80% 60% 40% 20% 0% 350 400 450 500 550 600 650 Wavelength (nm) Permissible Forward Current(mA) 50 Forward Current(mA) Ta=25°c 40 30 20 10 1.6 2.0 2.4 2.8 3.2 Forward Voltage(V) 3.6 Relative lntensity vs.Forward Currenr 50 40 30 20 10 0 20 40 60 80 100 Ambient Temperature(°c) 1.2 1.0 Relative lntensity Relative lntensity 0 Relative lntensity vs.Ambient Temperature Ta=25°c 3.0 2.5 2.0 1.5 1.0 0 800 60 3.5 0 750 Forward Current vs.Ambient Temperature Forward Current vs.Forward Voltage 0 700 0.8 0.6 0.4 0.2 20 40 60 80 Forward Current(mA) 0 100 -20° -30° -40° Radiation Pattern -10° 0° 10° Ta=25°c 0 20 40 60 80 100 Ambient Temperature(°c) 20° 30° 40° 50° -50° -60° 60° -70° 70° 80° -80° -90° 1.0 www.ekingluxs.com 0.5 0 Tel:021-59909181 0.5 021-59909182 3 90° 1.0 Sales@ekingluxs.com 1.6*1.6*0.6mm SMD CHIP LED E6C0606RYGC2UDA Reliability Test Items And Conditions Test Items Reference Thermal Shock Test Conditions Time -40℃(30min) 100 -100℃(30min) Cycles -10℃~65℃; 10cycles 0%~90%RH MIL-STD-202G Temperature And Humidity Cyclic High Temperature Storage Low Temperature Storage High Temperature High Humidity Storage High Temperature Life Test JEITA ED-4701 200 203 JEITA ED -4071 200 201 JEITA ED -4071 200 202 JEITA ED -4071 100 103 JESD22-A108D Life Test Resistance to Sodering Heat GB/T 4937,Ⅱ, 2.2&2.3 Criterion 22 0/22 22 0/22 Ta=100℃ 1000H 22 0/22 Ta=-40℃ 1000H 22 0/22 1000H 22 0/22 1000H 22 0/22 1000H 22 0/22 2 times 22 0/22 Ta=60℃; RH=90% Ta=80℃ Ta=25℃ IF=5mA Tsol*=(240±5) ℃10secs JESD22-A108D Quantity Criteria For Judging Damage Test Items Forward Voltage Recerse Current Symbol VF IR Test Conditions IF=IFT VR=5V Luminous Intensity IV IF=IFT Resistance to Soldering Heat - - www.ekingluxs.com Criteria For Judging Damage Initial Data±10% IR≤10uA Average IV degradation≤30%;Single LED IV degradation≤50% Meterial without internal cracks,no meterial between stripped,no deaded light Tel:021-59909181 021-59909182 4 Sales@ekingluxs.com 1.6*1.6*0.6mm SMD CHIP LED E6C0606RYGC2UDA Product size (Unit:mm) A01 NOTES: 1. All dimensions are in millimeters (inches) 2. Tolerances are 0.2mm (0.008inch) unless otherwise noted Recommended Soldering Pad Design (Unit:mm) Taping and package Spec ●Tape Specification:3,000pcs Per Reel www.ekingluxs.com Tel:021-59909181 021-59909182 5 Sales@ekingluxs.com 1.6*1.6*0.6mm SMD CHIP LED E6C0606RYGC2UDA Packaging LabelStyle www.ekingluxs.com Tel:021-59909181 021-59909182 6 Sales@ekingluxs.com 1.6*1.6*0.6mm SMD CHIP LED E6C0606RYGC2UDA Table of Classification Reflow Profiles Profile Feature Sn-Pb Eutectic Assembly Pb-Free Assembly 100 °C 150 °C 150°C 60-120 seconds 200 °C 60-120 seconds 3 °C/second max 3 °C/second max Liquidous temperature (TL) Time at liquidous (tL) 183 °C 60-150 seconds 217 °C 60-150 seconds Peak package body temperature (Tp)* 230 °C ~235 °C 255 °C ~260 °C 235 °C 260 °C 20 seconds 30 seconds 6 °C/second max 6 °C/second max 6 minutes max 8 minutes max Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) Average ramp-up rate (Tsmax to Tp) Classification temperature (Tc) Time (tp) within 5 °C of the specified Classification temperature (Tc) Average ramp-down rate (Tp to Tsmax) Time 25 °C to peak temperature 1. Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum. 2.Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. www.ekingluxs.com Tel:021-59909181 021-59909182 7 Sales@ekingluxs.com 1.6*1.6*0.6mm SMD CHIP LED E6C0606RYGC2UDA Precautions 1. Storage: ●Moisture proof and anti-electrostatic package with moisture absorbent material is used, to keep moisture to aminimum. ●Before opening the package, the product should be kept at 30℃ or less and humidity less than 60% RH, and beused within a year. ●After opening the package, the product should be stored at 30℃ or less and humidity less than 10%RH. It is recommended that the product be operated at the workshop condition of 30℃ or less and humidity less than 60%RH. ●If the moisture absorbent material has fade away or the LEDs have exceeded the storage time, baking treatment should be performed based on the following condition: (70±5)℃ for 24 hours. 2. Static Electricity: Static electricity or surge voltage damages the LEDs. Damaged LEDs will show some unusual characteristic such as the forward voltage becomes lower, or the LEDs do not light at the low current. even not light. All devices, equipment and machinery must be properly grounded. At the same time, it is recommended that wrist bands or anti-electrostatic gloves, anti-electrostatic containers be used when dealing with the LEDs. 3. Vulcanization: LED curing is due to sulfur being in bracket and the +1 price of silver in the chemical reaction generated Ag2S in the process. It will lead to the capacity of reflecting of silver layer reducing, light color temperature drift and serious decline ,seriously affecting the performance of the product.So we should take corresponding measures to avioding vulcanization, such as to avoid using sulphur volatile substances and keeping away from high sulphur content of the material. www.ekingluxs.com Tel:021-59909181 021-59909182 8 Sales@ekingluxs.com
E6C0606RYGC2UDA 价格&库存
很抱歉,暂时无法提供与“E6C0606RYGC2UDA”相匹配的价格&库存,您可以联系我们找货
E6C0606RYGC2UDA
  • 20+0.26514
  • 200+0.21330
  • 600+0.18738
  • 4000+0.16794
  • 8000+0.15239
库存:13856
E6C0606RYGC2UDA
  • 20+0.22890
  • 200+0.18530
  • 600+0.16240
  • 4000+0.14270
  • 8000+0.12960
库存:1556
