FE2.1-CQFP48A
FE2.1-CQFP48A
    TERMINUS(汤铭科技)
    LQFP-48(7x7)
    FE2.1 USB 2.0 高速7端口集线器控制器
FE2.1-CQFP48A 数据手册
USB 2.0 7-Port Hub Data Sheet Rev. 1.4 FE2.1 USB 2.0 HIGH SPEED 7-PORT HUB CONTROLLER Data Sheet INTRODUCTION FEATURES The FE2.1 is a highly integrated, high quality, high  Low power consumption □ 155 mA when seven downstream facing ports enabled in High-Speed mode; □ 66 mA when one downstream facing port enabled in High-Speed mode;  Fully compliant with Universal Serial Bus Specification Revision 2.0 (USB 2.0); □ Upstream facing port supports performance, low power consumption, yet low cost solution for USB 2.0 High Speed 7-Port Hub. It adopts Multiple Transaction Translator (MTT) architecture to explore the maximum possible throughput. Six, instead of two, non-periodic transaction buffers are used to minimize potential traffic jamming. The whole design is based on state- High- Speed (480MHz) and FullSpeed (12MHz) modes; machine-control to reduce the response delay time; no micro controller is used in this chip. □ To guarantee high quality, the whole chip is covered by Test Scan Chain – include even on the high speed 7 downstream facing ports support High-Speed (480MHz), Full-Speed (12MHz), and Low-Speed (1.5MHz) modes; Integrated USB 2.0 Transceivers; (480MHz) modules, so that all the logic components  could be fully tested before shipping. Special Build-  Integrated upstream 1.5KΩ pull-up, downstream 15KΩ pull-down, and serial resistors;  Integrated 5V to 3.3V and 1.8V regulator.  Integrated Power-On-Reset circuit;  Integrated 12MHz Oscillator with feedback resistor and crystal load capacitor;  Integrated 12MHz-to-480MHz Phase Lock Loop (PLL);  Multiple Transaction Translators (MTT) – In-Self-Test mode is designed to exercise all high, full, and low speed Analog Front End (AFE) components in the packaging and testing stages as well. Low power consumption is achieved by using 0.18μm technology and comprehensive power/clock control mechanism. Most part of the chip will not be clocked unless needed. April 5, 2017 □ One TT for each downstream port; Subject to Change Without Notice 1 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 □ □ Alternate Interface 0 for Single-TT, and Alternate Interface 1 for Multiple-TT; Each TT could handle 64 periodic StartSplit transactions, 32 periodic Complete-Split transactions, and 6 none-periodic transactions;   Support self-power Mode only; Board configured options – □ Ganged or Individual Power Control Mode select; □ Global, Multiple Gangs, or Individual Over-Current Protection Mode select; Removable or Non-Removable Downstream Devices configuration; □ □  Number of Downstream Ports; EEPROM configured options – □  Vendor ID, Product ID, & Device Release Number; □ Removable or Non-Removable Downstream Devices configuration; □ Serial Number; and □ Number of Downstream Ports; Comprehensive status Indicators support: □ Standard downstream port status indicators (Green and Amber LED control for each downstream port); □ April 5, 2017 Hub Active/Suspend indicator LED. Subject to Change Without Notice 2 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 ORDER INFORMATION P/N-Order Code FE2.1-CQFP48A FE2.1-CQFP48AT(Note 1) FE2.1-CQFP48ATR FE2.1-CQFP64A Description Package Type Packing Minimum Order Quantity 48-pin LQFP (7mm x 7mm) Tray 15000 48-pin LQFP USB 2.0 7-Port MTT (7mm x 7mm) Hub Controller 48-pin LQFP (7mm x 7mm) Tray 2500 Tape & Reel 10000 Tray 9600 64-pin LQFP (10mm x 10mm) Note 1: Product of order code CQFP48AT is final tested in Room Temperature, 85°C, and -40°C, respectively. Note 2: All Terminus products are Halogen Free and RoHS Compliant. April 5, 2017 Subject to Change Without Notice 3 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 BLOCK DIAGRAM To Downstream Devices Downstream PHY #1 Downstream PHY #2 To Upstream Host/Hub Downstream PHY #7 ….. Upstream PHY Routing Switch USB Multi-port Transceiver Macro Cell 3.3V & 1.8V Regulator 12MHz Crystal Over Current Detection Power Switch Control OSC POR Downstream Port Controllers Transaction Translator Full/Low-Speed Handler PLL (x40) Data Transmit Data Recovery & Elastic Buffer USB 2.0 Serial Hub Interface Controller Engine Transaction Translator High-Speed Handler Unified Transaction Translator Buffer (14KB) Upstream Port Controller Hub Controller LED Controller EEPROM, Hub Activity LED Port Indicators Fig. 1: Block Diagram April 5, 2017 Subject to Change Without Notice 4 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 PACKAGE I – 64-PIN LQFP (Body Size: 10 x 10 mm) LED[5] VSS VBUSM XRSTJ PWRJ[7] PWRJ[6] OVCJ[7] OVCJ[6] VD33 PWRJ[5] PWRJ[1] OVCJ[5] PWRJ[2] OVCJ[1] LED[7] OVCJ[2] LED[6] PIN ASSIGNMENT 49 48 64 1 DRV DP7 DM7 TESTJ VD33 LED[1] DP6 LED[2] DM6 LED[3] VSS VD18 DP5 FE2.1 LED[4] VDD5 DM5 VD33 VD33_O DPU VSS DMU PWRJ[3] VSS OVCJ[3] PWRJ[4] VD18 REXT VD33 OVCJJ[4] 32 33 VD18_O XOUT VS_PLL XIN VD33 VD_PLL DP1 DM1 VSS DP2 DM2 VD33 DP3 DM3 DP4 17 VSS 16 DM4 VD33 Fig. 2: 64-Pin LQFP Pin Assignment April 5, 2017 Subject to Change Without Notice 5 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 PACKAGE II – 48-PIN LQFP (Body Size: 7 x 7 mm) 48 DRV DM7 DP7 VSS XRSTJ VBUSM VD33 OVCJ5 PWRJ OVCJ1 LED[7] LED[6] LED[5] PIN ASSIGNMENT 37 1 36 VD33 TESTJ DP6 LED[1] DM6 LED[2] DP5 LED[3] DM5 VD18 VD33 FE2.1 LED[4] DPU VDD5 DMU VD33_O VD18 VSS REXT DM4 VD33 12 25 XOUT XIN VD_PLL VD33 DP1 DM1 DP2 DM2 VD33 DP3 13 DM3 VD18_O 24 VS_PLL DP4 Fig. 3: 48-Pin LQFP Pin Assignment April 5, 2017 Subject to Change Without Notice 6 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 PIN DESCRIPTION TABLE Pin Name 64-pin 48-pin Type LQFP LQFP Pin No. Pin No. Function Note LED[5] 1 48 O LED Control for the 5th Downstream Facing Port Status. DRV 2 1 O Driving Control for all LED. TESTJ 3 2 IO-PU Test Mode Enable during hardware reset, active low. Otherwise, SDA, Serial Data/Address pin for external Serial EEPROM. LED[1] 4 3 O/IO-PU LED Control for the 1st Downstream Facing Port Status, 4 and SCL, Serial Clock pin for external Serial EEPROM. LED[2] 5 4 O/I-PU LED Control for the 2nd Downstream Facing Port Status, and Non-Removable Device Configuration bit 0. 3 LED[3] 6 5 O/I-PU LED Control for the 3rd Downstream Facing Port Status, and Non-Removable Device Configuration bit 1. 3 VD18 7, 36 6, 28 P 1.8V power input. LED[4] 8 7 O/I-PU LED Control for the 4th Downstream Facing Port Status, and Non-Removable Device Configuration bit 2. VDD5 9 8 P 5V power input for integrated 5V→3.3V regulator. VD33_O 10 9 P 3.3V power output from 5V→3.3V integrated regulator – a 10μF output capacitor is required. VSS 11, 19, 25, 37, 43, 49 10, 39 P Ground. PWRJ[3] 12 ― OD Power Enable for 3rd Downstream Facing Port, active low. OVCJ[3] 13 ― I-PU Over-current Detect for 3rd Downstream Facing Port, active low. PWRJ[4] 14 ― OD Power Enable for 4th Downstream Facing Port, active low. OVCJ[4] 15 ― I-PU Over-current Detect for 4th Downstream Facing Port, active low. VD33 16, 22, 28, 34, 40, 46, 56 15, 20, 26, 31, 36, 42 P 3.3V Power Input. DM4 17 11 UTD The D- pin of the 4th Downstream Facing Port. DP4 18 12 UTD The D+ pin of the 4th Downstream Facing Port. DM3 20 13 UTD The D- pin of the 3rd Downstream Facing Port. DP3 21 14 UTD The D+ pin of the 3rd Downstream Facing Port. April 5, 2017 Subject to Change Without Notice 3 1 1 7 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 DM2 23 16 UTD The D- pin of the 2nd Downstream Facing Port. DP2 24 17 UTD The D+ pin of the 2nd Downstream Facing Port. DM1 26 18 UTD The D- pin of the 1st Downstream Facing Port. DP1 27 19 UTD The D+ pin of the 1st Downstream Facing Port. VD_PLL 29 21 P 1.8V Power for PLL. XIN 30 22 OSC 12 MHz Crystal Oscillator input XOUT 31 23 OSC 12 MHz Crystal Oscillator output. VS_PLL 32 24 P Ground for PLL. VD18_O 33 25 P 1.8V power output from 3.3V→1.8V integrated regulator – a 10μF output capacitor is required. REXT 35 27 A A 2.7KΩ (± 1%) resistor should be connected to VSS to provide internal bias reference. DMU 38 29 UTU The D- pin of the Upstream Facing Port. DPU 39 30 UTU The D+ pin of the Upstream Facing Port. DM5 41 32 UTD The D- pin of the 5th Downstream Facing Port. DP5 42 33 UTD The D+ pin of the 5th Downstream Facing Port. DM6 44 34 UTD The D- pin of the 6th Downstream Facing Port. DP6 45 35 UTD The D+ pin of the 6th Downstream Facing Port. DM7 47 37 UTD The D- pin of the 7th Downstream Facing Port. DP7 48 38 UTD The D+ pin of the 7th Downstream Facing Port. XRSTJ 50 40 I External Reset, active low, is an optional source of chip reset signal. The minimum low pulse width is 10 μs. VBUSM 51 41 I The VBUS Monitor of upstream facing port. PWRJ[7] 52 ― OD/I-PU Power Enable for 7th Downstream Facing Port, active low, and Power Control Mode Configuration bit 1. 2 OVCJ[7] 53 ― I-PU Over-current Detect for 7th Downstream Facing Port, active low. 1 PWRJ[6] 54 ― OD/I-PU Power Enable for 6th Downstream Facing Port, active low, and Power Control Mode Configuration bit 1. 2 OVCJ[6] 55 ― I-PU Over-current Detect for 6th Downstream Facing Port, active low. 1 PWRJ[5] 57 ― OD Power Enable for 5th Downstream Facing Port, active low. OVCJ[5] 58 43 I-PU Over-current Detect for 5th Downstream Facing Port, active low. PWRJ[1] 59 44 OD Power Enable for 1st Downstream Facing Port, active low. April 5, 2017 Subject to Change Without Notice 1 8 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 OVCJ[1] 60 45 I Over-current Detect for 1st Downstream Facing Port, active low. 1, 3 PWRJ[2] 61 ― OD Power Enable for 2nd Downstream Facing Port, active low. OVCJ[2] 62 ― I-PU Over-current Detect for 2nd Downstream Facing Port, active low. 1 LED[7] 63 46 O/I-PU LED Control for the 7th Downstream Facing Port Status, and Number of Ports Configuration bit 0. 3 LED[6] 64 47 O/I-PU LED Control for the 6th Downstream Facing Port Status, and Number of Ports Configuration bit 1. 3 Note 1. Pins OVCJ[7:2] are equipped with optional internal pull-up resistors. When certain OVCJ pin is not required by currently configured over-current protection mode, its internal pull-up resistor will be applied so that pin can be left as unconnected on the board. Otherwise, when certain OVCJ pin is used by currently configured over-current protection mode, its pull-up resistor will be removed so that it could be used to monitor either 3.3V or 5V input from external application circuit. 2. During power up configuration stage, pins PWRJ[7:6] are used as input with internal pull-up resistors. Once passed that stage, they will be configured as open drain output. 3. During power up configuration stage, pins LED[4:2] and LED[7:6] are used as input with internal pull-up resistor. Once passed that stage, they will be configured as CMOS output. 4. During power up configuration stage, pin LED[1] is used as CMOS tristate I/O to work with the external EEPROM as serial clock. Once passed that stage, it is used as CMOS output. Type Abbreviation – I: Schmitt Trigger Input, 5V-Tolerant; I-PU : Input with Controllable Internal Pull-Up, 5V-Tolerant when pull-up resistor is disabled; IO-PU : CMOS 3-state Output with Input and Internal Pull-Up; OD : Open Drain Output; O: CMOS Output; A: Analog I/O; P: Power/Ground; OSC : Crystal Oscillator with internal feedback resistor and load capacitor; UTU : USB High Speed and Full Speed Transceiver; UTD : USB High Speed, Full Speed, and Low Speed Transceiver. April 5, 2017 Subject to Change Without Notice 9 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 CONFIGURABLE OPTIONS The FE2.1 is a highly versatile design that can be configured to meet many varieties of implementation requirement in a rather easy way. The behavior of FE2.1 can be configured by either board design selected options or through contents of external EEPROM. LED Indicators, Number of Downstream Facing Port, and Non-Removable Devices According to USB 2.0 Specification, the status of each downstream port is shown by two LED indicators – the Green and Amber LED. FE2.1 supports the full function as specified by DRV and LED[7:1] pins. Fig. 4 shows how these port status indicators be connected, together with the external EEPROM and the Hub Active Indicator (the Red LED). TESTJ SDA SCL FE2.1 EEPROM Green A0 A1 A2 Port 1 Indicators LED[1] Amber Green Port 2 Indicators LED[2] Amber Green Port 3 Indicators LED[3] Amber Green Port 4 Indicators LED[4] Amber Green Port 5 Indicators LED[5] Amber Green Port 6 Indicators LED[6] Amber Green Port 7 Indicators LED[7] Amber DRV Red Hub Active Indicator Fig. 4: LED and EEPROM Connections April 5, 2017 Subject to Change Without Notice 10 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 The optional Hub Active Indicator is only turned on when the hub is configured by the host, and turned off when the hub is either set into suspend mode, disconnected, or powered off by the host. Any of these fifteen LED's could be removed without effecting the normal function of the hub. The LED[7:1] pins could also be used to configure the number of downstream facing port and non-removable downstream devices. These option selections are sampled and loaded each time after chip reset. If an alternate configuration is intended, the corresponding pins should be tied to ground as shown in the following table. Otherwise, denoted as Normal in the following tables, they could be either left floating or connected to the LED's as shown by Fig. 4. Usable Downstream Facing Port LED[7] LED[6] 4, 3, 2, 1 Tied-to-Ground Tied-to-Ground 5, 4, 3, 2, 1 Normal Tied-to-Ground 6, 5, 4, 3, 2, 1 Tied-to-Ground Normal 7, 6, 5, 4, 3, 2, 1 Normal Normal Setting the number of Downstream Facing Port by tying any of LED[7:6] to ground will change the bNbrPorts field (3rd byte) of Hub Descriptor as response to host's GetHubDescriptor request. Henceforth the ports beyond the specified number will not be recognized nor activated by the host. Non-Removable Downstream Facing ports LED[4] LED[3] LED[2] None Normal Normal Normal 2 Normal Normal Tied-to-Ground 3, 2 Normal Tied-to-Ground Normal 3, 2, 1 Normal Tied-to-Ground Tied-to-Ground 4, 3, 2, 1 Tied-to-Ground Normal Normal 5, 4, 3, 2, 1 Tied-to-Ground Normal Tied-to-Ground 6, 5, 4, 3, 2, 1 Tied-to-Ground Tied-to-Ground Normal 7, 6, 5, 4, 3, 2, 1 Tied-to-Ground Tied-to-Ground Tied-to-Ground April 5, 2017 Subject to Change Without Notice 11 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 The Non-Removable Downstream Facing Ports setting is reported in the bit-map of DeviceRemovable field of Hub Class Descriptor. When a downstream facing port is configured as unusable or non-removable, its corresponding LED pin will be disabled. In other words, those LED pins should be either tied to ground based on the selected configuration, or left floating. The only exception is LED[1], which would be still used as SCL, Serial Clock pin for external EEPROM, should it exist. Fig. 5 depicts an example that enable 5 downstream facing ports only, with port 3 and 2 as nonremovable device. As shown, the LED[4] is connected to the LED's, LED[2] left floating, and LED[3] tied to ground, so that the FE2.1 would recognize that port 3 and 2 are non-removable devices. The LED[6] is tied to ground and LED[7] left floating, thus the FE2.1 will report to system that only 5 ports are available in this hub. TESTJ FE2.1 SDA SCL Green EEPROM A0 A1 A2 Port 1 Indicators LED[1] Amber LED[2] LED[3] Green LED[4] Amber Green Port 4 Indicators Port 5 Indicators LED[5] Amber LED[6] LED[7] DRV Red Hub Active Indicator Fig. 5: LED Board Configuration Example If the external EEPROM is not required, the TESTJ should be left floating. If the Hub Active Indicator is not required, the LED and its serial resistor should be removed together. If the port status LED's are not required, LED[5:4, 1] could be all left floating with all their related Green/Amber LED's and resistors removed. April 5, 2017 Subject to Change Without Notice 12 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 POWER CONTROL AND OVER-CURRENT PROTECTION The FE2.1 supports optional power switches that control delivery of power downstream facing ports by way of a set of active low, open drain, control pins, PWRJ[7:1]. With external pull-up resistors to either 5V or 3.3V, system designers could choice from a wide variety of circuit to implement the power switches. As self-powered hub, over-current protection is a must for safety reasons. The FE2.1 provides a set of input pins, OVCJ[7:1], to monitor status of external over-current detection circuit. The over-current status will than be reported to the host hub driver by FE2.1. Depends on the power control mode actually selected, the unused OVCJ pins will be internally pull-up and left unconnected on board. The FE2.1 supports three types of power control modes, namely Individual Mode, Multiple Gangs Mode, and Ganged Mode. These modes could be configured by tying either or both of PWRJ[7:6] to ground according to the following table. Power PWRJ[7] PWRJ[6] wHubCharacteristics Control Mode D1..D0 D4..D3 PWRJ [N] PWRJ [N] 1, 2, 3, 4, 1, 2, 3, 4, 5, 6, 7 5, 6, 7 Availability Individual Mode Normal Normal 01 01 LQFP-64 Multiple Gangs Mode Tied-toGround Normal 00 01 1 1, 5 LQFP-64, LQFP-48 Ganged Mode Tied-toGround Tied-toGround 00 00 1 1 LQFP-64 In the Individual Mode, the power switch of each port is controlled individually, and the overcurrent status is reported on a per-port basis. That is, for each port N, the power switch is controlled by PWRJ[N], and the over-current status is monitored by OVCJ[N]. Fig. 6 demonstrates a LQFP-64 implementation of Individual Mode design with dual-channel power distribution switches. In this case, 3.3V pull-up are used for PWRJ/Enable pins to meet the requirement of the specific switches used. April 5, 2017 Subject to Change Without Notice 13 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 3.3V 5V Power Switch OVCJ[1] ENA FLGA FLGB ENB OVCJ[2] OVCJ[3] OVCJ[4] OVCJ[5] OUTA IN GND OUTB Power Switch OVCJ[6] ENA FLGA FLGB ENB OVCJ[7] FE2.1 PWRJ[1] PWRJ[2] OUTA IN GND OUTB Power Switch PWRJ[3] ENA FLGA FLGB ENB PWRJ[4] PWRJ[5] PWRJ[6] PWRJ[7] 3.3V OUTA IN GND OUTB Power Switch ENA OUTA FLGA IN FLGB GND ENB OUTB To VBUS of Port 1 To VBUS of Port 2 To VBUS of Port 3 To VBUS of Port 4 To VBUS of Port 5 To VBUS of Port 6 To VBUS of Port 7 Fig. 6: LQFP-64 Individual Power Control Mode Example In the Ganged Mode, the power switch to all ports are controlled by one single PWRJ[1], and the over-current is monitored by OVCJ[1]. Therefore, when host issues SetPortFeature(PORT_POWER) to any of the downstream facing port, the PWRJ[1] will go active, and only when all ports are in powered-off state that PWRJ[1] will be turned inactive. Since there is only one OVCJ input, all downstream facing ports will be marked as over-current simultaneously and set to powered-off state. The Multiple Gangs Mode has one more over-current status pin, OVCJ[5], then the Ganged Mode. If OVCJ[1] goes low, downstream facing port 1, 2, 3, and 4 would be marked as over-current. If OVCJ[5] goes low, downstream facing port 5, 6, and 7 would be marked as over-current. Since April 5, 2017 Subject to Change Without Notice 14 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 there is only one PWRJ pin, all ports will be switched to powered-off state at once. This is the only mode supported by LQFP-48 package of FE2.1. The power control mode selection is reported to the host software through the wHubCharacteristics field, the 4th and 5th byte, of Hub Descriptor, which describes the hub's operational characteristics. Two bit-fields would be effected – “D1..D0” for Logical Power Switching Mode, and “D4..D3” for Over-current Protection Mode. In “D1..D0”, 00 means ganged power switching (all ports' power at the once,) and 01 means individual port power switching. In “D4..D3”, 00 represents global overcurrent protection, and 01 represents individual port over-current protection. Fig. 7 & Fig. 8 demonstrate LQFP-64 implementations of Ganged Mode and Multiple Gangs Mode with power switches. 3.3V OVCJ[1] OVCJ[2] OVCJ[3] OVCJ[4] 5V Power Switch (3.5A) CTL OUT FLG IN GND OUT IN OVCJ[5] To All Downstream Port OVCJ[6] OVCJ[7] FE2.1 PWRJ[1] PWRJ[2] PWRJ[3] PWRJ[4] PWRJ[5] PWRJ[6] PWRJ[7] Ganged Mode Selected Fig. 7: LQFP-64 Ganged Power Control Mode Example April 5, 2017 Subject to Change Without Notice 15 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 3.3V Power Switch (2A) OVCJ[1] OVCJ[2] OVCJ[3] OVCJ[4] OVCJ[5] OVCJ[6] OVCJ[7] CTL FLG GND GATE OUT IN OUT IN To Port 1, 2, 3, & 4 Power Switch (2A) CTL FLG GND GATE FE2.1 PWRJ[1] PWRJ[2] PWRJ[3] PWRJ[4] PWRJ[5] PWRJ[6] PWRJ[7] 5V OUT IN OUT IN To Port 5, 6, & 7 Multiple Gangs Mode Selected Fig. 8: LQFP-64 Multiple Gangs Power Control Mode Example And Fig. 9 shows LQFP-48 implementation for Multiple Gangs Mode – the only mode supported by LQFP-48 package. 3.3V OVCJ1 OVCJ5 PWRJ FE2.1 (LQFP48) 5V Power Switch (2A) CTL OUT FLG IN GND OUT GATE IN To Port 1, 2, 3, & 4 Power Switch (2A) CTL OUT FLG IN GND OUT GATE IN To Port 5, 6, & 7 Fig. 9: LQFP-48 Multiple Gangs Power Control Mode Example April 5, 2017 Subject to Change Without Notice 16 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 EEPROM CONTENTS Address Contents 0x00 0x40 Constant, low byte of check code 0x01 0x1A Constant, high byte of check code 0x02 Vendor ID (Low) Low byte of Vendor ID, idVendor field of Standard Device Descriptor 0x03 Vendor ID (High) High byte of Vendor ID, idVendor field of Standard Device Descriptor 0x04 Product ID (Low) Low byte of Product ID, idProduct field of Standard Device Descriptor 0x05 Product ID (High) High Byte of Product ID, idProduct field of Standard Device Descriptor 0x06 Device Release (Low) Low byte of Device Release Number, must be Binary Coded Decimal, bcdDevice field of Standard Device Descriptor 0x07 Device Release (High) High byte of Device Release Number, must be Binary Coded Decimal, bcdDevice field of Standard Device Descriptor 0x08 ~0x17 Device Serial Number Device's Serial Number – the contents of string descriptor describing the device's serial number. 0x18 Length of Serial Number 0x19 Filling 0x1A Port Number 0x1B Filling 0x1C Device Removable 0x1D Filling 0x1E Device Attributes April 5, 2017 Note Length of effective “Device Serial Number” stored in 0x08 to 0x17. 0x00 Number of Downstream Ports, bNbrPorts field of Hub Descriptor. 0x00 DeviceRemovable field of Hub Descriptor – Indicates if a port has a removable device attached. If bit N is set to 1, then the device on downstream facing port N is non-removable. Otherwise, it is removable. Bit 0 is reserved and should be 0. 0x00 Bit 0: Port Indicators Support, bit 7 of wHubCharacteristics field of Hub Descriptor – 0: Port Indicators are not supported on its downstream facing ports and PORT_INDICATOR request has no effect. 1: Port Indicators are supported on its downstream facing ports and PORT_INDICATOR request controls the indicators. Bit 1: Identifies a Compound Device, bit 2 of wHubCharacteristics Subject to Change Without Notice 17 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 field of Hub Descriptor – 0: Hub is not part of a compound device. 1: Hub is part of a compound device. Bit 2: Maximum current requirements of the Hub Controller electronics, bHubContrCurrent field of Hub Descriptor – 0: 200mA. 1: 500mA. Bit 3 to 7, reserved, must be 0's. 0x1F Check Sum The 8-bit sum of all value from 0x00 to 0x1E. The first two bytes are the check code for the existence of EEPROM, their value must be 0x1A40. Any other value would cause the EEPROM loading mechanism of FE2.1 to conclude that the contents of this EEPROM is unusable, and use default values instead. The string descriptor for device's serial number could be defined by Device Serial Number and Length of Serial Number fields of the EEPROM, address 0x08 to 0x18. Length of Serial Number field, address 0x18, define the number of digits, while Device Serial Number field, address 0x08 to 0x17, specify the serial number in ASCII code. The space after the specified number of digits should be filled with Null, 0x00. For example, suppose the serial number is “A090108F4”, then the EEPROM should be like: 0x08 0x41 (A) 0x30 (0) 0x39 (9) 0x30 (0) 0x31 (1) 0x30 (0) 0x38 (8) 0x46 (F) 0x10 0x34 (4) 0x00 (Null) 0x00 (Null) 0x00 (Null) 0x00 (Null) 0x00 (Null) 0x00 (Null) 0x00 (Null) 0x18 0x09 The last byte, address 0x1F, is a checksum made up of the sum of all value from 0x00 to 0x1E. The numbers must match to render the contents of the EEPROM usable. Otherwise, the loading mechanism of FE2.1 would discard the value from EEPROM and use default values instead. April 5, 2017 Subject to Change Without Notice 18 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS Parameter Symbol Min. Max. Unit Storage Temperature TS -55 +150 °C Power Supply Voltage VDD5 VD33 VD18 & VD_PLL -0.5 -0.5 -0.5 +6.0 +4.0 +2.5 V ESD Human Body Mode -2000 2000 V ESD Machine Mode -200 200 V Latch Up -200 200 mA RECOMMENDED OPERATING RANGES Parameter Symbol Min. Operating temperature TA 0 Operating voltage VDD5 VD33 VD18 & VD_PLL 4.5 3.0 1.62 LOW level voltage of digital input VIL HIGH level voltage of digital input Typ. Max. Unit 70 °C 5.5 3.6 1.98 V -0.3 0.8 V VIH 2.0 5.5 V Threshold voltage of digital input VTH 1.45 1.58 1.74 V Low-to-High level of Schmitt-trigger input VT+ 1.44 1.5 1.56 V High-to-Low level of Schmitt-trigger input VT- 0.89 0.94 0.99 V LOW level voltage of digital output@4mA VOL 0.4 V HIGH level voltage of digital output@4mA VOH 2.4 Internal Pull-Up Resistor Range RPU 39 April 5, 2017 Subject to Change Without Notice 5.0 3.3 1.8 V 65 116 KΩ 19 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 EXTENDED OPERATING RANGES Product with order code of CQFP48AT is Final Tested (FT) at Room Temperature, 85°C, and -40°C. Parameter Operating temperature April 5, 2017 Symbol TA Subject to Change Without Notice Min. Typ. Max. -40 25 85 Unit °C 20 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 POWER CONSUMPTION DC SUPPLY CURRENT Symbol Condition Active I_suspend 6 5 4 3 2 1 No active April 5, 2017 Unit Devices Suspend 7 Icc Host Typical 600 uA Full-Speed 7x Full-Speed 36 mA High-Speed 7x High-Speed 155 mA High-Speed 7x Full-Speed 53 mA Full-Speed 6x Full-Speed 36 mA High-Speed 6x High-Speed 140 mA High-Speed 6x Full-Speed 53 mA Full-Speed 5x Full-Speed 36 mA High-Speed 5x High-Speed 125 mA High-Speed 5x Full-Speed 53 mA Full-Speed 4x Full-Speed 35 mA High-Speed 4x High-Speed 111 mA High-Speed 4x Full-Speed 52 mA Full-Speed 3x Full-Speed 35 mA High-Speed 3x High-Speed 96 mA High-Speed 3x Full-Speed 52 mA Full-Speed 2x Full-Speed 35 mA High-Speed 2x High-Speed 82 mA High-Speed 2x Full-Speed 52 mA Full-Speed 1x Full-Speed 35 mA High-Speed 1x High-Speed 66 mA High-Speed 1x Full-Speed 52 mA Full-Speed None 35 mA High-Speed None 52 mA Subject to Change Without Notice 21 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 PACKAGE DRAWING I – 64-PIN LQFP (Body Size: 10 x 10 mm) April 5, 2017 Subject to Change Without Notice 22 USB 2.0 7-Port Hub Data Sheet Rev. 1.4 PACKAGE DRAWING II – 48-PIN LQFP (Body Size: 7 x 7 mm) Terminus Technology Inc. 5F., No.9, Ln.130, Sec.3, Minsheng E.Rd., Songshan Dist., Taipei City, Taiwan www.terminus-tech.com April 5, 2017 Subject to Change Without Notice 23
FE2.1-CQFP48A 价格&库存
很抱歉,暂时无法提供与“FE2.1-CQFP48A”相匹配的价格&库存,您可以联系我们找货
FE2.1-CQFP48A
  • 1+12.34800
  • 10+10.30960
  • 30+9.04540
  • 250+7.56560
库存:250
