EW-7811UTC
EW-7811UTC
    EDIMAX
    EDIMAX - EW-7811UTC - AC600 Dual-Band Mini USB Wifi Adapter
EW-7811UTC 数据手册
EW-7811UTC AC600 Wireless Dual-Band Mini USB Adapter Overview The next generation 802.11ac wireless standard is set to revolutionize Wi-Fi. Super-speed 802.11ac dual-band routers are already available but wireless devices are still stuck with 802.11n technology. Upgrade your wireless device to dual-band 802.11ac with the fastest possible USB 2.0 connectivity for blistering Wi-Fi speeds on the interference free 5Ghz frequency band. Next Generation Wi-Fi Standard The Edimax EW-7811UTC is the next generation of Wi-Fi adapter, compatible with the draft 802.11ac standard and delivering speeds of up to 433Mbps at 5GHz - almost three times as fast as 802.11n. Upgrade PCs and notebooks to super high speed 802.11ac Wi-Fi and enjoy streaming video and data. Dual-Band Connectivity Enjoy better performance and greater flexibility for your Wi-Fi devices, using dual-band connectivity. The EW-7811UTC provides connectivity for the 2.4GHz band at speeds of 150Mbps or 5Ghz band at speeds of 433Mbps. You can surf the internet and check your email on the 2.4GHz band, or select the 5GHz band for online gaming and video streaming. Mac & OS X are trademarks of Apple Inc. Maximum performance, actual data rates, and coverage will vary depending on network conditions and environmental factors. Product specifications and design are subject to change without notice. Copyright © 2013 Edimax Technology Co. Ltd. All rights reserved. www.edimax.com www.edimax.com AC600 Wireless Dual-Band Mini USB Adapter EW-7811UTC Download and Stream Anywhere Use the EW-7811UTC to download and stream media from YouTube, Netflix or other services without waiting for buffering, or stream media across your network from a NAS (networkattached storage) at lightning speeds. Streaming HD movies or downloading is faster and more reliable than ever with 802.11ac Wi-Fi. Compact & Convenient Designed for efficiency and performance, the mini-sized adapter is lightweight, sleek and portable. Incorporating 11ac technology into users’ lifestyles and unlocking a new world of potential Wi-Fi applications, the low-profile miniadapter sits almost unnoticed in any USB drive and travels with your laptop wherever your lifestyle takes it. Wi-Fi Protected Setup (WPS) Button The EW-7811UTC has a one-click Wi-Fi Protected Setup (WPS) button to help you set up and activate a secure wireless network in a snap. Maximum performance, actual data rates, and coverage will vary depending on network conditions and environmental factors. Product specifications and design are subject to change without notice. Copyright © 2013 Edimax Technology Co. Ltd. All rights reserved. www.edimax.com www.edimax.com AC600 Wireless Dual-Band Mini USB Adapter EW-7811UTC FEATURES • Complies with draft IEEE 802.11ac standard and backward compatible with wireless 802.11a/b/g/n standards • Dual-band wireless connectivity for 2.4GHz or 5GHz • Maximum Wi-Fi speeds of 150Mbps (2.4GHz) or 433Mbps (5GHz) • Features a hardware WPS (Wi-Fi Protected Setup) button for easy wireless connections • Features easy setup wizard • Supports Windows XP/Vista/7/8, Linux and Mac OS X drivers TECHNICAL SPECIFICATIONS Hardware 1 x USB 2.0 Type A 1 x Hardware WPS Button 1 x Link/Activity LED Output Power 2.4GHz 11b (11Mbps): 17dBm±1.5dBm 11g (54Mbps): 15dBm±1.5dBm 11n (20MHz, MCS7): 14dBm±1.5dBm 11n (40MHz, MCS7): 14dBm±1.5dBm 5GHz 11a (54Mbps): 14dBm±1.5dBm 11n (20MHz, MCS7): 13dBm±1.5dBm 11n (40MHz, MCS7): 13dBm±1.5dBm 11ac (80MHz, MCS9): 12dBm±1.5dBm LEDs Link/Activity Weight 3g Standards 2.4GHz: IEEE 802.11b, 802.11g, 802.11n 5GHz: IEEE 802.11ac (Draft), 802.11a, 802.11n Installation Easy setup wizard Hardware WPS Button for easy wireless connections Security WEP 64/128-bit, WPA, WPA2, 802.1x Hardware & Software WPS Configuration Dimensions 40(H) x 16(W) x 7(D) mm Frequency Band 2.4000 - 2.4835GHz (subject to local regulations) 5.150 - 5.825GHz (subject to local regulations) Operating Range 11a: 6/9/12/24/36/48/54Mbps 11b: 1/2/5.5/11Mbps 11g: 6/9/12/24/36/48/54Mbps 11n (20MHz): MCS0-7 (up to 72Mbps) 11n (40MHz): MCS0-7 (up to 144Mbps) 11ac (80MHz): MCS0-9 (up to 433Mbps) Temperature & Humidity Max 95% (non-condensing) 32 - 104°F (0 - 40°C) Certifications CE/FCC APPLICATION DIAGRAM Maximum performance, actual data rates, and coverage will vary depending on network conditions and environmental factors. Product specifications and design are subject to change without notice. Copyright © 2013 Edimax Technology Co. Ltd. All rights reserved. www.edimax.com
EW-7811UTC 价格&库存
很抱歉,暂时无法提供与“EW-7811UTC”相匹配的价格&库存,您可以联系我们找货
