F-Xal4020HC-152ME
F-Xal4020HC-152ME
    JNCOIL(富尔)
    1.5UH ±20%
F-Xal4020HC-152ME 数据手册
Molded Power Inductor Models and Specifications F-XAL4020HC系列一体电感元件 SMT Power Inductors- F-XAL4020HC PRODUCT IDENTIFICATION 产品型号 F-XAL 4020HC - □ □ □ □ Tolerance Inductance Product specification PO-SMT Power Inductors Tolerance: Code 102 103 104 105 106 外观尺寸 Tolerance 1.0µ H 10.0µ H 100.0µ H 1000.0µ H 10000.0µ H Inductance: Code J K L M N Tolerance ±5% ± 10% ± 15% ±20% ±30% SHAPE AND DIMENSIONS F-XAL4020HC系列一体电感元件 SMT Power Inductors- F-XAL4020HC 规格特性 SPECIFICATIONS F-XAL4020系列一体电感元件 SMT Power Inductors- F-XAL4020HC 电气特性 TYPICAL ELECTRICAL CHARACTERISTICS F-XAL4020HC系列一体电感元件 SMT Power Inductors- F-XAL4020HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 PASSED MEASUTEMENT / 通过如下测量 ITEM Test condition Test Result Operating Temperature 操作温度 -40℃~+ 125℃ 5Pcs Passed Storage temperature 储存温度 -55℃~125℃ 5Pcs Passed Rated Current 额定电流 Refer to standard electrical characteristics list 参考标准特性规格表 5Pcs Passed Temperature Rise Test 温升测试 40℃ max.(△t) 40度最大 5Pcs Passed Electrical Performance Test Solder Heat Resistance 耐焊锡热 Solderability Test 端面焊锡性 Appearance:No significant abnormality. In d u cta n ce ch a n g e :W ith in ± 2 0 %. 外观:无显著异常。 电感值:变异性在初始值±20%以内。 More than 90% of the terminal electrode. Should be covered with solder. 端电极之锡覆盖面达90%以上。 Preheat:150℃,60sec. Solder:H63A Solder temperature:260±5℃ Flux for lead free:rosin Dip time:10±0.5sec. 预热:150℃,60sec。 锡炉温度:260±5℃ . 时间:10±0.5sec 助焊剂:rosin. Preheat:125±25℃,60sec. Solder:H63A. Solder temperature:230±5℃ Fiux for lead free:rosin Dip time:4± 1sec. 预热:125±25℃,60sec. 锡炉温度:230±5℃ 时间:4± 1sec. 助焊剂:rosin. A p p e a ra n ce :n o d a m a g e. High Temperature Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 Temperature:85±5℃ . Applied current:rated current. Duration:500 hrs. F-XAL4020HC系列一体电感元件 SMT Power Inductors- F-XAL4020HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 ITEM Test condition A p p e a ra n ce :n o d a m a g e. Humidity Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n ce :n o d a m a g e. Thermal shock 热冲击试验 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n ce :n o d a m a g e. Humidity Resistance 高湿测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线 Test Result Temperature:40±2℃ . Applied current:rated current. Duration:500 hrs. Humidity:90~95%. Condition for 1 cycle S te p 1 :-2 5 ± 2 ℃ ,3 0 ± 3 m in. S te p 2 :R o o m te m p e ra tu re w ith in 1 5 m in . S te p 3 :+ 8 5 ± 5 ℃ ,3 0 ± 3 m in. Step 4: Room temperature within 15 min. Number of cycles 50 Humidity 90~!95%RH. Temperature: 40±5℃ . Applied current:rated current. Duration:500± 12hrs. Measured at room temperature after placing for 2 to 3hrs. 湿度:90~95%RH。 温度:40±5℃ . 须加电流:额定电流。 放置时间:500± 12hrs. 测试结束于室温放置2~3小时,始可测试电气特性。 F-XAL4030HC系列一体电感元件 SMT Power Inductors-F-XAL4030HC PRODUCT IDENTIFICATION 产品型号 F-XAL 4030HC - □ □ □ □ Tolerance Inductance Product specification PO-SMT Power Inductors Tolerance: Code 102 103 104 105 106 外观尺寸 Tolerance 1.0µ H 10.0µ H 100.0µ H 1000.0µ H 10000.0µ H Inductance: Code J K L M N Tolerance ±5% ± 10% ± 15% ±20% ±30% SHAPE AND DIMENSIONS F-XAL4030HC系列一体电感元件 SMT Power Inductors-F-XAL4030HC 规格特性 SPECIFICATIONS F-XAL4030HC系列一体电感元件 SMT Power Inductors-F-XAL4030HC 电气特性 TYPICAL ELECTRICAL CHARACTERISTICS F-XAL4030HC系列一体电感元件 SMT Power Inductors-F-XAL4030HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 PASSED MEASUTEMENT / 通过如下测量 ITEM Test condition Test Result Operating Temperature 操作温度 -40℃~+ 125℃ 5Pcs Passed Storage temperature 储存温度 -55℃~125℃ 5Pcs Passed Rated Current 额定电流 Refer to standard electrical characteristics list 参考标准特性规格表 5Pcs Passed Temperature Rise Test 温升测试 40℃ max.(△t) 40度最大 5Pcs Passed Electrical Performance Test Solder Heat Resistance 耐焊锡热 Solderability Test 端面焊锡性 Appearance:No significant abnormality. In d u cta n ce ch a n g e :W ith in ± 2 0 %. 外观:无显著异常。 电感值:变异性在初始值±20%以内。 More than 90% of the terminal electrode. Should be covered with solder. 端电极之锡覆盖面达90%以上。 Preheat:150℃,60sec. Solder:H63A Solder temperature:260±5℃ Flux for lead free:rosin Dip time:10±0.5sec. 预热:150℃,60sec。 锡炉温度:260±5℃ . 时间:10±0.5sec 助焊剂:rosin. Preheat:125±25℃,60sec. Solder:H63A. Solder temperature:230±5℃ Fiux for lead free:rosin Dip time:4± 1sec. 预热:125±25℃,60sec. 锡炉温度:230±5℃ 时间:4± 1sec. 助焊剂:rosin. A p p e a ra n ce :n o d a m a g e. High Temperature Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 Temperature:85±5℃ . Applied current:rated current. Duration:500 hrs. F-XAL4030HC系列一体电感元件 SMT Power Inductors-F-XAL4030HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 ITEM Test condition A p p e a ra n ce :n o d a m a g e. Humidity Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n ce :n o d a m a g e. Thermal shock 热冲击试验 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n ce :n o d a m a g e. Humidity Resistance 高湿测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线 Test Result Temperature:40±2℃ . Applied current:rated current. Duration:500 hrs. Humidity:90~95%. Condition for 1 cycle S te p 1 :-2 5 ± 2 ℃ ,3 0 ± 3 m in. S te p 2 :R o o m te m p e ra tu re w ith in 1 5 m in . S te p 3 :+ 8 5 ± 5 ℃ ,3 0 ± 3 m in. Step 4: Room temperature within 15 min. Number of cycles 50 Humidity 90~!95%RH. Temperature: 40±5℃ . Applied current:rated current. Duration:500± 12hrs. Measured at room temperature after placing for 2 to 3hrs. 湿度:90~95%RH。 温度:40±5℃ . 须加电流:额定电流。 放置时间:500± 12hrs. 测试结束于室温放置2~3小时,始可测试电气特性。 F-XAL4040HC系列一体电感元件 SMT Power Inductors- F-XAL4040HC PRODUCT IDENTIFICATION 产品型号 F-XAL 4040HC - □ □ □ □ Tolerance Inductance Product specification PO-SMT Power Inductors Tolerance: Code 102 103 104 105 106 外观尺寸 Tolerance 1.0µ H 10.0µ H 100.0µ H 1000.0µ H 10000.0µ H Inductance: Code J K L M N Tolerance ±5% ± 10% ± 15% ±20% ±30% SHAPE AND DIMENSIONS F-XAL4040HC系列一体电感元件 SMT Power Inductors- F-XAL4040HC 规格特性 SPECIFICATIONS F-XAL4040HC系列一体电感元件 SMT Power Inductors- F-XAL-4040HC 电气特性 TYPICAL ELECTRICAL CHARACTERISTICS F-XAL4040HC系列一体电感元件 SMT Power Inductors- F-XAL4040HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 PASSED MEASUTEMENT / 通过如下测量 ITEM Test condition Test Result Operating Temperature 操作温度 -40℃~+ 125℃ 5Pcs Passed Storage temperature 储存温度 -55℃~125℃ 5Pcs Passed Rated Current 额定电流 Refer to standard electrical characteristics list 参考标准特性规格表 5Pcs Passed Temperature Rise Test 温升测试 40℃ max.(△t) 40度最大 5Pcs Passed Electrical Performance Test Solder Heat Resistance 耐焊锡热 Solderability Test 端面焊锡性 Appearance:No significant abnormality. In d u cta n ce ch a n g e :W ith in ± 2 0 %. 外观:无显著异常。 电感值:变异性在初始值±20%以内。 More than 90% of the terminal electrode. Should be covered with solder. 端电极之锡覆盖面达90%以上。 Preheat:150℃,60sec. Solder:H63A Solder temperature:260±5℃ Flux for lead free:rosin Dip time:10±0.5sec. 预热:150℃,60sec。 锡炉温度:260±5℃ . 时间:10±0.5sec 助焊剂:rosin. Preheat:125±25℃,60sec. Solder:H63A. Solder temperature:230±5℃ Fiux for lead free:rosin Dip time:4± 1sec. 预热:125±25℃,60sec. 锡炉温度:230±5℃ 时间:4± 1sec. 助焊剂:rosin. A p p e a ra n ce :n o d a m a g e. High Temperature Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 Temperature:85±5℃ . Applied current:rated current. Duration:500 hrs. F-XAL4040HC系列一体电感元件 SMT Power Inductors- F-XAL4040HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 ITEM Test condition A p p e a ra n ce :n o d a m a g e. Humidity Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n ce :n o d a m a g e. Thermal shock 热冲击试验 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n ce :n o d a m a g e. Humidity Resistance 高湿测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线 Test Result Temperature:40±2℃ . Applied current:rated current. Duration:500 hrs. Humidity:90~95%. Condition for 1 cycle S te p 1 :-2 5 ± 2 ℃ ,3 0 ± 3 m in. S te p 2 :R o o m te m p e ra tu re w ith in 1 5 m in . S te p 3 :+ 8 5 ± 5 ℃ ,3 0 ± 3 m in. Step 4: Room temperature within 15 min. Number of cycles 50 Humidity 90~!95%RH. Temperature: 40±5℃ . Applied current:rated current. Duration:500± 12hrs. Measured at room temperature after placing for 2 to 3hrs. 湿度:90~95%RH。 温度:40±5℃ . 须加电流:额定电流。 放置时间:500± 12hrs. 测试结束于室温放置2~3小时,始可测试电气特性。 F-XAL5020HC系列一体电感元件 SMT Power Inductors- F-XAL5020HC PRODUCT IDENTIFICATION 产品型号 F-XAL 5020HC - □ □ □ □ Tolerance Inductance Product specification PO-SMT Power Inductors Tolerance: Code 102 103 104 105 106 外观尺寸 Tolerance 1.0µ H 10.0µ H 100.0µ H 1000.0µ H 10000.0µ H Inductance: Code J K L M N Tolerance ±5% ± 10% ± 15% ±20% ±30% SHAPE AND DIMENSIONS F-XAL5020HC系列一体电感元件 SMT Power Inductors- F-XAL5020HC 规格特性 SPECIFICATIONS F-XAL5020HC系列一体电感元件 SMT Power Inductors- F-XAL5020HC 电气特性 TYPICAL ELECTRICAL CHARACTERISTICS F-XAL5020HC系列一体电感元件 SMT Power Inductors- F-XAL5020HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 PASSED MEASUTEMENT / 通过如下测量 ITEM Test condition Test Result Operating Temperature 操作温度 -40℃~+ 125℃ 5Pcs Passed Storage temperature 储存温度 -55℃~125℃ 5Pcs Passed Rated Current 额定电流 Refer to standard electrical characteristics list 参考标准特性规格表 5Pcs Passed Temperature Rise Test 温升测试 40℃ max.(△t) 40度最大 5Pcs Passed Electrical Performance Test Solder Heat Resistance 耐焊锡热 Solderability Test 端面焊锡性 Appearance:No significant abnormality. In d u cta n ce ch a n g e :W ith in ± 2 0 %. 外观:无显著异常。 电感值:变异性在初始值±20%以内。 More than 90% of the terminal electrode. Should be covered with solder. 端电极之锡覆盖面达90%以上。 Preheat:150℃,60sec. Solder:H63A Solder temperature:260±5℃ Flux for lead free:rosin Dip time:10±0.5sec. 预热:150℃,60sec。 锡炉温度:260±5℃ . 时间:10±0.5sec 助焊剂:rosin. Preheat:125±25℃,60sec. Solder:H63A. Solder temperature:230±5℃ Fiux for lead free:rosin Dip time:4± 1sec. 预热:125±25℃,60sec. 锡炉温度:230±5℃ 时间:4± 1sec. 助焊剂:rosin. A p p e a ra n c e :n o d a m a g e. High Temperature Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 Temperature:85±5℃ . Applied current:rated current. Duration:500 hrs. F-XAL5020HC系列一体电感元件 SMT Power Inductors- F-XAL5020HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 ITEM Test condition A p p e a ra n c e :n o d a m a g e. Humidity Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n c e :n o d a m a g e. Thermal shock 热冲击试验 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n c e :n o d a m a g e. Humidity Resistance 高湿测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线 Test Result Temperature:40±2℃ . Applied current:rated current. Duration:500 hrs. Humidity:90~95%. Condition for 1 cycle S te p 1 :-2 5 ± 2 ℃ ,3 0 ± 3 m in. S te p 2 :R o o m te m p e ra tu re w ith in 1 5 m in . S te p 3 :+ 8 5 ± 5 ℃ ,3 0 ± 3 m in. Step 4: Room temperature within 15 min. Number of cycles 50 Humidity 90~!95%RH. Temperature: 40±5℃ . Applied current:rated current. Duration:500± 12hrs. Measured at room temperature after placing for 2 to 3hrs. 湿度:90~95%RH。 温度:40±5℃ . 须加电流:额定电流。 放置时间:500± 12hrs. 测试结束于室温放置2~3小时,始可测试电气特性。 F-XAL5030HC系列一体电感元件 SMT Power Inductors- F-XAL5030HC PRODUCT IDENTIFICATION 产品型号 F-XAL 5030HC - □ □ □ □ Tolerance Inductance Product specification PO-SMT Power Inductors Tolerance: Code 102 103 104 105 106 外观尺寸 Tolerance 1.0µ H 10.0µ H 100.0µ H 1000.0µ H 10000.0µ H Inductance: Code J K L M N Tolerance ±5% ± 10% ± 15% ±20% ±30% SHAPE AND DIMENSIONS F-XAL5030HC系列一体电感元件 SMT Power Inductors- F-XAL5030HC 规格特性 SPECIFICATIONS F-XAL5030HC系列一体电感元件 SMT Power Inductors- F-XAL5030HC 电气特性 TYPICAL ELECTRICAL CHARACTERISTICS F-XAL5030HC系列一体电感元件 SMT Power Inductors- F-XAL5030HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 PASSED MEASUTEMENT / 通过如下测量 ITEM Test condition Test Result Operating Temperature 操作温度 -40℃~+ 125℃ 5Pcs Passed Storage temperature 储存温度 -55℃~125℃ 5Pcs Passed Rated Current 额定电流 Refer to standard electrical characteristics list 参考标准特性规格表 5Pcs Passed Temperature Rise Test 温升测试 40℃ max.(△t) 40度最大 5Pcs Passed Electrical Performance Test Solder Heat Resistance 耐焊锡热 Solderability Test 端面焊锡性 Appearance:No significant abnormality. In d u cta n ce ch a n g e :W ith in ± 2 0 %. 外观:无显著异常。 电感值:变异性在初始值±20%以内。 More than 90% of the terminal electrode. Should be covered with solder. 端电极之锡覆盖面达90%以上。 Preheat:150℃,60sec. Solder:H63A Solder temperature:260±5℃ Flux for lead free:rosin Dip time:10±0.5sec. 预热:150℃,60sec。 锡炉温度:260±5℃ . 时间:10±0.5sec 助焊剂:rosin. Preheat:125±25℃,60sec. Solder:H63A. Solder temperature:230±5℃ Fiux for lead free:rosin Dip time:4± 1sec. 预热:125±25℃,60sec. 锡炉温度:230±5℃ 时间:4± 1sec. 助焊剂:rosin. A p p e a ra n ce :n o d a m a g e. High Temperature Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 Temperature:85±5℃ . Applied current:rated current. Duration:500 hrs. F-XAL5030HC系列一体电感元件 SMT Power Inductors- F-XAL5030HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 ITEM Test condition A p p e a ra n ce :n o d a m a g e. Humidity Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n ce :n o d a m a g e. Thermal shock 热冲击试验 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n ce :n o d a m a g e. Humidity Resistance 高湿测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线 Test Result Temperature:40±2℃ . Applied current:rated current. Duration:500 hrs. Humidity:90~95%. Condition for 1 cycle S te p 1 :-2 5 ± 2 ℃ ,3 0 ± 3 m in. S te p 2 :R o o m te m p e ra tu re w ith in 1 5 m in . S te p 3 :+ 8 5 ± 5 ℃ ,3 0 ± 3 m in. Step 4: Room temperature within 15 min. Number of cycles 50 Humidity 90~!95%RH. Temperature: 40±5℃ . Applied current:rated current. Duration:500± 12hrs. Measured at room temperature after placing for 2 to 3hrs. 湿度:90~95%RH。 温度:40±5℃ . 须加电流:额定电流。 放置时间:500± 12hrs. 测试结束于室温放置2~3小时,始可测试电气特性。 F-XAL5050HC系列一体电感元件 SMT Power Inductors- F-XAL5050HC PRODUCT IDENTIFICATION 产品型号 F-XAL 5050HC - □ □ □ □ Tolerance Inductance Product specification PO-SMT Power Inductors Tolerance: Code 102 103 104 105 106 外观尺寸 Tolerance 1.0µ H 10.0µ H 100.0µ H 1000.0µ H 10000.0µ H Inductance: Code J K L M N Tolerance ±5% ± 10% ± 15% ±20% ±30% SHAPE AND DIMENSIONS F-XAL5050HC系列一体电感元件 SMT Power Inductors- F-XAL5050HC 规格特性 SPECIFICATIONS F-XAL5050HC系列一体电感元件 SMT Power Inductors- F-XAL5050HC 电气特性 . TYPICAL ELECTRICAL CHARACTERISTICS F-XAL5050HC系列一体电感元件 SMT Power Inductors- F-XAL5050HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 PASSED MEASUTEMENT / 通过如下测量 ITEM Test condition Test Result Operating Temperature 操作温度 -40℃~+ 125℃ 5Pcs Passed Storage temperature 储存温度 -55℃~125℃ 5Pcs Passed Rated Current 额定电流 Refer to standard electrical characteristics list 参考标准特性规格表 5Pcs Passed Temperature Rise Test 温升测试 40℃ max.(△t) 40度最大 5Pcs Passed Electrical Performance Test Solder Heat Resistance 耐焊锡热 Solderability Test 端面焊锡性 Appearance:No significant abnormality. In d u cta n ce ch a n g e :W ith in ± 2 0 %. 外观:无显著异常。 电感值:变异性在初始值±20%以内。 More than 90% of the terminal electrode. Should be covered with solder. 端电极之锡覆盖面达90%以上。 Preheat:150℃,60sec. Solder:H63A Solder temperature:260±5℃ Flux for lead free:rosin Dip time:10±0.5sec. 预热:150℃,60sec。 锡炉温度:260±5℃ . 时间:10±0.5sec 助焊剂:rosin. Preheat:125±25℃,60sec. Solder:H63A. Solder temperature:230±5℃ Fiux for lead free:rosin Dip time:4± 1sec. 预热:125±25℃,60sec. 锡炉温度:230±5℃ 时间:4± 1sec. 助焊剂:rosin. A p p e a ra n ce :n o d a m a g e. High Temperature Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 Temperature:85±5℃ . Applied current:rated current. Duration:500 hrs. F-XAL5050HC系列一体电感元件 SMT Power Inductors- F-XAL5050HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 ITEM Test condition A p p e a ra n ce :n o d a m a g e. Humidity Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n ce :n o d a m a g e. Thermal shock 热冲击试验 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n ce :n o d a m a g e. Humidity Resistance 高湿测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线 Test Result Temperature:40±2℃ . Applied current:rated current. Duration:500 hrs. Humidity:90~95%. Condition for 1 cycle S te p 1 :-2 5 ± 2 ℃ ,3 0 ± 3 m in. S te p 2 :R o o m te m p e ra tu re w ith in 1 5 m in . S te p 3 :+ 8 5 ± 5 ℃ ,3 0 ± 3 m in. Step 4: Room temperature within 15 min. Number of cycles 50 Humidity 90~!95%RH. Temperature: 40±5℃ . Applied current:rated current. Duration:500± 12hrs. Measured at room temperature after placing for 2 to 3hrs. 湿度:90~95%RH。 温度:40±5℃ . 须加电流:额定电流。 放置时间:500± 12hrs. 测试结束于室温放置2~3小时,始可测试电气特性。 F-XAL6020HC系列一体电感元件 SMT Power Inductors- F-XAL6020HC PRODUCT IDENTIFICATION 产品型号 F-XAL 6020HC - □ □ □ □ Tolerance Inductance Product specification PO-SMT Power Inductors Tolerance: Code 102 103 104 105 106 外观尺寸 Tolerance 1.0µ H 10.0µ H 100.0µ H 1000.0µ H 10000.0µ H Inductance: Code J K L M N Tolerance ±5% ± 10% ± 15% ±20% ±30% SHAPE AND DIMENSIONS F-XAL6020HC系列一体电感元件 SMT Power Inductors- F-XAL6020HC 规格特性 SPECIFICATIONS F-XAL6020HC系列一体电感元件 SMT Power Inductors- F-XAL6020HC 电气特性 TYPICAL ELECTRICAL CHARACTERISTICS F-XAL6020HC系列一体电感元件 SMT Power Inductors- F-XAL6020HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 PASSED MEASUTEMENT / 通过如下测量 ITEM Test condition Test Result Operating Temperature 操作温度 -40℃~+ 125℃ 5Pcs Passed Storage temperature 储存温度 -55℃~125℃ 5Pcs Passed Rated Current 额定电流 Refer to standard electrical characteristics list 参考标准特性规格表 5Pcs Passed Temperature Rise Test 温升测试 40℃ max.(△t) 40度最大 5Pcs Passed Electrical Performance Test Solder Heat Resistance 耐焊锡热 Solderability Test 端面焊锡性 Appearance:No significant abnormality. In d u cta n ce ch a n g e :W ith in ± 2 0 %. 外观:无显著异常。 电感值:变异性在初始值±20%以内。 More than 90% of the terminal electrode. Should be covered with solder. 端电极之锡覆盖面达90%以上。 Preheat:150℃,60sec. Solder:H63A Solder temperature:260±5℃ Flux for lead free:rosin Dip time:10±0.5sec. 预热:150℃,60sec。 锡炉温度:260±5℃ . 时间:10±0.5sec 助焊剂:rosin. Preheat:125±25℃,60sec. Solder:H63A. Solder temperature:230±5℃ Fiux for lead free:rosin Dip time:4± 1sec. 预热:125±25℃,60sec. 锡炉温度:230±5℃ 时间:4± 1sec. 助焊剂:rosin. A p p e a ra n c e :n o d a m a g e. High Temperature Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 Temperature:85±5℃ . Applied current:rated current. Duration:500 hrs. F-XAL6020HC系列一体电感元件 SMT Power Inductors- F-XAL6020HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 ITEM Test condition A p p e a ra n c e :n o d a m a g e. Humidity Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n c e :n o d a m a g e. Thermal shock 热冲击试验 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n c e :n o d a m a g e. Humidity Resistance 高湿测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线 Test Result Temperature:40±2℃ . Applied current:rated current. Duration:500 hrs. Humidity:90~95%. Condition for 1 cycle S te p 1 :-2 5 ± 2 ℃ ,3 0 ± 3 m in. S te p 2 :R o o m te m p e ra tu re w ith in 1 5 m in . S te p 3 :+ 8 5 ± 5 ℃ ,3 0 ± 3 m in. Step 4: Room temperature within 15 min. Number of cycles 50 Humidity 90~!95%RH. Temperature: 40±5℃ . Applied current:rated current. Duration:500± 12hrs. Measured at room temperature after placing for 2 to 3hrs. 湿度:90~95%RH。 温度:40±5℃ . 须加电流:额定电流。 放置时间:500± 12hrs. 测试结束于室温放置2~3小时,始可测试电气特性。 F-XAL6030HC系列一体电感元件 SMT Power Inductors- F-XAL6030HC PRODUCT IDENTIFICATION 产品型号 X-FAL 6030HC - □ □ □ □ Tolerance Inductance Product specification PO-SMT Power Inductors Tolerance: Code 102 103 104 105 106 外观尺寸 Tolerance 1.0µ H 10.0µ H 100.0µ H 1000.0µ H 10000.0µ H Inductance: Code J K L M N Tolerance ±5% ± 10% ± 15% ±20% ±30% SHAPE AND DIMENSIONS F-XAL6030HC系列一体电感元件 SMT Power Inductors- F-XAL6030HC 规格特性 SPECIFICATIONS F-XAL6030HC系列一体电感元件 SMT Power Inductors- F-XAL6030HC 电气特性 TYPICAL ELECTRICAL CHARACTERISTICS F-XAL6030HC系列一体电感元件 SMT Power Inductors- F-XAL6030HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 PASSED MEASUTEMENT / 通过如下测量 ITEM Test condition Test Result Operating Temperature 操作温度 -40℃~+ 125℃ 5Pcs Passed Storage temperature 储存温度 -55℃~125℃ 5Pcs Passed Rated Current 额定电流 Refer to standard electrical characteristics list 参考标准特性规格表 5Pcs Passed Temperature Rise Test 温升测试 40℃ max.(△t) 40度最大 5Pcs Passed Electrical Performance Test Solder Heat Resistance 耐焊锡热 Solderability Test 端面焊锡性 Appearance:No significant abnormality. In d u cta n ce ch a n g e :W ith in ± 2 0 %. 外观:无显著异常。 电感值:变异性在初始值±20%以内。 More than 90% of the terminal electrode. Should be covered with solder. 端电极之锡覆盖面达90%以上。 Preheat:150℃,60sec. Solder:H63A Solder temperature:260±5℃ Flux for lead free:rosin Dip time:10±0.5sec. 预热:150℃,60sec。 锡炉温度:260±5℃ . 时间:10±0.5sec 助焊剂:rosin. Preheat:125±25℃,60sec. Solder:H63A. Solder temperature:230±5℃ Fiux for lead free:rosin Dip time:4± 1sec. 预热:125±25℃,60sec. 锡炉温度:230±5℃ 时间:4± 1sec. 助焊剂:rosin. A p p e a ra n c e :n o d a m a g e. High Temperature Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 Temperature:85±5℃ . Applied current:rated current. Duration:500 hrs. F-XAL6030HC系列一体电感元件 SMT Power Inductors- F-XAL6030HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 ITEM Test condition A p p e a ra n c e :n o d a m a g e. Humidity Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n c e :n o d a m a g e. Thermal shock 热冲击试验 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n c e :n o d a m a g e. Humidity Resistance 高湿测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线 Test Result Temperature:40±2℃ . Applied current:rated current. Duration:500 hrs. Humidity:90~95%. Condition for 1 cycle S te p 1 :-2 5 ± 2 ℃ ,3 0 ± 3 m in. S te p 2 :R o o m te m p e ra tu re w ith in 1 5 m in . S te p 3 :+ 8 5 ± 5 ℃ ,3 0 ± 3 m in. Step 4: Room temperature within 15 min. Number of cycles 50 Humidity 90~!95%RH. Temperature: 40±5℃ . Applied current:rated current. Duration:500± 12hrs. Measured at room temperature after placing for 2 to 3hrs. 湿度:90~95%RH。 温度:40±5℃ . 须加电流:额定电流。 放置时间:500± 12hrs. 测试结束于室温放置2~3小时,始可测试电气特性。 F-XAL6060HC系列一体电感元件 SMT Power Inductors-F-XAL6060HC PRODUCT IDENTIFICATION 产品型号 F-XAL 6060HC - □ □ □ □ Tolerance Inductance Product specification PO-SMT Power Inductors Tolerance: Code 102 103 104 105 106 外观尺寸 Tolerance 1.0µ H 10.0µ H 100.0µ H 1000.0µ H 10000.0µ H Inductance: Code J K L M N Tolerance ±5% ± 10% ± 15% ±20% ±30% SHAPE AND DIMENSIONS F-XAL6060HC系列一体电感元件 SMT Power Inductors-F-XAL6060HC 规格特性 SPECIFICATIONS F-XAL6060HC系列一体电感元件 SMT Power Inductors-F-XAL6060HC 电气特性 TYPICAL ELECTRICAL CHARACTERISTICS F-XAL6060HC系列一体电感元件 SMT Power Inductors-F-XAL6060HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 PASSED MEASUTEMENT / 通过如下测量 ITEM Test condition Test Result Operating Temperature 操作温度 -40℃~+ 125℃ 5Pcs Passed Storage temperature 储存温度 -55℃~125℃ 5Pcs Passed Rated Current 额定电流 Refer to standard electrical characteristics list 参考标准特性规格表 5Pcs Passed Temperature Rise Test 温升测试 40℃ max.(△t) 40度最大 5Pcs Passed Electrical Performance Test Solder Heat Resistance 耐焊锡热 Solderability Test 端面焊锡性 Appearance:No significant abnormality. In d u cta n ce ch a n g e :W ith in ± 2 0 %. 外观:无显著异常。 电感值:变异性在初始值±20%以内。 More than 90% of the terminal electrode. Should be covered with solder. 端电极之锡覆盖面达90%以上。 Preheat:150℃,60sec. Solder:H63A Solder temperature:260±5℃ Flux for lead free:rosin Dip time:10±0.5sec. 预热:150℃,60sec。 锡炉温度:260±5℃ . 时间:10±0.5sec 助焊剂:rosin. Preheat:125±25℃,60sec. Solder:H63A. Solder temperature:230±5℃ Fiux for lead free:rosin Dip time:4± 1sec. 预热:125±25℃,60sec. 锡炉温度:230±5℃ 时间:4± 1sec. 助焊剂:rosin. A p p e a ra n c e :n o d a m a g e. High Temperature Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 Temperature:85±5℃ . Applied current:rated current. Duration:500 hrs. F-XAL6060HC系列一体电感元件 SMT Power Inductors-F-XAL6060HC TYPICAL ELECTRICAL CHARACTERISTICS 电气特性 ITEM Test condition A p p e a ra n c e :n o d a m a g e. Humidity Resistance Test 高温放置测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n c e :n o d a m a g e. Thermal shock 热冲击试验 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线。 A p p e a ra n c e :n o d a m a g e. Humidity Resistance 高湿测试 Inductance:within±20% of initial value NO disconnection or short circuit. 外观不能破损。 电感值:变异值在初始值20%以内。 电性无短路或断线 Test Result Temperature:40±2℃ . Applied current:rated current. Duration:500 hrs. Humidity:90~95%. Condition for 1 cycle S te p 1 :-2 5 ± 2 ℃ ,3 0 ± 3 m in. S te p 2 :R o o m te m p e ra tu re w ith in 1 5 m in . S te p 3 :+ 8 5 ± 5 ℃ ,3 0 ± 3 m in. Step 4: Room temperature within 15 min. Number of cycles 50 Humidity 90~!95%RH. Temperature: 40±5℃ . Applied current:rated current. Duration:500± 12hrs. Measured at room temperature after placing for 2 to 3hrs. 湿度:90~95%RH。 温度:40±5℃ . 须加电流:额定电流。 放置时间:500± 12hrs. 测试结束于室温放置2~3小时,始可测试电气特性。
F-Xal4020HC-152ME 价格&库存
很抱歉,暂时无法提供与“F-Xal4020HC-152ME”相匹配的价格&库存,您可以联系我们找货
