HMS J11 F5.5
HMS J11 F5.5
    HEIMANNSENSOR(海曼)
    Through Hole
    HMS J11 F5.5
HMS J11 F5.5 数据手册
Product Specification: Thermopile Sensor HMS J11 F5.5 HEIMANN Sensor GmbH Author(s): W. Leneke, M. Simon Rev.: R 04 / 09.02.2015 Page 1 of 6 Specification Thermopile Sensor HMS J11 F5.5 Part No. 1001 R 04 Author(s): W. Leneke M. Simon Revision History Version Date Remarks R 01 10.08.2005 1. Draft of Heimann Sensor GmbH R 02 15.12.2006 Add further parameter R 03 02.08.2010 Update §7 R 04 09.02.2015 Update conditions Spec_ThermopileSensor_HMS-J11-F5.5_R04_PN1001.docx © HEIMANN Sensor GmbH Product Specification: Thermopile Sensor HMS J11 F5.5 HEIMANN Sensor GmbH Author(s): W. Leneke, M. Simon Rev.: R 04 / 09.02.2015 Page 2 of 6 TABLE OF CONTENTS 1. Purpose, Scope .................................................................................................. 2 2. Absolute Maximum Ratings .............................................................................. 2 3. General and Electrical Parameter Thermopile ................................................ 2 4. General and Electrical Parameter Thermistor ................................................. 3 5. Filter Characteristics ......................................................................................... 4 6. Drawing and Pin Assignment ........................................................................... 5 7. General Directions for Further Processing ..................................................... 6 8. Liability ............................................................................................................... 6 1. Purpose, Scope The new thermopile infrared sensor from Heimann Sensor, comprising a new type CMOS compatible sensor chip plus a thermistor reference chip, features good sensitivity, small temperature coefficient of sensitivity as well as high reproducibility and reliability. The sensor meets the requirements of the European Union RoHS (Regulation of Hazardous Substances) Directive. The sensor will be available in standard transistor outline packages in different sizes, equipped with an IR transmitting filter window (transmission curve as shown below). 2. Absolute Maximum Ratings Parameter Symbol Limits Min Typ. Units Conditions Max storage temperature * -40 100 °C operating temperature -20 100 °C * … see also §7 3. General and Electrical Parameter Thermopile Parameter Symbol Limits Min element size Typ. Units Conditions mm2 absorbing area -40°C to 100°C Max 0.6*0.6 resistance RTS 56 86 116 k voltage sensitivity SV 20 35 50 V/W 6 10 ms time constant  noise voltage VRMS 38 * detectivity D insulation resistance Riso nV/Hz 7 5.5*10 5 Spec_ThermopileSensor_HMS-J11-F5.5_R04_PN1001.docx cmHz/W GΩ filter F5.5, 350°C, 4.5 Hz r.m.s., 25°C filter F5.5, 350°C, 4.5 Hz 10V, 25°C, 60% r.h., between pin 1 or 3 and 4 (ground) © HEIMANN Sensor GmbH Product Specification: Thermopile Sensor HMS J11 F5.5 HEIMANN Sensor GmbH Author(s): W. Leneke, M. Simon Rev.: R 04 / 09.02.2015 Page 3 of 6 4. General and Electrical Parameter Thermistor Type Thermistor 100k Parameter resistance BETA-value Symbol Limits Units Min Typ. Max RTH 95 100 105 k  3900 3940 3980 K Conditions 25°C 25°C/50°C T / °C Rth_min / Ohm Rth_nom / Ohm Rth_max / Ohm -30 1557900 1655000 1753100 -25 1163320 1234000 1306680 -20 875826 928700 981974 -15 665010 704500 744190 -10 508730 538500 568370 -5 392108 414600 437292 0 304466 321700 338934 5 238072 251400 264728 10 187444 197800 208056 15 148568 156600 164632 20 118404 124800 131096 25 95000 100000 105000 30 76537 80630 84713 35 62032 65380 68738 40 50543 53310 56077 45 41386 43680 45984 50 34070 35980 37890 55 28174 29770 31366 60 23405 24750 26095 65 19536 20670 21804 70 16383 17340 18297 75 13788 14600 15422 80 11653 12350 13047 85 9890 10480 11080 90 8421 8930 9444 95 7197 7635 8076 100 6172 6551 6935 Spec_ThermopileSensor_HMS-J11-F5.5_R04_PN1001.docx © HEIMANN Sensor GmbH Product Specification: Thermopile Sensor HMS J11 F5.5 HEIMANN Sensor GmbH Author(s): W. Leneke, M. Simon Rev.: R 04 / 09.02.2015 Page 4 of 6 5. Filter Characteristics Filter F5.5 Limits Typ Max Parameter Min 70 average transmission average transmission cut on filter thickness filter material 1 5.5 5.8 0.525 silicon coated 5.2 Units Conditions % % µm 7.5µm to 13.5µm visual to 5µm 25°C 100 90 80 Transmission [%] 70 60 50 40 30 20 10 0 2 4 6 8 10 12 14 16 18 20 Wavelength [µm] Spec_ThermopileSensor_HMS-J11-F5.5_R04_PN1001.docx © HEIMANN Sensor GmbH 22 Product Specification: Thermopile Sensor HMS J11 F5.5 HEIMANN Sensor GmbH Author(s): W. Leneke, M. Simon Rev.: R 04 / 09.02.2015 Page 5 of 6 6. Drawing and Pin Assignment Spec_ThermopileSensor_HMS-J11-F5.5_R04_PN1001.docx © HEIMANN Sensor GmbH Product Specification: Thermopile Sensor HMS J11 F5.5 HEIMANN Sensor GmbH Author(s): W. Leneke, M. Simon Rev.: R 04 / 09.02.2015 Page 6 of 6 7. General Directions for Further Processing Stresses above the absolute maximum ratings may cause damages to the device. The sensor can be damaged by electrostatic discharges. Please take appropriate precautions for the handling. Do not expose the sensors to aggressive detergents. Windows may be cleaned with alcohol and cotton swab. Hand soldering and / or wave soldering may be applied by a maximum temperature of 280°C for a dwell time less than 10s. Avoid heat exposure to the top and the window of the detector. Reflow soldering is not recommended. The minimum distance between the housing body and the liquid solder should be at least 0.6mm. Storage: 1) Parts are to be stored indoors in the original packing. 2) Storage Temperature should be from +5°C to +40°C Recommended: 20 to 30°C). 3) A maximum of 60% Relative Humidity (Recommended: 40 to 60% RH). Shelf Life: Heimann Sensor recommends the properly stored components be used within one years of receipt to guarantee a good solderability. 8. Liability Important product or process changes require a customer release. Changes or modifications at the product which haven't influence to the performance and/or quality of the device haven't to be announced to the customers in advance. Customers are requested to consult with Heimann Sensor representatives before the use of Heimann Sensor products in special applications where failure or abnormal operation may directly affect human lives or cause physical injury or property damage. The company or their representatives will not be responsible for damage arising from such use without prior approval. Spec_ThermopileSensor_HMS-J11-F5.5_R04_PN1001.docx © HEIMANN Sensor GmbH
HMS J11 F5.5 价格&库存
很抱歉,暂时无法提供与“HMS J11 F5.5”相匹配的价格&库存,您可以联系我们找货
