深 圳 市 毫 欧 电 子 有 限公 司
承
认
书
SPECIFICATION FOR APPROVAL
深圳市毫欧电子有限公司
Product Name : Medium Voltage Multilayer Ceramic Chip Capacitors
Part No. : FM Series
Description : Size 0402~2225, C0G/X7R/Y5V, 100Vdc~630Vdc
SPEC. No. : FM-000-001-15
DATE : 2021/11/30
APPROVAL
MAKE
YongKangHuang
CHECK
ZhiMinZheng
Address: Factory no.1 801, 280-1, Dabutou Village, Songyuansha Community, Guanhu Street,
Longhua District, Shenzhen
1. INTRODUCTION
FM Series green type capacitors are manufactured by using green materials without lead and cadmium.
These capacitors feature series connection of multi-layer capacitor units in a MLCC to realize high voltage
performance. Reliable performances are built-in through exact formulation of dielectric powders, preparation of
conductive paste, advanced automatic manufacturing, and strict quality control to assure excellent control in
dielectric thickness, electrode integrity, and electrode-to-termination continuity.
2. FEATURES
3. APPLICATIONS
a. Medium voltage in a given case size.
b. High reliability and stability.
c. RoHS compliant.
a.
b.
c.
d.
DC to DC converter.
High voltage coupling/DC blocking.
Back-lighting inverters.
Snubbers in high frequency power converters.
4. HOW TO ORDER
FM
PDC
Family
Table 1
31
X
Size
471
K
251
Rated
Voltage
Table 6
Dielectric Capacitance Tolerance
Table 2
Table 3
Table 4
Table 5
P
X
G
Control
Code
Table 9
Packaging Thickness
Table 7
Table 6
Table 8
Table 1
PDC Family
Code
Description
Code
Description
Code
Description
Code
Description
FM
100V≤Rated Voltage≤630V series
101
100Vdc
251
250Vdc
501
500Vdc
201
200Vdc
401
400Vdc
631
630Vdc
Table 2
Size
Code
Description
Code
Description
Code
Description
15
0402 (1005)
32
1210 (3225)
52
2211 (5728)
18
21
0603 (1608)
0805 (2012)
42
43
1808 (4520)
1812 (4532)
55
56
2220 (5750)
2225 (5763)
31
1206 (3216)
46
1825 (4563)
Table 3
Table 7
Dielectric Material Characteristics
Code
Description
Code
Description
N
F
C0G
Y5V
X
X7R
Table 4
Rated Voltage
Capacitance Rule Code
Packaging Type
Code
Description
Code
Description
B
Bulk
T
Tray package
E
K
L
Tape and 7” Reel, Embossed Tape
Tape and 10” Reel, Embossed Tape
P
D
G
Tape and 10” Reel, Paper Tape
Tape and 13” Reel, Embossed Tape
Table 8
Tape and 7” Reel, Paper Tape
Tape and 13” Reel, Paper Tape
Thickness Description
Code
Description
Code
Description
Code
Description
Code
Description
Code
Description
R47
0.47pF
102
102=10x102=1000pF
A
0.60 ± 0.10 mm
I
1.25 ± 0.20 mm
Q
0.50 +0.02/-0.05 mm
0R5
100
0.5pF
100=10x100=10pF
104
106
104=10x104=100nF
106=10x106=10µF
B
C
0.8 + 0.15/-0.10 mm
J
K
1.15 ± 0.15 mm
0.50 ± 0.20 mm
R
S
3.10 ± 0.30 mm
1.25 ± 0.10 mm
D
1.40 ± 0.15 mm
L
0.30 ± 0.03 mm
T
0.85 ± 0.10 mm
E
1.60 ± 0.20 mm
M
0.95 ± 0.10 mm
U
0.50 ± 0.10 mm
F
G
2.00 ± 0.20 mm
0.50 ± 0.05 mm
2.50 ± 0.30 mm
N
O
3.50 ± 0.20 mm
V
X
0.80 ± 0.10 mm
H
2.80 ± 0.30 mm
P
1.60 +0.3/-0.10 mm
Z
0.25 ± 0.03 mm
Table 5
Tolerance
Code
Description
Code
Description
Code
Description
A
±0.05 pF
J
±5 %
X
+10%~+20%
B
±0.10 pF
K
±10 %
C
±0.25 pF
L
0% ~ +10%
D
F
±0.50 pF
±1 %
M
N
±20 %
-5% ~ +10%
Table 9
Code
Description
G
H
I
±2 %
±3 %
-10% ~ 0%
P
Q
Z
±0.02 pF
±0.03 pF
-20% ~ +80%
G
Q
O
RoHS Compliant
Surface Coating (Size 1206~2225)
Gold plating (Size≥0603)
Special Control Code
0.80 ± 0.07 mm
0.20 ± 0.02 mm
5. EXTERNAL DIMENSIONS
Size Inch
(mm)
L
(mm)
W
(mm)
0402(1005)
1.00±0.10
0.50±0.10
0603(1608)
0805(2012)
1.60±0.15
2.00±0.20
3.20±0.20
0.80±0.15
1.25±0.20
1.60±0.20
3.20 +0.30/-0.10#
1.60 +0.30/-0.10#
3.20±0.30
4.50±0.40
4.50±0.40
4.50±0.40
5.70±0.40
5.70±0.40
2.50±0.30
2.00±0.25
3.20±0.30
6.30±0.40
5.00±0.40
6.30±0.40
1206(3216)
1210(3225)
1808(4520)
1812(4532)
1825(4563)
2220(5750)
2225(5763)
Code / T
(mm)
MB
(mm)
0.25
+0.05/-0.10
0.40±0.15
0.50±0.20
See
No.4
Reference
Table 8
L
T
0.60±0.20
W
0.75±0.35
0.75±0.35
0.75±0.35
0.75±0.35
0.85±0.35
0.85±0.35
MB
MB
Fig. 5.1 The outline of MLCC
“#”For 1206 size P thickness products.
6. GENERAL ELECTRICAL DATA
Dielectric
Size
Rated voltage
(WVDC)
Capacitance range
Capacitance
tolerance
Tan δ
C0G
X7R
Y5V
0402, 0603, 0805, 1206, 1210,
1808, 1812, 1825, 2220, 2225
0805, 1206,
1210, 1812
100V, 200V, 250V, 500V, 630V
100V, 200V, 250V
0.5pF ~ 100nF
100pF ~ 820nF
10nF to 680nF
Reference to Table5
Reference to Table5
Reference to Table5
≤2.5% ~ ≤10.0%
≤5.0%
Cap. Rang
Q Spec.
Cap.1000pF 1.0±0.2Vrms, 1.0KHz±10%
temperature
Insulation
resistance at Ur
Operating
temperature
Capacitance
characteristic
Termination
≥10GΩ or RxC≥500Ω-F,
whichever is smaller
≥10GΩ or RxC≥100Ω-F,
-55 to +125°C
±30ppm/°C
-25 to +85°C
±15%
+30/-80%
Cu or Ag/Ni/Sn or Au (lead-free termination)
7. CAPACITANCE RANGE
7-1. C0G
Dimension
Cap(pF) code
0.5
0R5
1.0
1R0
1.2
1R2
1.5
1R5
1.8
1R8
2.2
2R2
2.7
2R7
3.3
3R3
3.9
3R9
4.7
4R7
5.6
5R6
6.8
6R8
8.2
8R2
10
100
12
120
15
150
18
180
22
220
27
270
33
330
39
390
47
470
56
560
68
680
82
820
100
101
120
121
150
151
180
181
220
221
270
271
330
331
390
391
470
471
560
561
680
681
820
821
1000
102
1200
122
1500
152
1800
182
2200
222
2700
272
3300
332
3900
392
4700
472
5600
562
6800
682
8200
822
10000
103
12000
123
15000
153
18000
183
22000
223
27000
273
33000
333
100V
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
0402
200V
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
250V
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
100V
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
B
B
0603
200V
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
B
B
B
B
B
250V
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
B
B
B
B
B
100V
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
X
X
X
X
X
X
X
X
X
X
C
C
C
C
C
C
200V
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
X
X
C
C
C
C
C
C
C
C
C
C
C
C
C
C
0805
250V
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
X
X
X
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
500V
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
X
X
C
C
C
C
C
C
C
I
I
I
I
I
630V
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
X
X
C
C
C
C
C
C
C
I
I
I
I
I
100V
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
M
M
C
C
C
E
E
E
E
P
P
P
P
200V
1206
250V
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
M
M
M
M
M
M
C
C
C
C
C
E
E
E
E
E
E
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
M
M
M
M
C
C
E
E
E
E
E
E
E
E
E
E
E
E
E
E
500V
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
M
M
M
M
C
C
E
E
E
E
E
E
E
E
E
E
E
E
630V
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
M
M
M
M
C
C
E
E
E
E
E
E
E
E
E
E
7-1. C0G
Dimension
Cap(pF)
code
2.2
2R2
2.7
2R7
3.3
3R3
3.9
3R9
4.7
4R7
5.6
5R6
6.8
6R8
8.2
8R2
10
100
12
120
15
150
18
180
22
220
27
270
33
330
39
390
47
470
56
560
68
680
82
820
100
101
120
121
150
151
180
181
220
221
270
271
330
331
390
391
470
471
560
561
680
681
820
821
1000
102
1200
122
1500
152
1800
182
2200
222
2700
272
3300
332
3900
392
4700
472
5600
562
6800
682
8200
822
10000
103
12000
123
15000
153
18000
183
22000
223
27000
273
33000
333
39000
393
47000
473
56000
563
68000
683
82000
823
100000
104
100V
200V
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
C
C
C
E
E
F
F/G
F/G
F
F
F
F
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
C
C
C
C
C
C
C
C
E
E
E
E
F
F
G
G
G
1210
250V
500V
630V
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
C
C
C
C
C
C
C
C
E
E
E
E
F
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
C
C
C
C
C
C
C
C
C
C
E
E
F
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
C
C
C
C
C
C
C
C
C
C
E
E
F
100V
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
E
E
200V
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
E
E
F
F
1808
250V
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
E
E
F
F
500V
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
F
F
F
F
F
F
F
F
F
F
F
F
F
F
630V
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
F
F
F
F
F
F
F
F
F
F
F
F
F
F
100V
200V
1812
250V
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
E
E
F
F
G
G
G
G
G
G
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
E
E
F
F
G
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
E
E
F
F
G
500V
630V
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
E
E
F
F
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
E
E
F
F
7-1. C0G
Dimension
Cap(pF)
code
100V
200V
1825
250V
500V
630V
100V
200V
2220
250V
500V
630V
100V
200V
2225
250V
500V
630V
10
12
15
18
22
27
100
120
150
180
220
270
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
33
39
47
56
68
82
330
390
470
560
680
820
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
100
120
150
180
220
270
101
121
151
181
221
271
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
330
390
470
560
680
820
331
391
471
561
681
821
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
1000
1200
1500
1800
2200
2700
102
122
152
182
222
272
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
3300
3900
4700
5600
6800
8200
332
392
472
562
682
822
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
10000
12000
15000
18000
22000
27000
103
123
153
183
223
273
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
33000
39000
47000
56000
68000
82000
333
393
473
563
683
823
F
F
F
F
F
G
F
F
F
G
G
F
F
F
G
G
F
F
F
F
F
F
F
G
F
F
G
G
G
F
F
G
G
G
F
G
G
F
F
F
F
F
F
F
F
F
G
G
G
F
F
F
G
G
G
F
F
F
G
G
G
F
F
F
G
G
100000
120000
150000
180000
220000
104
124
154
184
224
G
G
G
G
G
7-2. X7R
Dimension
0402
0603
0805
1206
Cap(pF)
code
100V
100V
200V
250V
100V
200V
250V
500V
630V
100V
200V
250V
500V
630V
100
101
N
S
B
B
X
X
X
X
X
X
C
C
C
C
120
121
N
S
B
B
X
X
X
X
X
X
C
C
C
C
150
151
N
S
B
B
X
X
X
X
X
X
C
C
C
C
180
181
N
S
B
B
X
X
X
X
X
X
C
C
C
C
220
221
N
S
B
B
X
X
X
X
X
X
C
C
C
C
270
271
N
S
B
B
X
X
X
X
X
X
C
C
C
C
330
331
N
S
B
B
X
X
X
X
X
X
C
C
C
C
390
391
N
S
B
B
X
X
X
X
X
X
C
C
C
C
470
471
N
S
B
B
X
X
X
X
X
X
C
C
C
C
560
561
N
S
B
B
X
X
X
X
X
X
C
C
C
C
680
681
N
S
B
B
X
X
X
X
X
X
C
C
C
C
820
821
N
S
B
B
X
X
X
X
X
X
C
C
C
C
1000
102
N
S
B
B
X
X
X
X
X
X
C
C
C
C
1200
122
N
S
B
B
X
X
X
X
X
X
C
C
C
C
1500
152
N
S
B
B
X
X
X
X
X
X
C
C
C
C
1800
182
N
S
B
B
X
X
X
X
X
X
C
C
C
C
2200
222
N
S
B
B
X
X
X
X
X
X
C
C
C
C
2700
272
N
S
B
B
X
X
X
X
X
X
C
C
C
C
3300
332
N
S
B
B
X
X
X
X
X
X
C
C
C
C
3900
392
N
S
B
B
X
X
X
X
X
X
C
C
C
C
4700
472
N
S
B
B
X
X
X
C
C
X
C
C
C
C
5600
562
S
B
B
X
X
X
C
C
X
C
C
C
C
6800
682
S
B
B
X
X
X
C
C
X
C
C
C
C
8200
822
S
B
B
X
X
X
C
C
X
C
C
C
C
10000
103
S
B
B
X
C
C
C
C
X
C
C
C
C
12000
123
B
X
C
C
C
C
X
C
C
C
C
15000
153
B
X
C
C
C
C
X
C
C
C
C
18000
183
B
X
C
C
C
C
X
C
C
C
C
22000
223
B
X
C
C
C
C
X
C
C
E
E
27000
273
B
C
C
C
C
C
X
C
C
E
E
33000
333
B
C
C
C
C
X
E
E
E
E
39000
393
B
C
C
C
X
E
E
E
E
47000
473
B
C
C
C
X
E
E
E
E
56000
563
B
C
C
C
X
E
E
E
E
68000
683
B
C
C
C
X
E
E
82000
823
B
C
C
C
E
E
100000
104
B
C
C
C
E
E
120000
124
I
C
E
E
150000
154
I
E
E
E
180000
184
I
E
E
E
220000
224
I
E
E
E
270000
274
I
E
330000
334
I
E
390000
394
I
E
470000
474
I
E
560000
564
P
680000
684
P
820000
824
P
7-2. X7R
Dimension
Cap(pF)
code
100
101
120
121
150
151
180
181
220
221
270
271
330
331
390
391
470
471
560
561
680
681
820
821
1000
102
1200
122
1500
152
1800
182
2200
222
2700
272
3300
332
3900
392
4700
472
5600
562
6800
682
8200
822
10000
103
12000
123
15000
153
18000
183
22000
223
27000
273
33000
333
39000
393
47000
473
56000
563
68000
683
82000
823
100000
104
120000
124
150000
154
180000
184
220000
224
270000
274
330000
334
390000
394
470000
474
560000
564
680000
684
820000
824
100V
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
C
C
C
E
E
G
G
G
G
G
200V
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
C
C
E
E
E
E
G
G
G
G
G
G
G
G
G
1210
250V
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
C
E
E
E
E
E
G
G
G
G
G
G
G
G
G
500V
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
E
E
E
E
E
F
F
F
630V
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
E
E
E
E
E
F
F
F
1808
500V
630V
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
100V
200V
1812
250V
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
F
F
F
F
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
F
F
F
F
F
F
F
G
G
G
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
F
F
F
F
F
F
F
G
G
G
500V
630V
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
F
F
F
F
G
G
G
G
G
G
G
G
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
F
F
F
F
G
G
G
G
7-2. X7R
Dimension
1825
2220
2225
Cap(pF)
code
100V
200V
250V
500V
630V
100V
200V
250V
500V
630V
100V
200V
250V
500V
630V
1000
102
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
1200
122
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
1500
152
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
1800
182
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
2200
222
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
2700
272
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
3300
332
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
3900
392
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
4700
472
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
5600
562
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
6800
682
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
8200
822
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
10000
103
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
12000
123
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
15000
153
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
18000
183
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
22000
223
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
27000
273
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
33000
333
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
39000
393
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
47000
473
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
56000
563
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
68000
683
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
82000
823
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
100000
104
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
120000
124
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
150000
154
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
180000
184
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
220000
224
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
270000
274
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
330000
334
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
390000
394
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
470000
474
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
560000
564
F
F
F
G
G
F
F
F
F
F
F
F
F
680000
684
F
F
F
F
F
F
F
F
F
820000
824
F
F
F
F
F
F
F
F
F
7-3. Y5V
Dimension
0805
1206
1210
1812
Cap(μF)
code
100V
200V
250V
100V
200V
250V
100V
200V
250V
100V
200V
250V
0.010
103
B
B
B
B
B
B
C
C
C
D
D
D
0.015
153
B
B
B
B
B
B
C
C
C
D
D
D
0.022
223
B
B
B
B
B
B
C
C
C
D
D
D
0.033
333
B
B
B
B
B
B
C
C
C
D
D
D
0.047
473
B
B
B
B
B
B
C
C
C
D
D
D
0.068
683
B
B
B
B
B
B
C
C
C
D
D
D
0.10
104
B
B
B
B
C
C
C
D
D
D
0.15
154
C
C
C
C
C
C
D
D
D
0.22
224
C
C
D
D
D
0.33
334
C
D
D
D
0.47
474
D
D
D
0.68
684
D
D
D
8. RELIABILITY TEST CONDITIONS AND REQUIREMENTS
No.
1.
Item
Visual and
Dimensions
Test Condition
Requirements
* No remarkable defect.
* Dimensions to confirm to individual specification sheet.
2. Capacitance
* Shall not exceed the limits given in the detailed spec.
* Class I : C0G
Q/ D.F.
3. (Tangent of
loss angle)
Temperature
4.
Cap.≤1000pF, 1.0±0.2Vrms, 1MHz±10%.
6.
Q/D.F.
Class I
Q≥1000
Cap.≥30pF
(C0G)
Q≥400+20C
Cap.0.22µF
* Class II : (X7R, Y5V)
D.F.≤3.5%
1.0±0.2Vrms, 1KHz±10%.
Remark
X7R items
X7R 0603≥0.047μF, 0805=0.1μF,
1206≥0.47μF
X7R 0603≥0.068μF, 0805>0.1µF
All Y5V items
Cap.>1000pF, 1.0±0.2Vrms, 1KHz±10%.
Class II
* With no electrical load.
Coefficient
(Temperature
characteristic
of
capacitance)
5.
Dielectric
T.C.
Operating Temp.
C0G
-55~125°C at 25°C
X7R
-55~125°C at 25°C
Y5V
-25~85°C at 20°C
Rated Vol.(V)
Apply Voltage
Test Condition
Insulation
=100
1 times of UR
Max. 120 sec.
Resistance
100500
500Vdc
60 sec.
T.C.
Capacitance Change
C0G
Within ±30ppm/°C
X7R
Within ±15%
Y5V
Within +30%/-80%
Dielectric
Requirements
Class I
≥10GΩ or RxC≥500Ω-F, whichever is smaller
Class II
≥10GΩ or RxC≥100Ω-F, whichever is smaller
* Solder temperature : 235±5°C for (0402~1210).
Solderability
* Solder temperature : 245±5°C for (1808~2225).
* 75% min. coverage of all metalized area.
* Dipping time : 2±0.5 sec.
Rated Vol.(V)
Condition
≤100
2.5 times of UR
100
