1N5408
1N5408
    DIOFIT(对余科技)
    DO-27(DO-201AA)
    1N5408
1N5408 数据手册
3.0Amp General Purpose Rectifiers 1N5400 ~ 1N5408 Features DO-27 The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 Construction utilizes void-free molded plastic technique Low reverse leakage High forward surge current capability High temperature soldering guaranteed: 250°C/10 seconds,0.375"(9.5mm) lead length, 5 lbs. (2.3kg) tension 1.0 (25.4) MIN. 0.220 (5.6) 0.197(5.0) DIA. 0.375(9.5) 0.285(7.2) Mechanical Data Case: JEDEC DO-27 molded plastic body Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 1.0 (25.4) MIN. 0.052 (1.3) 0.035(0.9) DIA. Polarity: Color band denotes cathode end Mounting Position: Any Weight : 0.04 ounce, 1.10 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load, for capacitive load current derate by 20%. 1N 1N 5401 5402 1N 5403 1N 5404 1N 5405 1N 5406 1N 5407 1N UNITS 5408 200 300 400 500 600 800 1000 VOLTS 70 140 210 280 350 420 560 700 VOLTS 100 200 300 400 500 600 800 1000 VOLTS SYMBOLS 1N 5400 Maximum repetitive peak reverse voltage VRRM 50 100 Maximum RMS voltage VRMS 35 Maximum DC blocking voltage VDC 50 Maximum average forward rectified current 0.375"(9.5mm) lead length at T A =75°C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 3.0A Maximum DC reverse current T =25 C at rated DC blocking voltage TA=100 C Typical junction capacitance (Note 2) A Typical thermal resistance (Note 3) I(AV) 3.0 Amp IFSM 150 Amps 1.2 Volts VF IR 5.0 100.0 uA CJ 30.0 pF RqJA 20.0 C/W -65 to +175 C Operating junction and storage temperature range TJ,TSTG Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.Thermal resistance from junction to ambient at 0.375" (9.5mm)lead length,P.C.B. mounted 技术   创新   未来 Rev.2013A Page 1 Ratings And Characteristic Curves 1N5400 THRU 1N5408 FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 3.0 Peak Forward Surage Current AMPERES 150 2.4 AMPERES Average Forward Rectified Current FIG. 1- FORWARD CURRENT DERATING CURVE 1.8 Single Phase Half Wave 60Hz Resistive or inductive Load 1.2 0.6 0 0 25 50 75 100 125 150 120 90 60 30 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 175 0 C 1 10 FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS FIG. 4-TYPICAL REVERSE CHARACTERISTICS 20 100 1 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 0.1 0.01 0.6 0.8 1.0 1.2 1.4 1.5 10 MICROAMPERES 10 Instantaneous Reverse Current Instantaneous Forward Current AMPERES 100 Number Of Cycles At 60 Hz Ambient Temperature VOLTS Instantaneous Forward Voltage 1 TJ=100 C 0.1 TJ=25 C 0.01 0.001 0 30 60 90 120 150 Percent Of Peak Reverse Voltage FIG. 5-TYPICAL JUNCTION CAPACITANCE FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE Junction Capacitance pF Transient Thermal Impedance C/W 200 TJ=25 C 100 10 1 100 10 1 0.1 0.1 1.0 10 100 0.01 VOLTS Reverse Voltage 0.1 sec 1 10 100 t,Pulse Duration 技术   创新   未来 Rev.2013A Page 2
1N5408 价格&库存
很抱歉,暂时无法提供与“1N5408”相匹配的价格&库存,您可以联系我们找货
