59-F67.00-01FR
59-F67.00-01FR
    EUROTEC
59-F67.00-01FR 数据手册
www.eurotec-intl.co.uk 59-F67.00-01FR Paper Cone Inverted rolled cloth edge RoHS Compliant 8 ohm 2W 88 dB After the following tests the speaker operates normally. Thermal Shock Test -30˚C±2˚C/2Hrs +80˚C/2Hrs 20 Cycles Humidity Test +40˚C 95%RH 96Hrs High Temperature Test +85˚C 240 Hrs Low Temperature Test -40˚C 72 Hrs Output S P L 1W @ 1m FS 255 Hz RE 6.5 Ohm RES 18 Ohm 88 Nominal impedance Ω 8 Rated Power input (W) QMS 5.8 QES 2.2 2 Speaker weight (g) 133 Voice coil dia (mm) 15 Specification QTS 2.119 MMs 0.4 grams CMs 1080µm/Newton BL 1.65 Tesla-m Thiele small A (mm) Magnet Dia (mm) 76 45 B (mm) Gasket thickness (mm) 61 0.7 C (mm) Mounting holes in pitch 26 4
59-F67.00-01FR 价格&库存
很抱歉,暂时无法提供与“59-F67.00-01FR”相匹配的价格&库存,您可以联系我们找货
