GSDR-16
GSDR-16
    SUNGMUN(韩国星炆)
    Mini Rotary dip switch 7.2*7.2mm H:2.9mm, 16Positon,Arrow Actuator H:0mm,THT Ter`3x3pins
GSDR-16 数据手册
MRK. DATE REVISION SIGN 1 5.08 Specification 1. Operating Voltage : 42V (None-Switching : 100mA, DC50V) (Switching : 100mA, DC5V) 2. Contact Resistance : 100mΩ Max 3. Insulation Resistance : 100MΩ Min 4. Operating Force : 200gf.cm Max 6- 5. 6. 8 0. 7.62 Life cycle : 10,000 steps Sealing : Comparable IP67 P.C.B DIMENSION 2 8 1 10 P o s i t i 16 o P n o s i t i o n C 3. 2 0.68 C 5.08 4 2.6 D.P 0.8 3.5 2.9 7.2 0 1 2 3 4 5 6 7 8 9 A B C D E F C ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Real Code 1 2 4 8 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 0.5 STANDARD LAYOUT 0.2t 01 ASSEMBLY NO. 7.62 DRAW/DESIGNED 재질 DESCRIPTION CHECKED MATERIAL APPROVED G.TOL ±0.1 2017-07-10 SUNGMUN ELECTRONICS CO.,LTD UNIT SCALE mm 4:1 SIZE A4 1 COLOR/FINISH TITLE ASSEMBLY MODEL GSDR-16 DRAW NO. GSDR-1600-01 Q,TY VENDOR SHEET 1/1 본 도면은 당사 재산으로서 허가없이 무단복사/배포 금지함. PROPERTY OF ISSUING ENTITY. CANNOT BE DISTRIBUTED OR REPRODUCED WITHOUT AUTHORIZATION. SME 151028 G SERIES MINI ROTARY DIP SWITCH SPECIFICATION (7.2X7.2) Rev. 03 P:1/3     !"# $%& '  (") * +,$ ,  - ". /./ 0" 1 2 +"1 &"3" ( 1 4 5678 9 :;?@A B./ C 5+, 1 4 /77 &DE *%  P>O>LO?Q?LQ   R       65/ F3T UV&  W) X3T V&  Y ,3  ) 3 "3" Z  1. 65B %  (  65b c 3T (  [  # &3"! #,  , "& T ! ,  , T. \ '3"&  TT # &! ,  /Y]^ TT 3""    "  &". 656 *T" , ! 1 FT1 /77F *% S  " TT #  !    "X#T)   "!3. /77&_ &V. ` Ta /77 d & . B
GSDR-16 价格&库存
很抱歉,暂时无法提供与“GSDR-16”相匹配的价格&库存,您可以联系我们找货
