BX48 BATEGO II
BX48 BATEGO II
    BATRONIX
    BATRONIX - BX48 BATEGO II - Universal Programmer, BX48 Batego, 51.2Mbps Data Rate, Available with 4 ...
BX48 BATEGO II 数据手册
Batronix Leading programming and measurement solutions Batronix Professional Programmer Series Batronix I Lise-Meitner-Str. 1-7 I Batronix Professional Programmer Series 24223 Schwentinental | Germany | www.batronix.com Batronix Leading programming and measurement solutions The Batronix Professional Programmer Series offers an exceptionally flexible, simple to use and fast set of programmers that support a broad range of chips. With a height of only 2.5 cm the enclosures are very practical and are noted for their design and anodized die-cast aluminum construction. These programming devices are your first choice even in a harsh usage environment. The exceptional flexibility is attained by providing all power requirements via the USB port. A power adapter or batteries are not required, since all programming voltages are provided internally by a voltage generator from the USB supply voltage. The chips are programmed at a high level of quality and reproducibility through the use of optimized algorithms and microcontroller managed programming times. All supported chips can be programmed directly in DIP/DIL packages and suitable adapters are available for specialized packages such as PLCC, SOIC, SOP, TSOP, QFP and BGA. Special Features BX32(P)-II, BX40-II BX48-II USB Powered The device is powered through the USB port and doesn’t need a power adapter or batteries. Chip Auto Identification The programmer identifies chips automatically on their chip signature. Multi Programmer Control For volume production of chips up to eight BX32, BX32P, BX40 or BX48 devices can be controlled simultaneously from one PC using the Prog-Express software. Automatic Programming Start In production mode, the programmer detects newly inserted chips automatically and can automatically start the programming process. Ultra High Speed Technology Due to the specially developed Batronix pindriver ICs the BX48 is the fastest available programmer. Ultra Low Voltage Support Due to state-of-the-art technology the BX48 supports as first programmer in the world supply voltages down to 0.9 Volt and therefore already the coming 1.0 Volt chip technologies according to JEDEC standard JESD8-14A.01. Multi Platform Support The Batronix programmers can be used on all popular Windows, Linux and Mac operating systems. Batronix I Lise-Meitner-Str. 1-7 I Batronix Professional Programmer Series 24223 Schwentinental | Germany | www.batronix.com Batronix Leading programming and measurement solutions Supported Devices BX32-II BX32P-II BX40-II BX48-II BX32-II BX32P-II BX40-II BX48-II Very old NMOS EPROM (VPP > 15 V) NMOS EPROM (VPP
BX48 BATEGO II 价格&库存
很抱歉,暂时无法提供与“BX48 BATEGO II”相匹配的价格&库存,您可以联系我们找货
