CHIPPROG-48
CHIPPROG-48
    PHYTON
    DIP
CHIPPROG-48 数据手册
ChipProg-48 Universal Programmer At a Glance: Automation and Multiprogramming: • Low-cost, very fast programmer for engineering and lowvolume production • Palm-size tool – 160x90x25 mm or 6¼x3¾x1inch • 48-pin DIP ZIF socket • USB 2.0 interface to a host computer • Very fast programming operations • Unlimited support for future devices • Lifetime free software updates • Allows operations with projects to simplify and speed up operations with different device types • Single programming commands can be executed automatically as a preset batch of single operations • Built-in C-like script language enables automation of complex and routine programming operations • Incorrect device insertion and bad contacting test • Programming starts automatically upon the device being reliably inserted and fixed in the socket • Can be controlled from external applications • Supports volume programming by writing serial numbers, checksums, signatures into target devices • Maintains the programming log • Unlimited numbers of programmers can be connected to one host PC for the concurrent programming of multiple devices Device support: • Memory: serial and parallel, NOR and NAND Flash memory devices, PROM, EPROM, EEPROM • Microcontrollers with Flash and OTP memory, including the ARM7, ARM9, Cortex, 8051, PIC, AVR, MSP430, Z8, 9S08 and 9S12 architectures • Programmable logic: PALs, GALs, PLDs, EPLDs • In-system programmable devices of all types Semiconductor manufacturers support: • Altera, AMD, AMIC, Atmel, Cypress, Dallas Semiconductor, EON, Freescale, Fujitsu, Hynix, Holtek, Hitachi, ICT, Infineon, Intel, ISSI, Lattice, Macronix, Microchip, Micron, Mitsubishi, NSC, NXP/Philips, Numonyx, Renesas, Samsung, Sharp, Spansion, STMicroelectronics, SST, Texas Instruments, Winbond, Xilinx, Zilog and others Package support: • Requires no adapters for operations with any devices in DIP packages with up to 48 pins • Phyton adapters for operations with devices in PLCC, SOIC, TSOP, MSOP, TSSOP, SSOP, QFP, BGA, QFN, MLF and other packages as well as cables for in-system programming are available • Compatible with a variety of third party adapters Miscellaneous: • Start button for fast manual control • Hot keys for major operations: Blank Check, Erase, Read, Program, Verify, Lock and Auto • Loads files in Binary, Intel HEX, Motorola S-Record, POF, JEDEC, PRG and other formats • Unlimited number of memory dump buffers • Dump buffers are featured with multi layer structure corresponding to the device memory map • Easy preset for microcontrollers parameters: SFRs, boot vectors, oscillator options, voltages, etc. • Automatically calculates and displays checksums of the data dumps in memory buffers -• The embedded editor operates with Hexadecimal, Decimal, Binary and ASCII data in memory buffers and enables full screen data editing in buffers • Allows advanced block operations in buffers: copy, move, compare, fill with data, search, etc. Phyton, Inc. Microsystems and Development Tools 7206 Bay Parkway, 2nd floor, Brooklyn NY 11204, USA • Phone: 718 259-3191 • Fax: 718 259-1539 info@phyton.com • http://www.phyton.com Phyton ChipProg-48 - A4 - 01.ind1 1 9/22/2008 12:37:21 AM
CHIPPROG-48 价格&库存
很抱歉,暂时无法提供与“CHIPPROG-48”相匹配的价格&库存,您可以联系我们找货
