DB59M024035-A
DB59M024035-A
    NANOTEC(纳诺达克)
    NANOTEC - DB59M024035-A - DC Motor, BLDC, Brushless, 24 V, 3500 rpm, 1.11 N-m, 135 W, 56.6 mm
DB59M024035-A 数据手册
DB59 Brushless DC Motor OPTIONS I I I I I I I I VERSIONS Type Rated Power W Rated Torque Ncm Rated Current A Rated Voltage V Rated Speed rpm Torque Constant Ncm/A Rotor Inertia gcm² Weight kg Length „A“ mm DB59S024035 84 23 5 24 3500 4.5 75 0.52 53.6 mm - 54 mm DB59M024035 135 37 8 24 3500 4.6 105 0.65 53.6 mm - 54 mm DB59L024035 172 47 9.4 24 3500 5 119 0.72 53.6 mm - 73.6 mm DB59C024035 220 60 13.6 24 3500 4.4 173 0.95 53.6 mm - 93.6 mm ORDER IDENTIFIER ACCESSORIES DB59S024035- ZD-DF56 Damper A* = single shaft * also available for individual configuration with encoder and brake on our website  DIMENSIONS (IN MM) DB59 47.1±0.5 Side view 0.05 A 56.6±0.5 Ø0.08 A Front view and mounting 20.6±1 1.6±0.5 Rear view "A" 4.5±0.5 46±0.1 .2 ± 0.2 -0.013 5 98 Ø57±0.5 Ø5 2-M2 .5 Ø8 for DB59S...Ø6.35 -0.013 4x 0 Ø38.1-0.05 A 0.15 A L= min.300 BRUSHLESS DC MOTORS
DB59M024035-A 价格&库存
很抱歉,暂时无法提供与“DB59M024035-A”相匹配的价格&库存,您可以联系我们找货
