EPG108(EPS108G)
EPG108(EPS108G)
    ECE(百容)
    插件
    类型:琴键;额定电流:25mA;额定电压:24V;电路结构:单刀单掷;开关位数:8;引脚样式:PC引脚;引脚间距:2.54mm;工作温度:-40℃~+85℃;使用寿命:2000;颜色:蓝色;
EPG108(EPS108G) 数据手册
Switch EPH/EPG/EPS SERIES EDGE ACTUATED TYPE EPH Housing Height 5mm Only!! EPG/EPS SPST EPG/EPS DPST EPG/EPS SPDT EPG/EPS 3PST EPG/EPS 4PST EPG/EPS DPDT ■ FEATURES z Edge actuated type (Piano Type) easy setting on closely racked PCB. z Tactile response is performed directly by larger contact pressure to ensure stable contact. z All plastics are UL 94V-0 grade fire retardant. z Bottom epoxy sealed to ensure free of flux immersion during wave soldering. z Contact wiping on make and break. z Gold or Tin plated contacts to ensure low contact resistance and long operation life. z Ideal for data processing, communications, remote controls and burglar alarm system use, where manual programming required. z RoHS Compliant ■ APPLICATIONS z Numerical setting for computer terminal equipment z Price setting for vending machines z Programming for game machines z Programming for industrial equipment and measuring instruments For the latest product information, Please visit our website at http://www.ece.com.tw 1 Switch ■ SPECIFICATIONS 1.ELECTRICAL z Contact rating switching 25mA, 24VDC non-switching z Contact resistance (After life test) z Insulation resistance 100mA z Dielectric strength 500VDC Min. for 60 seconds z Leakage Current 2mA Max. 100mΩ Max. (300mΩ Max. for Tin plated type) 1000MΩ Min. at 100VDC z Capacitance between adjacent switches 5pF Max. 2.MECHANICAL AND ENVIRONMENTAL z Temperature rating operating -40℃ to +85℃ storage -40℃ to +85℃ z Operation force 800g Max. (SPST only) z Mechanical life 1000 operations (EPH) 2000 operations (EPG/EPS) z Humidity 95﹪RH, 40℃ for 96 Hrs. z Vibration 10Hz-55Hz-10Hz for 6 Hrs. z Solderability After flux 245±5℃ for 5±1 seconds z Resistance to soldering heat Solder bath:260±5℃ for 5±1 seconds ■ PART NUMBERING SYSTEM EPH 1 04 XX XX Z Z: RoHS Compliant Special product number Actuator and ON Positon: E: Extended Actuator and Top Side "OFF" L: Low Profile Actuator and Top Side "OFF" LT: Top Tape Sealed&Low Profile Actuator BE: Extended Actuator and Top Side "ON" Number of Positions: 2, 3, 4, 5, 6, 8, 10 Contact Form: SPST Series Name: EPH: Piano type For the latest product information, Please visit our website at http://www.ece.com.tw 2 Switch EPG 1 08 A XX X Z: RoHS Compliant (For EPS series only) Blank: RoHS Compliant (For EPG series only) Special product number Actuator and Sealing (For Position 1): A : Top Side "OFF" B : Top Side "ON" AT : Top Side "OFF" and Tape Sealed BT : Top Side "ON" and Tape Sealed Number of Positions: As Dimensions and Circuitry Contact form: 1. SPST 2. DPST 3. SPDT 4. 3PST 5. 4PST 6. DPDT Series name: EPG: Edge Actuated Type (Gold Plated Contacts) EPS: Edge Actuated Type (Tin Plated Contacts) ■ CONSTRUCTION EPH EPG/EPS ■ OPTIONS 1.Special top or side marking available 2.Blue or black body color 3.Normal "ON" (top side "ON") available 4.Tape sealed EPHxxxLT EPGxxxxT For the latest product information, Please visit our website at http://www.ece.com.tw 3 Switch ECE ■ DIMENSIONS AND CIRCUITRY ON ECE ON For the latest product information, Please visit our website at http://www.ece.com.tw 4 Switch For the latest product information, Please visit our website at http://www.ece.com.tw 5 Switch For the latest product information, Please visit our website at http://www.ece.com.tw 6
EPG108(EPS108G) 价格&库存
很抱歉,暂时无法提供与“EPG108(EPS108G)”相匹配的价格&库存,您可以联系我们找货
