BIWIN /
DIJ/S/A/H Series—IC Type DIP Switch
RoHS Compliant
Features
Twin contacts designed to ensure stable contact
Highly resistant to physical shock & vibration
Tape sealed version available to ensure washability
Low profile to save PCB space
Light click feeling
Heat resistance: 260°C for 10 sec.
DIJ
SMD SOLDERING PAD
6.00±0.10
SAB
ON
1
2
3
4
5
6
7
8
3.58±0.30
6.20±0.3
DIS
1
0.25±0.02
SAB
ON
2
3
4
5
6
7
SMD SOLDERING PAD
6.00±0.10
8
7.62±0.20
9.70±0.3
DIA/H
DIH
6.00±0.10
6.00±0.10
DRILLING PLAN
SAB
3
5
4
6
7
8
9.05±0.3
Specifications
7.62±0.3
Materials
◆ Contact Rating
Switching ………………… 25mA, 24VDC
Non-Switching ……………………
100mA, 50VDC
◆ Contact Resistance
Initial ……………………… 50mΩ Max.
After Life Test …………… 100mΩ Max.
◆ Insulation Resistance ………
100MΩ min at 500VDC
◆ Dielectric Strength ……… 500VAC/ 1 minute
◆ Operating Force…………. 1,000g Max.
◆ Mechanical Life……………5,000 cycles
◆ Electrical Life………………2,000 cycles
Soldering lnformation
Actuator
Cover & Base: Thermoplastic UL 94V-0, Black
Actuator: Thermoplastic UL 94-HB, White
Movable Contact: Copper Alloy, Gold- or Pure-Tin-plated
Terminal Contact & Terminal: Copper Alloy, Gold- or
Pure-Tin-plated
◆ Tape Sealed: Polyimide film
Packaging lnformation
IC Type
Terminal:
J=J Lead
S=SMD
A=Auto-insert
H=Straight
08
Positions:
06=6 Position
08=8 Position
G
01
Actuator:
Finished:
G=Raise Actuator
01=1u" Gold
M=Medium Actuator 03=3u" Gold
L=Flat Actuator
E=Tin Plated
T=Tape Sealed
"G, M & L types: un-washable"
http://www.biwin.com
http://www.sab.com.tw
L/T type
M type
6.00±0.10
G type
ON
1
2
3
4
N
Package
Order lnformation
S
6.00±0.10
Wiring Diagram
◆ Tube: DIS/ DIA/ DIH
◆ Tape & Reel: DIS/ DIJ
◆ Actuators all in "OFF" position.
◆ Hand Soldering
Soldering Iron of 30W or under at 350°C for 3 sec. max. or at 270°C for 5 sec. max.
◆ Wave Soldering
260±5°C for 10 sec. max.
◆ Reflow Soldering.
Peak temperature: 245 or 250°C max. The time above 240 or 245°C must be 30 sec. max.
◆ Keep all actuators in "OFF" position during soldering and cleaning process
DI
6.00±0.10
0.70±0.05
2
0.40±0.05
ON
1
DIA
R
U
Package:
None=Tube
R=Tape & Reel
None=Standard
U=Halogen Free
P/N
No. Of
Pole
Dim.
A
Quantity
per Tube
DIS/A/H01
DIS/A/H02
DIS/A/H03
DIS/A/H04
DIS/A/H05
DIS/A/H06
DIS/A/H07
DIS/A/H08
DIS/A/H09
DIS/A/H10
DIS/A/H12
1
2
3
4
5
6
7
8
9
10
12
2.98mm
5.52mm
8.06mm
10.60mm
13.14mm
15.68mm
18.22mm
20.76mm
23.30mm
25.84mm
30.92mm
174
95
65
48
39
33
28
25
22
http://www.sab-switch.com.cn
Oct. 2016
很抱歉,暂时无法提供与“DIS02GE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.56840
- 10+3.73680
- 30+3.31560
- 95+2.72160
- 475+2.47320
- 1045+2.35440
