Switch
EPH/EPG/EPS SERIES
EDGE ACTUATED TYPE
EPH
Housing Height 5mm Only!!
EPG/EPS SPST
EPG/EPS DPST
EPG/EPS SPDT
EPG/EPS 3PST
EPG/EPS 4PST
EPG/EPS DPDT
■ FEATURES
z Edge actuated type (Piano Type) easy setting on closely racked PCB.
z Tactile response is performed directly by larger contact pressure to ensure stable
contact.
z All plastics are UL 94V-0 grade fire retardant.
z Bottom epoxy sealed to ensure free of flux immersion during wave soldering.
z Contact wiping on make and break.
z Gold or Tin plated contacts to ensure low contact resistance and long operation life.
z Ideal for data processing, communications, remote controls and burglar alarm system
use, where manual programming required.
z RoHS Compliant
■ APPLICATIONS
z Numerical setting for computer terminal equipment
z Price setting for vending machines
z Programming for game machines
z Programming for industrial equipment and measuring instruments
For the latest product information, Please visit our website at http://www.ece.com.tw
1
Switch
■ SPECIFICATIONS
1.ELECTRICAL
z Contact rating
switching
25mA, 24VDC
non-switching
z Contact resistance
(After life test)
z Insulation resistance
100mA
z Dielectric strength
500VDC Min. for 60 seconds
z Leakage Current
2mA Max.
100mΩ Max. (300mΩ Max. for Tin plated type)
1000MΩ Min. at 100VDC
z Capacitance between adjacent switches 5pF Max.
2.MECHANICAL AND ENVIRONMENTAL
z Temperature rating
operating
-40℃ to +85℃
storage
-40℃ to +85℃
z Operation force
800g Max. (SPST only)
z Mechanical life
1000 operations (EPH)
2000 operations (EPG/EPS)
z Humidity
95﹪RH, 40℃ for 96 Hrs.
z Vibration
10Hz-55Hz-10Hz for 6 Hrs.
z Solderability
After flux 245±5℃ for 5±1 seconds
z Resistance to soldering heat
Solder bath:260±5℃ for 5±1 seconds
■ PART NUMBERING SYSTEM
EPH 1
04 XX
XX Z
Z: RoHS Compliant
Special product number
Actuator and ON Positon:
E: Extended Actuator and Top Side "OFF"
L: Low Profile Actuator and Top Side "OFF"
LT: Top Tape Sealed&Low Profile Actuator
BE: Extended Actuator and Top Side "ON"
Number of Positions: 2, 3, 4, 5, 6, 8, 10
Contact Form: SPST
Series Name: EPH: Piano type
2
Switch
EPG
1
08 A XX
X
Z: RoHS Compliant (For EPS series only)
Blank: RoHS Compliant (For EPG series only)
Actuator and Sealing (For Position 1):
A : Top Side "OFF"
B : Top Side "ON"
AT : Top Side "OFF" and Tape Sealed
BT : Top Side "ON" and Tape Sealed
Number of Positions: As Dimensions and Circuitry
Contact form: 1. SPST 2. DPST 3. SPDT
4. 3PST 5. 4PST 6. DPDT
Series name: EPG: Edge Actuated Type (Gold Plated Contacts)
EPS: Edge Actuated Type (Tin Plated Contacts)
■ CONSTRUCTION
EPH
EPG/EPS
■ OPTIONS
1.Special top or side marking available
2.Blue or black body color
3.Normal "ON" (top side "ON") available
4.Tape sealed
EPHxxxLT
EPGxxxxT
3
Switch
ECE
■ DIMENSIONS AND CIRCUITRY
ON
ECE
ON
4
Switch
5
Switch
6
很抱歉,暂时无法提供与“EPS102AZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.21200
- 10+3.44520
- 30+3.06720
