Switch
EDG/EDS SERIES
SLIDE TYPE
EDG/EDS SPST
EDG/EDS DPST
EDG/EDS SPDT
EDG/EDS 3PST
EDG/EDS 4PST
EDG/EDS DPDT
■ FEATURES
z Tactile response is performed directly by larger contact pressure to ensure very stable
contact.
z All plastics are UL 94V-0 grade fire retardant.
z Bottom epoxy sealed standard to ensure free of flux immersion during wave soldering.
z Contact wiping on make and break.
z Gold or Tin plated contacts to ensure low contact resistance and long mechanical life.
z Ideal for data processing, communications, remote controls and burglar alarm system
use, where manual programming is required.
z RoHS Complinat
■ APPLICATIONS
z Numerical setting for computer terminal equipment
z Price setting for vending machines
z Programming for game machines
z Programming for industrial equipment and measuring instruments
For the latest product information, Please visit our website at http://www.ece.com.tw
1
Switch
■ SPECIFICATIONS
1.ELECTRICAL
z Contact rating
switching
25mA, 24VDC
non-switching
100mA
z Contact resistance
initial
50mΩ Max.
after life test
100mΩ Max. (300mΩ Max. for Tin plated type)
z Insulation resistance
1000MΩ Min. at 100VDC
z Dielectric strength
500VDC Min. for 60 seconds
z Capacitance between adjacent switches 5pF Max.
2.MECHANICAL AND ENVIRONMENTAL
z Temperature rating
operating
Storage
z Operation force
z Mechanical life
z Humidity
z Vibration
z Solderability
z Resistance to soldering heat
-40℃ to + 85℃
-40℃ to + 85℃
800g Max. (SPST only)
2000 operations
95﹪RH, 40℃ for 96 Hrs.
10Hz-55Hz-10Hz for 6 Hrs.
After flux 245±5℃ for 5±1 seconds
Solder bath:260±5℃ for 5±1 seconds
■ PART NUMBERING SYSTEM
EDG
1
08 S 33
X
Blank: RoHS Compliant (For EDG series only)
Special product number
33:Contact (Gold Plated) / Terminal (Tin Plated)
Actuator and Sealing:
S : Standard
L : Low Profile Actuator
LT : Low Profile and Tape Sealed
ST : Standard and Tape Sealed
Number of Positions: As Dimensions and Circuitry
Contact Forms: 1. SPST 2. DPST 4. 3PST 5. 4PST
Series Name: EDG: Gold Plated Contacts
2
Switch
EDS 1
08 S XX
Z
Z: RoHS Compliant (For EDS series only)
S : Standard
Contact Forms: 1. SPST 2. DPST 3. SPDT
4. 3PST 5. 4PST 6. DPDT
Series Name: EDS:Tin Plated Contacts
■ CONSTRUCTION
3
Switch
■ DIMENSIONS AND CIRCUITRY
EDG/EDS SPST SERIES
(0.381)
9.7±0.3
N
O
Extended type
A±0.3
(0.118)
(0.024)
0.25±0.1
(0.300)
0.6±0.1
7.62±0.1
+0.2
φ0.8 -0 HOLE
4.2±0.3
3±0.3
(0.260)
P.C.B. LAYOUT
(TOP VIEW)
(0.075)
(5.4±0.2
for 1 pole)
(0.213)
5.4±0.3
6.6±0.3
1.9±0.2
(0.010)
2.54±0.2
7.62±0.3
(0.100)
2.54x(P-1)±0.1
(0.100x(P-1))
(0.300)
Dimension A
UNIT:mm(inch)
Positions
1
2
3
4
5
6
7
8
9
10
12
15
A
3.9*
(0.154)
6.7
(0.264)
9.2
(0.362)
11.7
(0.461)
14.2
(0.559)
16.7
(0.657)
19.2
(0.756)
21.7
(0.854)
24.2
(0.953)
26.7
(1.051)
31.8
(1.252)
39.5
(1.555)
* The dimensions of the 1 pole switch may vary slightly.
A±0.3
(0.118)
(0.024)
7.62±0.1
+0.2
φ0.8 -0 DIA. HOLE
4.2±0.3
3±0.3
(0.260)
0.6±0.1
P.C.B. LAYOUT
(TOP VIEW)
(0.075)
(5.4±0.2
for 1 pole)
(0.213)
5.4±0.3
6.6±0.3
1.9±0.2
0.25±0.1
(0.300)
9.7±0.3
N
(0.381)
EDG 33 SERIES(SPST)
(0.010)
2.54±0.2
7.62±0.3
(0.100)
(0.300)
2.54x(P-1)±0.1
(0.100x(P-1))
UNIT:mm(inch)
Dimension A
Positions
2
3
4
5
6
7
8
9
10
12
15
A
6.7
(0.264)
9.2
(0.362)
11.7
(0.461)
14.2
(0.559)
16.7
(0.657)
19.2
(0.756)
21.7
(0.854)
24.2
(0.953)
26.7
(1.051)
31.8
(1.252)
39.5
(1.555)
Remark: 2&3 position switches don't have the "ECE" Mark.
4
Switch
(0.381)
9.7±0.3
EDG/EDS DPST SERIES
2.75±0.2
P.C.B. LAYOUT
(TOP VIEW)
0.25±0.1
(0.300)
0.6±0.1
(0.024)
7.62±0.1
+0.2
φ0.8 -0 HOLE
(0.165)
3±0.3
(0.118)
(0.303)
(0.108)
4.2±0.3
(0.213)
5.4±0.3
7.7±0.3
A±0.3
(0.010)
2.54±0.2
7.62±0.3
2.54x(P-1)±0.1
(0.100)
(0.300)
(0.100x(P-1))
Dimension A
UNIT:mm(inch)
Positions
1
2
3
4
5
6
A
6.7
(0.264)
11.7
(0.461)
16.7
(0.657)
21.7
(0.854)
26.7
(1.051)
31.8
(1.252)
(0.381)
9.7±0.3
EDG/EDS SPDT SERIES
2.75±0.2
P.C.B. LAYOUT
(TOP VIEW)
0.25±0.1
(0.300)
0.6±0.1
(0.024)
7.62±0.1
+0.2
φ0.8 -0 HOLE
(0.165)
3±0.3
(0.118)
(0.303)
(0.108)
4.2±0.3
(0.213)
5.4±0.3
7.7±0.3
A±0.3
(0.010)
2.54±0.2
7.62±0.3
2.54x(P-1)±0.1
(0.100)
(0.300)
(0.100x(P-1))
Dimension A
UNIT:mm(inch)
Positions
1
2
3
4
5
6
A
6.7
(0.264)
11.7
(0.461)
16.7
(0.657)
21.7
(0.854)
26.7
(1.051)
31.8
(1.252)
5
Switch
EDG/EDS 3PST SERIES
(0.381)
9.7±0.3
N
O
2.75±0.2
(0.118)
P.C.B. LAYOUT
(TOP VIEW)
(0.024)
0.25±0.1
(0.300)
0.6±0.1
7.62±0.1
+0.2
φ0.8 -0 HOLE
4.2±0.3
3±0.3
(0.303)
(0.108)
(0.165)
(0.213)
5.4±0.3
7.7±0.3
A±0.3
(0.010)
2.54±0.2
7.62±0.3
(0.100)
2.54x(P-1)±0.1
(0.300)
(0.100x(P-1))
UNIT:mm(inch)
Dimension A
Positions
1
2
3
4
5
A
9.2
(0.362)
16.7
(0.657)
24.2
(0.953)
31.8
(1.252)
39.5
(1.555)
EDG/EDS 4PST SERIES
(0.381)
9.7±0.3
N
O
2.75±0.2
(0.118)
(0.024)
2.54±0.2
0.25±0.1
(0.010)
7.62±0.3
(0.100)
(0.300)
4.2±0.3
+0.2
φ0.8 -0 HOLE
0.6±0.1
Dimension A
P.C.B. LAYOUT
(TOP VIEW)
7.62±0.1
3±0.3
(0.303)
(0.108)
(0.165)
(0.213)
5.4±0.3
7.7±0.3
A±0.3
(0.300)
2.54x(P-1)±0.1
(0.100x(P-1))
UNIT:mm(inch)
Positions
1
2
3
A
11.7
(0.461)
21.7
(0.854)
31.8
(1.252)
6
Switch
(0.381)
9.7±0.3
EDG/EDS DPDT SERIES
2.75±0.2
0.6±0.1
(0.024)
2.54±0.2
0.25±0.1
(0.010)
7.62±0.3
(0.100)
(0.300)
4.2±0.3
+0.2
φ0.8 -0 HOLE
7.62±0.1
3±0.3
(0.118)
(0.303)
P.C.B. LAYOUT
(TOP VIEW)
(0.108)
(0.165)
(0.213)
5.4±0.3
7.7±0.3
A±0.3
2.54x(P-1)±0.1
(0.100x(P-1))
(0.300)
UNIT:mm(inch)
Dimension A
Positions
1
2
3
A
11.7
(0.461)
21.7
(0.854)
31.8
(1.252)
■ OPTIONS
◆ RIGHT ANGLE TYPE
DIMENSIONS A IS SAME AS PREVIOUS PAGE
Right angle type
UNIT:mm(inch)
A±0.3
P.C.B. LAYOUT
(0.100)
3±1
(0.118)
2.54±0.1
6±0.3
(0.236)
+0.2
φ0.8 -0 HOLE
(0.118)
2.9 min (T)
(0.381)
9.7±0.3
1.5±0.1
2.54x(P-1)±0.1
(0.100x(P-1))
+0.4
**The "T" of the 1 position switch is 3.0 -0.2
7
Switch
EDG X XX X RA X 33
Special product number:
33: Contact (Gold Plated) / Terminal (Tin Plated)
Blank: Without Tape Sealed
T: With Tape Sealed
RA: Right Angle
S: Standard
L: Low Profile Actuator
EDG
X
XX X
RA X X
T: With Tape Sealed
RA: Right Angle
S: Standard
EDS: Silver or Tin Plated Contacts
◆ LOW PROFILE ACTUATORS
◆ LOW PROFILE ACTUATORS AND TOP
TAPE SEALED
◆ SPECIAL TOP OR SIDE MARKING AVAILABLE
8
很抱歉,暂时无法提供与“EDS102SZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.28320
- 10+2.60280
- 30+2.32200
- 80+1.95480
- 480+1.79280
- 800+1.69560
