COM-R5W-HT-580-R
COM-R5W-HT-580-R
    HIGGSTEC(万达光电)
COM-R5W-HT-580-R 数据手册
 ႄᄒՠᄽঝ‫ࡈپ‬՝ֶ৻҆ӹ    PRODUCT SPECIFICATIONS Customer: Model: USB-R5W-HT580-R/COM-R5W-HT580-R Mode: 5 wires resistive USB/COM controller Date: Mar. 07, 2006 Version: 1.0 Customer Approval HIGGSTEC INCORPORATED 9 Fl., No.657-8, Jungjeng Rd., Shinjuang City, Taipei 24260, Taiwan. TEL:886-2-2903-6262 FAX:886-2-2906-2007 E-mail:info@higgstec.com.tw Approve Review Preparation Henry Andy Vicky OVERVIEW The touchscreen controller provides the optimistic performance for 5-wire analog resistive touch pa nels. It communicates with PC system directly through RS-232 port or USB port .The touchscreen device driver emulates mouse left and right button. HARDWARE SPECIFICATIONS Circuit Board Dimension Power Requirements 68.00 mm x 21.00 mm +5VDC ( Maximum 150mA, typical current depend on specified panel, 50mV peak to peak maximum ripple ) Operation Temperature 0 to 60 ℃ Storage Tempeture -40 to 80 ℃ Relative Humidity 95% at 60 ℃ Protocal Resolution Report Rate COM:9600 BPS baudrate, 1 Start bit, 8 Data bits, None parity, 1 Stop bit USB:USB1.1 full speed (HID 1.11) Sample 4096X4096 (12Bits) COM:Minimum 63 PPS (Point per Second) USB:Minimum 86 PPS (Point per Second) Response Time Maximum 20 ms Pin Out Definition RT, RL, SG, LT, LL Panel Requirements Capacitive 80 nF (max.), Resistance 30 to 500 Ohm ( pin to pin on drive layer ) COM SOFTWARE SUPPORTS The touchscreen device driver supports operation systems, including MS-DOS, Windows 3.1, Windows 95, Windows 98, Windows ME, Windows NT 4.0, Windows 2000, Windows XP, Windows XP embedded, Windows CE, Windows server 2003, RedHat/Mandrake Linux series. USB SOFTWARE SUPPORTS The touchscreen device driver supports operation systems, including Windows 2000, Windows XP, Windows XP embedded.
COM-R5W-HT-580-R 价格&库存
很抱歉,暂时无法提供与“COM-R5W-HT-580-R”相匹配的价格&库存,您可以联系我们找货
