3CH DC/DC + 1CH LDO
Power Management IC
EA3056
Datasheet
General Description
The EA3056 is a 4-CH power management IC for applications powered by one Li-Ion battery or a
DC 5V adapter. It integrates three synchronous buck regulators and one N-MOS LDO in a single
chip. The internal compensation architecture simplifies the application circuit design. Besides,
the independent enable control makes the designer have the greatest flexibility to optimize timing
for power sequencing purposes. The EA3056 is available in a 24 pin QFN 4x4 package.
Features
2.7V to 5.5V Input Voltage Range
Three Buck Converters
I2C Controlled VID Programmable Reference Voltage from 0.58V to 0.8V
-- 6 Bits VID in 5mV Steps
Output Voltage Can Also be Set by Resistor Divider
-- The Initial Reference Voltage is 0.6V
Continuous Load Current: 3A (CH1), 1.5A (CH2), 2A (CH3)
Peak Load Current: 3.5A (CH1), 2A (CH2), 2.5A (CH3)
Fixed 1.5MHz Switching Frequency
180° Out of Phase Operation
100% Duty Cycle Low Dropout Operation
Independent Enable Control
Internal Compensation
Cycle-by-Cycle Current Limit
很抱歉,暂时无法提供与“EA3056QDR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 3+3.80160
- 30+3.04560
- 90+2.67840
- 300+2.28960
- 1500+2.06280
- 3000+1.95480
