DRP-480S-48
DRP-480S-48
    SUNPOWER
DRP-480S-48 数据手册
Sunpower (UK) Ltd, Orion House, Calleva Park, Aldermaston, Berkshire, RG7 8SN. Tel: +44 (0)118 981 1001 Fax: +44 (0)118 981 2002 Email: sales@sunpower-uk.com DRP-480S Series - 480W Single Output PFC Function DIN RAIL Power Sup Home > Products >Enclosed > 480W Single Output PFC Function DIN RAIL Power Sup Features Standards AC input range selected by switch Built-in passive PFC function compliance to EN61000-3-2 High efficiency 89% and low dissipation Protections: Short circuit/Over load/Over voltage/Over temperature Cooling by free air convection Built-in constant current limiting circuit Can be installed on DIN rail TS-35/7.5 or 15 UL 508 (industrial control equipment) approved EN61000-6-2(EN50082-2) industrial immunity level 100% full load burn-in test Specification INRUSH CURRENT (MAX.) EFFICIENCY 30A/115VAC 50A/230VAC, cold start AC CURRENT 11A/115VAC 4A/230VAC POWER FACTOR >0.7 230VAC only FREQUENCY RANGE 47 ~ 63Hz VOLTAGE RANGE 90 ~ 132VAC / 180 ~ 264VAC by switch VIBRATION 10 ~ 500Hz, 2G 10min/1cycle, 60min. each along X,Y,Z axes TEMP. COEFFICIENT ?0.03%/?C (0 ~ 50?C) WITHSTAND VOLTAGE I/P-O/P: 3KVAC I/P-FG: 1.5KVAC O/P-FG: 0.5KVAC ISOLATION RESISTANCE STORAGE TEMPERATURE, HUMIDITY MTBF I/P-O/P, I/P-FG, O/P-FG:100M Ohms/500VDC EMC Compliance to EN55011 CISPR11), EN55022 (CISPR22), EN61204-3 Class B; EN61204-3; EN61000-3-2,-3; EN6 WORKING TEMPERATURE, HUMIDITY LEAKAGE CURRENT OVER LOAD PROTECTION OVER VOLTAGE PROTECTION OVER TEMPERATURE PROTECTION SETUP, RISE, HOLD TIME SAFETY STANDARDS 89% typically -40?C ~ +85?C, 10 ~ 95% RH 187.9Khrs min. MIL-HDBK-217F (25?C) -10?C ~ +70?C (Refer to output load derating curve), 20 ~ 90% RH non-condensing
DRP-480S-48 价格&库存
很抱歉,暂时无法提供与“DRP-480S-48”相匹配的价格&库存,您可以联系我们找货
