H150/2B
H150/2B
    BRAUER
    BRAUER - H150/2B - Toggle Clamp, Horizontal, 150 N Holding Force, 5.5 mm Hole, 53 mm x 170 mm
H150/2B 数据手册
® HORIZONTAL CLAMPS G Features: Horizontal clamps are used where height restrictions prevent the use of a Vertical clamp, or where the action of the clamping arm and handle rotating in opposite directions is more suitable. The geometry of Brauer Horizontal clamps has been designed to ensure that the clamp opens and closes with a smooth and continuous action. The side plates have been designed so as to provide a guard against mechanism finger trapping. A comfortable, cushioned PVC handle grip is fitted to all Horizontal clamps. Horizontal models except H700 and additional products have a closed end to the clamping arm for rigidity of construction and to retain the spindle or setscrew if it should loosen. G Specification: The main components are of zinc plated and passivated steel. Rivets are of stainless steel which burnishes and work-hardens with use, the rivets of the larger clamps rotating in hardened bushes or directly in the close-toleranced holes of hardened parts. ® HORIZONTAL CLAMPS H50 SERIES MODEL H50/1B Arm opens through 85° Arm: The spindle position is adjustable along the arm. Base: Straight. Nominal Holding Force: 50 daN Weight: 0.033 Kg Supplied complete with: MB0520 Setscrew & nuts. FW05/09 Flanged washers. See “Accessories” for other items. Handle opens through 65° H50 SERIES MODEL H50/2B Arm: The spindle position is adjustable along the arm. Base: Flanged. Nominal Holding Force: 50 daN Weight: 0.036 Kg Supplied complete with: MB0520 Setscrew & nuts. FW05/09 Flanged washers. See “Accessories” for other items. Arm opens through 85° 9.5 H50 SERIES MODEL H50/2BSS Arm: The spindle position is adjustable along the arm. Base: Flanged. Nominal Holding Force: 50 daN Weight: 0.036 Kg Supplied complete with: Setscrew & nuts. Flanged washers. Material: BS 304 S15. WEB: www.brauer.co.uk Arm opens through 85° Handle opens through 65° CLAMPING PRODUCTS Handle opens through 65° 9.5 EMAIL: sales@brauer.co.uk 77 ® HORIZONTAL CLAMPS H50 SERIES MODEL H50/2C Arm: The spindle is in a fixed position. Base: Flanged. Nominal Holding Force: 50 daN Weight: 0.025 Kg Supplied complete with: MB0520 Setscrew & nuts. See “Accessories” for other items. Arm opens through 85° Handle opens through 65° CLAMPING PRODUCTS H50 SERIES MODEL H50/2BL 78 Arm: The spindle position is adjustable along the arm. Base: Left hand flanged. Nominal Holding Force: 50 daN Weight: 0.02 Kg Supplied complete with: MB0520 Setscrew & nuts. FW05/09 Flanged washers. See “Accessories” for other items. Arm opens through 85° Handle opens through 65° H50 SERIES MODEL H50/2BR Arm: The spindle position is adjustable along the arm. Base: Right hand flanged. Nominal Holding Force: 50 daN Weight: 0.02 Kg Supplied complete with: MB0520 Setscrew & nuts. FW05/09 Flanged washers. See “Accessories” for other items. Arm opens through 85° Handle opens through 65° CALL US AT: 00 44 (0)1908 374022 OR FAX US AT: 00 44 (0)1908 641628 ® HORIZONTAL CLAMPS H75 SERIES MODEL H75/1B Arm: The spindle position is adjustable along the arm. Base: Straight. Nominal Holding Force: 75 daN Weight: 0.10 Kg Supplied complete with: MB0535 Setscrew & nuts. FW05/10 Flanged washers. NC/05 Neoprene cover. See “Accessories” for other items. Arm opens through 90° Handle opens through 75° H75 SERIES MODEL H75/1BSS Arm opens through 90° Handle opens through 75° H75 SERIES MODEL H75/1C Arm: The spindle is in a fixed position. Base: Straight. Nominal Holding Force: 75 daN Weight: 0.10 Kg Supplied complete with: MB0535 Setscrew & nuts. NC/05 Neoprene cover. See “Accessories” for other items. WEB: www.brauer.co.uk Arm opens through 90° Handle opens through 75° EMAIL: sales@brauer.co.uk CLAMPING PRODUCTS Arm: The spindle position is adjustable along the arm. Base: Straight. Nominal Holding Force: 75 daN Weight: 0.10 Kg Supplied complete with: MB0535 Setscrew & nuts. FW05/10 Flanged washers. NC/05 Neoprene cover. Material: BS 304 S15. 79 ® HORIZONTAL CLAMPS H75 SERIES MODEL H75/2B for front mounting use bracket Model FM1 Arm: The spindle position is adjustable along the arm. Base: Flanged. Nominal Holding Force: 75 daN Weight: 0.10 Kg Supplied complete with: MB0535 Setscrew & nuts. FW05/10 Flanged washers. NC/05 Neoprene cover. See “Accessories” for other items. Arm opens through 90° Handle opens through 75° CLAMPING PRODUCTS H75 SERIES MODEL H75/2BSS 80 Arm: The spindle position is adjustable along the arm. Base: Flanged. Nominal Holding Force: 75 daN Weight: 0.10 Kg Supplied complete with: Setscrew & nuts. Flanged washers. Neoprene cover. Material: BS 304 S15. Arm opens through 90o Handle opens through 75o H75 SERIES MODEL H75/2C for front mounting use bracket Model FM1 Arm: The spindle is in a fixed position. Base: Flanged. Nominal Holding Force: 75 daN Weight: 0.10 Kg Supplied complete with: MB0535 Setscrew & nuts. NC/Neoprene cover. See “Accessories” for other items. Arm opens through 90° Handle opens through 75° CALL US AT: 00 44 (0)1908 374022 OR FAX US AT: 00 44 (0)1908 641628 ® HORIZONTAL CLAMPS H150 SERIES MODEL H150/1B Arm: The spindle position is adjustable along the arm. Base: Straight. Nominal Holding Force: 150 daN Weight: 0.25 Kg Supplied complete with: MB0650 Setscrew & nuts. NC/06 Neoprene cover. FW06/12 Flanged washers. See “Accessories” for other items. Arm opens through 90° Handle opens through 80° H150 SERIES MODEL H150/1BSS Arm opens through 90° Handle opens through 80° H150 SERIES MODEL H150/1C Arm: The spindle is in a fixed position. Base: Straight. Nominal Holding Force: 150 daN Weight: 0.25 Kg Supplied complete with: MB0650 Setscrew & nuts. NC/06 Neoprene cover. See “Accessories” for other items. WEB: www.brauer.co.uk Arm opens through 90° Handle opens through 80° EMAIL: sales@brauer.co.uk CLAMPING PRODUCTS Arm: The spindle position is adjustable along the arm. Base: Straight. Nominal Holding Force: 150 daN Weight: 0.25 Kg Supplied complete with: MB0650 Setscrew & nuts. NC/06 Neoprene cover. FW06/12 Flanged washers. Material: BS 304 S15. 81 ® HORIZONTAL CLAMPS H150 SERIES MODEL H150/2B for front mounting use bracket Model FM2 Arm: The spindle position is adjustable along the arm. Base: Flanged. Nominal Holding Force: 150 daN Weight: 0.25 Kg Supplied complete with: MB0650 Setscrew & nuts. NC/06 Neoprene cover. FW06/12 Flanged washers. See “Accessories” for other items. Arm opens through 90° Handle opens through 80° CLAMPING PRODUCTS H150 SERIES MODEL H150/2BSS 82 Arm: The spindle position is adjustable along the arm. Base: Flanged. Nominal Holding Force: 150 daN Weight: 0.10 Kg Supplied complete with: Setscrew & nuts. Flanged washers. Material: BS 304 S15. Arm opens through 90° Handle opens through 80° H150 SERIES MODEL H150/2C for front mounting use bracket Model FM2 Arm: The spindle is in a fixed position. Base: Flanged. Nominal Holding Force: 150 daN Weight: 0.25 Kg Supplied complete with: MB0650 Setscrew & nuts. NC/06 Neoprene cover. See “Accessories” for other items. Arm opens through 90° Handle opens through 80° CALL US AT: 00 44 (0)1908 374022 OR FAX US AT: 00 44 (0)1908 641628 ® HORIZONTAL CLAMPS H250 SERIES MODEL H250/1A Arm: 2-piece “solid” arm with spindle retainer supplied loose for welding in the desired position. Base: Straight. Nominal Holding Force: 250 daN Weight: 0.50 Kg Supplied complete with: MB0860 Setscrew & nuts. R/08 Spindle retainer. See “Accessories” for other items. Arm opens through 95° Handle opens through 80° H250 SERIES MODEL H250/1AL 236 Arm opens through 95° Handle opens through 80° 92 42 H250 SERIES MODEL H250/1B for ‘T’ Bar Accessory order Model T250 Arm: The spindle position is adjustable along the arm. Base: Straight. Nominal Holding Force: 250 daN Weight: 0.50 Kg Supplied complete with: MB0860 Setscrew & nuts. FW08/15 Flanged washers. See “Accessories” for other items. WEB: www.brauer.co.uk Arm opens through 95° Handle opens through 80° EMAIL: sales@brauer.co.uk CLAMPING PRODUCTS Arm: Solid arm with spindle retainer supplied loose for welding in the desired position. 10mm added to arm length over H250/1A model. Base: Straight. Nominal Holding Force: 250 daN Weight: 0.50 Kg Supplied complete with: MB0860 Setscrew & nuts. R/08 Spindle retainer. See “Accessories” for other items. 83 ® HORIZONTAL CLAMPS H250 SERIES MODEL H250/2A for front mounting use bracket Model FM2 Arm: 2-piece “solid” arm with spindle retainer supplied loose for welding in the desired position. Base: Flanged. Nominal Holding Force: 250 daN Weight: 0.50 Kg Supplied complete with: MB0860 Setscrew & nuts. R/08 Spindle retainer. See “Accessories” for other items. Arm opens through 90° M10 x 80 Arm opens through 95° Handle opens through 80° H250 SERIES MODEL H250/2AL CLAMPING PRODUCTS for front mounting use bracket Model FM2 84 236 Arm: Solid arm with spindle retainer supplied loose for welding in the desired position. 10mm added to arm length over H250/2A model. Base: Flanged. Nominal Holding Force: 250 daN Weight: 0.50 Kg Supplied complete with: MB0860 Setscrew & nuts. R/08 Spindle retainer. See “Accessories” for other items. Arm opens through 95° Handle opens through 80° 92 H250 SERIES MODEL H250/2B for front mounting use bracket Model FM2 Arm: The spindle position is adjustable along the arm. Base: Flanged. Nominal Holding Force: 250 daN Weight: 0.50 Kg Supplied complete with: MB0860 Setscrew & nuts. FW08/15 Flanged washers. See “Accessories” for other items. Arm opens through 95° Handle opens through 80° CALL US AT: 00 44 (0)1908 374022 OR FAX US AT: 00 44 (0)1908 641628 ® HORIZONTAL CLAMPS H350 SERIES MODEL H350/1A Arm: 2-piece “solid” arm with spindle retainer supplied loose for welding in the desired position. Base: Straight. Nominal Holding Force: 350 daN Weight: 0.90 Kg Supplied complete with: MB1080 Setscrew & nuts. R/10 Spindle retainer. See “Accessories” for other items. Arm opens through 90° Handle opens through 75° for ‘T’ Bar Accessory order Model T350 Arm: The spindle position is adjustable along the arm. Base: Straight. Nominal Holding Force: 350 daN Weight: 0.90 Kg Supplied complete with: MB1080 Setscrew & nuts. FW10/20 Flanged washers. See “Accessories” for other items. H350 SERIES MODEL H350/2A for front mounting use bracket Model FM3 Arm: 2-piece “solid” arm with spindle retainer supplied loose for welding in the desired position. Base: Flanged. Nominal Holding Force: 350 daN Weight: 0.90 Kg Supplied complete with: MB1080 Setscrew & nuts. R/10 Spindle retainer. See “Accessories” for other items. WEB: www.brauer.co.uk Arm opens through 90° Handle opens through 75° EMAIL: sales@brauer.co.uk CLAMPING PRODUCTS H350 SERIES MODEL H350/1B 85 ® HORIZONTAL CLAMPS H350 SERIES MODEL H350/2B for front mounting use bracket Model FM3 Arm: The spindle position is adjustable along the arm. Base: Flanged. Nominal Holding Force: 350 daN Weight: 0.90 Kg Supplied complete with: MB1080 Setscrew & nuts. FW10/20 Flanged washers. See “Accessories” for other items. Arm opens through 90° Handle opens through 75° CLAMPING PRODUCTS H450 SERIES MODEL H450/1A 86 Arm: Solid with spindle retainer supplied loose for welding in the desired position. Base: Straight. Nominal Holding Force: 450 daN Weight: 1.60 Kg Supplied complete with: MB12100 Setscrew & nuts. R/12 Spindle retainer. See “Accessories” for other items. Arm opens through 90° Arm: The spindle position is adjustable along the arm. Base: Straight. Nominal Holding Force: 450 daN Weight: 1.60 Kg Supplied complete with: MB12100 Setscrew & nuts. FW12/23 Flanged washers. See “Accessories” for other items. Arm opens through 90° Handle opens through 75° H450 SERIES MODEL H450/1B for ‘T’ Bar Accessory order Model T450 Handle opens through 75° CALL US AT: 00 44 (0)1908 374022 OR FAX US AT: 00 44 (0)1908 641628 ® HORIZONTAL CLAMPS H450 SERIES MODEL H450/2A for front mounting use bracket Model FM3 Arm: Solid with spindle retainer supplied loose for welding in the desired position. Base: Flanged. Nominal Holding Force: 450 daN Weight: 1.60 Kg Supplied complete with: MB12100 Setscrew & nuts. R/12 Spindle retainer. See “Accessories” for other items. Arm opens through 90° Handle opens through 75° H450 SERIES MODEL H450/2B Arm opens through 90° Handle opens through 75° H700 SERIES MODEL H700 for ‘T’ Bar Accessory order Model T450 Arm: The spindle position is adjustable along the arm. Base: Flanged. Nominal Holding Force: 700 daN Weight: 1.15 Kg Supplied complete with: MB12100 Setscrew & nuts. FW12/23 Flanged washers. This heavy duty clamp features a cast steel base with central hole for optional “tee” bolt mounting. See “Accessories” for other items. WEB: www.brauer.co.uk Arm opens through 90° EMAIL: sales@brauer.co.uk Handle opens through 85° CLAMPING PRODUCTS for front mounting use bracket Model FM3 Arm: The spindle position is adjustable along the arm. Base: Flanged. Nominal Holding Force: 450 daN Weight: 1.60 Kg Supplied complete with: MB12100 Setscrew & nuts. FW12/23 Flanged washers. See “Accessories” for other items. 87
H150/2B 价格&库存
很抱歉,暂时无法提供与“H150/2B”相匹配的价格&库存,您可以联系我们找货
