HS-3806-UW
HS-3806-UW
    HZS(鸿之森)
    SMD,1x3.8mm
    白灯
HS-3806-UW 数据手册
深圳市鸿之森电子有限公司 产品规格书 SPECIFICATION 客户名称 Customer Name 客户料号 Customer No. 产品描述 Product Description 产品型号 Product Model HS-3806UW 鸿之森确 认 客户确认 Orient Confirm Customer Confirm SIDE VIEW WHITE LED 0.06W 批准 审核 Approved by Checked by Prepared by Approved by Zhongjiang Zhouyuanjie Huanghaijun 结果判定: Judge outcome Part No:HS-3806-UW 编制 批准 品质 工程 Quality Engineering 结果判定: OK Judge outcome Ver:A/2 Page 1 of 12 深圳市鸿之森电子有限公司 Features ● ●Package: 3.8*1.0*0.6mm ●Emitted colour:White ●Soldering methods:SMT assembly avaliable ●RoHS compliant & Pb free Applications ● ●LCD backlight ●Decoration lighting ●Mobile phone, panel computer backlight Package Outline Dimensions ● Recommended solding pad design Notes:tolerances Unless Dimension: X.X ±0.1, X.XX±0.05, Unit=mm Notes: 1、All dimensions are in millimeters. 2、Tolerances are 0.02mm unless otherwise noted. Part No:HS-3806-UW 本资料可能适时修正,请注意版本 Ver:A/2 Page 2 of 12 深圳市鸿之森电子有限公司 Absolute maximum ratings at Ta=25℃ ● Parameter Symbol Typical Unit Power dissipation Pd 100 mw Forward current If 30 mA Reverse voltage Vr 5 V Operating temperature range Top -40 ~+85 ℃ Storage temperature range Tstg -40~+100 ℃ Peak pulsing current Ifp 100 mA Electrostatic Discharge ESD 2000(HBM) V Soldering temperature Tsld Reflow Soldering:260℃ for 10 secs Hand Soldering: 350℃ for 3 secs *IFP Conditions: Pulse Width≦10msec. and Duty cycle≦1/10. Electrical-optical characteristics at Ta=25℃ Test Parameter Condition Symbol Min. ● Typ. Max. Unit Forward voltage If=20mA Vf 2.9 -- 3.3 V Luminous intensity If=20mA IV -- -- -- mcd If=20mA X -- -- -- -- If=20mA Y -- -- -- -- Viewing angle If=20mA 2 θ 1/2 -- 120 -- Deg Reverse current Vr=5V IR -- -- 10 A CIE Chromaticity Notes: 1、Tolerance of luminous intensity is ±5%. 2、Tolerance of forward voltage is ±0.05V. Part No:HS-3806-UW Ver:A/2 Page 3 of 12 深圳市鸿之森电子有限公司 ● Typical optical characteristics curves Spectrum 1.2 Int ens ity 1.0 Em issi on 0.6 Rel ativ e 0.2 Directivity (Angle : 120 Ta = 25 C IF = 20mA 1 0.8 (a.u .) Lu min osit y Rel ativ e 0.4 0 350 450 550 W avelength 650 nm) 750 50 IFP = 20mA 30 20 10 2.4 2.8 3.2 3.6 Foward voltage(v) Ambient Temperature vs. Chromaticity Coordinate ( 0.35 0.31 0.30 0.29 40 50 60 70 80 0 90 60 30 4.0 4.4 int en sit y( %) lu mi no us Re lati ve 160 0 0.5 IFP = 20mA 140 120 100 80 60 0 10 20 30 Forward Current vs. Chromaticity Coordinate ( D) 40 50 Foward current(mA) D) 0.35 0.34 -30 C 0C 25C 50 C 0.32 30 0.5 0.34 y 20 IF = 20mA IFP = 20mA 0.33 10 Foward current vs.Relative luminous intensity 40 0 0 Ta = 25 C Radiation Angle Foward current vs.Forward voltage cu rre nt( m A) Fo wa rd ) y 0.30 0.31 0.32 0.33 x 0.33 1mA 5mA 0.32 20mA 0.31 85 C 0.34 Ta = 25 C 0.30 0.29 0.30 50mA 100mA 0.31 0.32 0.33 0.34 x 1 90 深圳市鸿之森电子有限公司 ● CIE Chromaticity Diagrams 0.34 0.335 0.33 0.325 0.32 C6 0.315 0.31 0.305 0.3 C4 0.295 0.29 W9 H4 C3 F4 W8 C2 H3 W7 C1 H2 F3 F2 0.285 0.28 0.275 0.27 0.265 0.26 W6 0.255 0.25 0.245 0.24 0.235 0.23 0.225 0.22 0.215 0.21 C0 C5 H6 F6 H5 F5 H7 F7 H1 F1 W5 W4 W3 W2 0.205 0.2 0.230 0.235 0.240 0.245 0.250 0.255 0.260 0.265 0.270 0.275 0.280 0.285 0.290 0.295 0.300 0.305 0.310 0.315 0.320 0.325 0.330 ● Color Ranks(IF=20mA,Ta=25℃) BIN Code W2 W5 X Y 0.2453 0.2392 0.2448 0.2508 0.262 0.256 0.2616 0.2676 0.2109 0.213 0.2238 0.2216 0.2431 0.2453 0.256 0.2538 BIN Code W3 W6 X Y 0.2508 0.2448 0.2504 0.2564 0.2676 0.2616 0.2672 0.2731 0.2216 0.2238 0.2345 0.2323 0.2538 0.256 0.2668 0.2644 Ver:A/2 BIN Code W4 W7 X Y 0.2564 0.2504 0.256 0.262 0.2731 0.2672 0.2728 0.2788 0.2323 0.2345 0.2453 0.2431 0.2644 0.2668 0.2776 0.2754 Page 5 of 12
HS-3806-UW 价格&库存
很抱歉,暂时无法提供与“HS-3806-UW”相匹配的价格&库存,您可以联系我们找货
