DB682J3CD25H200D9R
DB682J3CD25H200D9R
    CARLI(凯励)
    插件,P=15mm
    薄膜电容 径向
DB682J3CD25H200D9R 数据手册
DMB MKP82 双面金属化聚丙烯膜电容器(串联盒装型) Double Sided Metallized Polypropylene Film Capacitor (Series &Box-Type) CARLI DMB 223J 1000V 特点 ●双面金属化聚丙烯膜,串联无感式捲绕结构 ●高频损耗小 ●内部温升低 ●塑胶外壳,阻燃环氧树脂填充 FEATURES: ● Double sided metallized polypropylene film , series nonwound construction . ● Low loss at high frequency ● Small inherent temperature rise ● Plastic case ,Flame retardent epoxy resin sealing 典型应用 TYPE APPLICATION: ● 广泛用於高压高频脉冲电路中 ● Widely used in high voltage and frequency and pulse circuit ●电视机偏转电路(S-校正和行逆程波形)和显示器中 ● Deflection circuits in TV sets (s -correction and fly-back tuning )and monitors ●电子镇流器和节能灯中 ●吸收和SCR整流电路 ● Lamp capacitor for electronic ballast and compact lamps ● Snubber and SCR commutating circuits 技术要求specifications 引用标准/Reference Standard GB/T 10190 (IEC 60384-16) 气候类别/Climatic Category 40/105/56 额定温度/Rated Temperature 85℃ 工作温度范围 /Operating Temperature Range -40℃ -- +105℃. (+85℃~+105℃:derating factor 1.25%per℃ for UR(dc) 额定电压/Rated voltage 630Vdc,800Vdc,1000Vdc,1200Vdc,1600Vdc,2000Vdc,2500Vdc 容量范围/Capacitance range 0.001µF~0.33µF 容差/Capacitance tolerance ±5% (J),±10% (K)±20%(M) Voltage Proof 耐电压 1.6 UR , 2s 损失角/Dissapation factor ≤0.1% (1KHz at 20~25℃) 绝缘阻抗/Insulation Resistance ≥50 000MΩ,CR≤0.33µF ≥15 000 s,CR > 0.33µF ,( at 100VDC, 1min ,20~25℃) 最大脉冲爬升速率Maximum Pulse Rise Time(dV/dt): 若实际工作电压U比额定电压U R 低,电容器可工作在更高的dV/dt场 合。这样dV/dt允许值应为右表值乘UR/U. If the working voltage (U) is lower than the rated voltage (UR), the capacitor can be worked at a higher dV/dt.In thiscase,the maximum allowed dV/dt is obtain by multiplyingthe right value with UR/U. 72 UR(V) dV/dt(V/µs) P=10 P=15.0 P=22.5 P=27.5 630/800 1200 900 400 200 1000/1200 2200 2000 800 400 1600 -- 4500 1800 900 2000 -- 9500 4500 -- 2500 -- 10000 5000 -- DMB MKP82 外形尺寸 Dimensions(mm) 630VDC 800VDC DIMENSIONS 尺寸 (mm) CAP (μF) DIMENSIONS 尺寸 (mm) CARLI P/N CAP (μF) 10 DB102 * 2JC1 ■●□□□⊙■ R 0.6 10 4 0.6 9 4 13 9 0.0027 13 0.0033 W (±0.5 mm) H (±0.5 mm) T dΦ (±0.5 (±0.05 mm) mm) 0.001 13 9 4 0.6 0.0012 13 9 4 0.0015 13 9 0.0018 13 0.0022 P (±1 mm) CARLI P/N W (±0.5 mm) H (±0.5 mm) T (±0.5 mm) dΦ (±0.05 mm) P (±1 mm) 0.001 13 9 4 0.6 10 DB102 * 2KC1 ■●□□□⊙■ R DB122 * 2JC1 ■●□□□⊙■ R 0.0012 13 9 4 0.6 10 DB122 * 2KC1 ■●□□□⊙■ R 10 DB152 * 2JC1 ■●□□□⊙■ R 0.0015 13 9 4 0.6 10 DB152 * 2KC1 ■●□□□⊙■ R 0.6 10 DB182 * 2JC1 ■●□□□⊙■ R 0.0018 13 9 4 0.6 10 DB182 * 2KC1 ■●□□□⊙■ R 4 0.6 10 DB222 * 2JC1 ■●□□□⊙■ R 0.0022 13 9 4 0.6 10 DB222 * 2KC1 ■●□□□⊙■ R 9 4 0.6 10 DB272 * 2JC1 ■●□□□⊙■ R 0.0027 13 9 4 0.6 10 DB272 * 2KC1 ■●□□□⊙■ R 13 9 4 0.6 10 DB332 * 2JC1 ■●□□□⊙■ R 0.0033 13 11 5 0.6 10 DB332 * 2KC2 ■●□□□⊙■ R 0.0039 13 9 4 0.6 10 DB392 * 2JC1 ■●□□□⊙■ R 0.0039 13 11 5 0.6 10 DB392 * 2KC2 ■●□□□⊙■ R 0.0047 13 9 4 0.6 10 DB472 * 2JC1 ■●□□□⊙■ R 0.0047 13 12 6 0.6 10 DB472 * 2KC3 ■●□□□⊙■ R 0.0056 13 9 4 0.6 10 DB562 * 2JC1 ■●□□□⊙■ R 0.0056 13 12 6 0.6 10 DB562 * 2KC3 ■●□□□⊙■ R 0.0068 13 11 5 0.6 10 DB682 * 2JC2 ■●□□□⊙■ R 0.0068 13 12.5 7 0.6 10 DB682 * 2KC4 ■●□□□⊙■ R 0.0082 13 11 5 0.6 10 DB822 * 2JC2 ■●□□□⊙■ R 0.0082 13 12.5 7 0.6 10 DB822 * 2KC4 ■●□□□⊙■ R 0.01 13 12 6 0.6 10 DB103 * 2JC3 ■●□□□⊙■ R 0.01 18 11 5 0.8 15 DB103 * 2KD1 ■●□□□⊙■ R 0.012 18 11 5 0.8 15 DB123 * 2JD1 ■●□□□⊙■ R 0.012 18 11 5 0.8 15 DB123 * 2KD1 ■●□□□⊙■ R 0.015 18 11 5 0.8 15 DB153 * 2JD1 ■●□□□⊙■ R 0.015 18 11 5 0.8 15 DB153 * 2KD1 ■●□□□⊙■ R 0.018 18 11 5 0.8 15 DB183 * 2JD1 ■●□□□⊙■ R 0.018 18 12 6 0.8 15 DB183 * 2KD2 ■●□□□⊙■ R 0.022 18 11 5 0.8 15 DB223 * 2JD1 ■●□□□⊙■ R 0.022 18 12 6 0.8 15 DB223 * 2KD2 ■●□□□⊙■ R 0.027 18 12 6 0.8 15 DB273 * 2JD2 ■●□□□⊙■ R 0.027 18 13.5 7.5 0.8 15 DB273 * 2KD3 ■●□□□⊙■ R 0.033 18 12 6 0.8 15 DB333 * 2JD2 ■●□□□⊙■ R 0.033 18 13.5 7.5 0.8 15 DB333 * 2KD3 ■●□□□⊙■ R 0.039 18 13 6.5 0.8 15 DB393 * 2JD25 ●□□□⊙■ R 0.039 18 14.5 8.5 0.8 15 DB393 * 2KD4 ■●□□□⊙■ R 0.047 18 13.5 7.5 0.8 15 DB473 * 2JD3 ■●□□□⊙■ R 0.047 18 14.5 8.5 0.8 15 DB473 * 2KD4 ■●□□□⊙■ R 0.056 18 14.5 8.5 0.8 15 DB563 * 2JD4 ■●□□□⊙■ R 0.056 18 16 10 0.8 15 DB563 * 2KD5 ■●□□□⊙■ R 0.068 18 14.5 8.5 0.8 15 DB683 * 2JD4 ■●□□□⊙■ R 0.068 18 16 10 0.8 15 DB683 * 2KD5 ■●□□□⊙■ R 0.082 18 14.5 8.5 0.8 15 DB823 * 2JD4 ■●□□□⊙■ R 0.082 18 18.5 11 0.8 15 DB823 * 2KD6 ■●□□□⊙■ R 0.1 18 16 10 0.8 15 DB104 * 2JD5 ■●□□□⊙■ R 0.1 26.5 17 8.5 0.8 22.5 DB104 * 2KE3 ■●□□□⊙■ R 0.12 18 18.5 11 0.8 15 DB124 * 2JD6 ■●□□□⊙■ R 0.12 26.5 19 10 0.8 22.5 DB124 * 2KE4 ■●□□□⊙■ R 0.15 26.5 17 8.5 0.8 22.5 DB154 * 2JE3 ■●□□□⊙■ R 0.15 26 20 11 0.8 22.5 DB154 * 2KE5 ■●□□□⊙■ R 0.22 26 20 11 0.8 22.5 DB224 * 2JE5 ■●□□□⊙■ R 0.22 26 21.5 12 0.8 22.5 DB224 * 2KE6 ■●□□□⊙■ R 73 DMB MKP82 外形尺寸 Dimensions(mm) 1200VDC/1250VDC 1000VDC DIMENSIONS 尺寸 (mm) DIMENSIONS 尺寸 (mm) CAP (μF) CARLI P/N CAP (μF) H (±0.5 mm) 0.001 13 9 4 0.6 10 DB102 * 3BC1 ■●□□□⊙■ R 0.0012 13 9 4 0.6 10 DB122 * 3BC1 ■●□□□⊙■ R 0.0015 13 9 4 0.6 10 DB152 * 3BC1 ■●□□□⊙■ R 0.0018 13 9 4 0.6 10 DB182 * 3BC1 ■●□□□⊙■ R 0.0022 13 11 5 0.6 10 DB222 * 3BC2 ■●□□□⊙■ R 0.0027 13 11 5 0.6 10 DB272 * 3BC2 ■●□□□⊙■ R 0.0033 13 12 6 0.6 10 DB332 * 3BC3 ■●□□□⊙■ R 0.0039 13 12.5 7 0.6 10 DB392 * 3BC4 ■●□□□⊙■ R DB562 * 3AC4 ■●□□□⊙■ R 0.0047 13 12.5 7 0.8 10 DB472 * 3BC4 ■●□□□⊙■ R 10 DB682 * 3AC4 ■●□□□⊙■ R 0.0056 18 11 5 0.8 15 DB562 * 3BD1 ■●□□□⊙■ R 0.8 15 DB822 * 3AD1 ■●□□□⊙■ R 0.0068 18 11 5 0.8 15 DB682 * 3BD1 ■●□□□⊙■ R 5 0.8 15 DB103 * 3AD1 ■●□□□⊙■ R 0.0082 18 11 5 0.8 15 DB822 * 3BD1 ■●□□□⊙■ R 11 5 0.8 15 DB123 * 3AD1 ■●□□□⊙■ R 0.01 18 11 5 0.8 15 DB103 * 3BD1 ■●□□□⊙■ R 18 12 6 0.8 15 DB153 * 3AD2 ■●□□□⊙■ R 0.012 18 12 6 0.8 15 DB123 * 3BD2 ■●□□□⊙■ R 0.018 18 12 6 0.8 15 DB183 * 3AD2 ■●□□□⊙■ R 0.015 18 12 6 0.8 15 DB153 * 3BD2 ■●□□□⊙■ R 0.022 18 13 6.5 0.8 15 DB223 * 3AD25 ●□□□⊙■ R 0.027 18 13.5 7.5 0.8 15 DB273 * 3AD3 ■●□□□⊙■ R 0.018 18 13.5 7.5 0.8 15 DB183 * 3BD3 ■●□□□⊙■ R 0.033 18 14.5 8.5 0.8 15 DB333 * 3AD4 ■●□□□⊙■ R 0.022 18 13.5 7.5 0.8 15 DB223 * 3BD3 ■●□□□⊙■ R 0.039 18 16 10 0.8 15 DB393 * 3AD5 ■●□□□⊙■ R 0.027 18 17 8.5 0.8 15 DB273 * 3BD42 ●□□□⊙■ R 0.047 18 17 8.5 0.8 15 DB473 * 3AD42 ●□□□⊙■ R 0.033 18 17 8.5 0.8 15 DB333 * 3BD42 ●□□□⊙■ R 0.056 18 18.5 11 0.8 15 DB563 * 3AD6 ■●□□□⊙■ R 0.039 18 18.5 11 0.8 15 DB393 * 3BD6 ■●□□□⊙■ R 0.068 26.5 17 8.5 0.8 22.5 DB683 * 3AE3 ■●□□□⊙■ R 0.047 18 18.5 11 0.8 15 DB473 * 3BD6 ■●□□□⊙■ R 0.082 26.5 17 8.5 0.8 22.5 DB823 * 3AE3 ■●□□□⊙■ R 0.056 26.5 17 8.5 0.8 22.5 DB563 * 3BE3 ■●□□□⊙■ R 0.1 26.5 19 10 0.8 22.5 DB104 * 3AE4 ■●□□□⊙■ R 0.068 26.5 19 10 0.8 22.5 DB683 * 3BE4 ■●□□□⊙■ R 0.12 26 20 11 0.8 22.5 DB124 * 3AE5 ■●□□□⊙■ R 0.082 26.5 19 10 0.8 22.5 DB823 * 3BE4 ■●□□□⊙■ R 0.15 26 21.5 12 0.8 22.5 DB154 * 3AE6 ■●□□□⊙■ R 0.22 26 25 16.5 0.8 22.5 DB224 * 3AE8 ■●□□□⊙■ R 0.1 26 20 11 0.8 22.5 DB104 * 3BE5 ■●□□□⊙■ R 0.22 32 25 15 0.8 27.5 DB224 * 3AF3 ■●□□□⊙■ R 0.12 26 21.5 12 0.8 22.5 DB124 * 3BE6 ■●□□□⊙■ R 0.33 32 28 18 0.8 27.5 DB334 * 3AF4 ■●□□□⊙■ R 0.15 26 25 16.5 0.8 22.5 DB154 * 3BE8 ■●□□□⊙■ R H (±0.5 mm) 0.001 13 9 4 0.6 10 DB102 * 3AC1 ■●□□□⊙■ R 0.0012 13 9 4 0.6 10 DB122 * 3AC1 ■●□□□⊙■ R 0.0015 13 9 4 0.6 10 DB152 * 3AC1 ■●□□□⊙■ R 0.0018 13 9 4 0.6 10 DB182 * 3AC1 ■●□□□⊙■ R 0.0022 13 9 4 0.6 10 DB222 * 3AC1 ■●□□□⊙■ R 0.0027 13 11 5 0.6 10 DB272 * 3AC2 ■●□□□⊙■ R 0.0033 13 11 5 0.6 10 DB332 * 3AC2 ■●□□□⊙■ R 0.0039 13 12 6 0.6 10 DB392 * 3AC3 ■●□□□⊙■ R 0.0047 13 12 6 0.6 10 DB472 * 3AC3 ■●□□□⊙■ R 0.0056 13 12.5 7 0.6 10 0.0068 13 12.5 7 0.6 0.0082 18 11 5 0.01 18 11 0.012 18 0.015 74 T dΦ (±0.5 (±0.05 mm) mm) P (±1 mm) T dΦ (±0.5 (±0.05 mm) mm) P (±1 mm) CARLI P/N W (±0.5 mm) W (±0.5 mm) DMB MKP82 外形尺寸 Dimensions(mm) 1600VDC 2000VDC DIMENSIONS 尺寸 (mm) CAP (μF) DIMENSIONS 尺寸 (mm) W (±0.5 mm) H (±0.5 mm) T (±0.5 mm) dΦ (±0.05 mm) P (±1 mm) CARLI P/N CAP (μF) W (±0.5 mm) H (±0.5 mm) T (±0.5 mm) dΦ (±0.05 mm) P (±1 mm) CARLI P/N 0.001 13 11 5 0.6 10 DB102 * 3CC2 ■●□□□⊙■ R 0.001 18 11 5 0.8 15 DB102 * 3DD1 ■●□□□⊙■ R 0.0012 13 12 6 0.6 10 DB122 * 3CC3 ■●□□□⊙■ R 0.0012 18 11 5 0.8 15 DB122 * 3DD1 ■●□□□⊙■ R 0.0015 13 12 6 0.6 10 DB152 * 3CC3 ■●□□□⊙■ R 0.0015 18 11 5 0.8 15 DB152 * 3DD1 ■●□□□⊙■ R 0.0018 13 12.5 7 0.6 10 DB182 * 3CC4 ■●□□□⊙■ R 0.0018 18 12 6 0.8 15 DB182 * 3DD2 ■●□□□⊙■ R 0.0022 13 12.5 7 0.6 10 DB222 * 3CC4 ■●□□□⊙■ R 0.0022 18 12 6 0.8 15 DB222 * 3DD2 ■●□□□⊙■ R 0.0027 13 16 8 0.6 10 DB272 * 3CC5 ■●□□□⊙■ R 0.0027 18 13 6.5 0.8 15 DB272 * 3DD25 ●□□□⊙■ R 0.0033 13 16 8 0.6 10 DB332 * 3CC5 ■●□□□⊙■ R 0.0033 18 13.5 7.5 0.8 15 DB332 * 3DD3 ■●□□□⊙■ R 0.0039 18 11 5 0.8 15 DB392 * 3CD1 ■●□□□⊙■ R 0.0039 18 13.5 7.5 0.8 15 DB392 * 3DD3 ■●□□□⊙■ R 0.0047 18 11 5 0.8 15 DB472 * 3CD1 ■●□□□⊙■ R 0.0047 18 14.5 8.5 0.8 15 DB472 * 3DD4 ■●□□□⊙■ R 0.0056 18 12 6 0.8 15 DB562 * 3CD2 ■●□□□⊙■ R 0.0056 18 17 8.5 0.8 15 DB562 * 3DD42 ●□□□⊙■ R 0.0068 18 13 6.5 0.8 15 DB682 * 3CD25 ●□□□⊙■ R 0.0068 18 16 10 0.8 15 DB682 * 3DD5 ■●□□□⊙■ R 0.0082 18 13.5 7.5 0.8 15 DB822 * 3CD3 ■●□□□⊙■ R 0.0082 18 18.5 11 0.8 15 DB822 * 3DD6 ■●□□□⊙■ R 0.01 18 13.5 7.5 0.8 15 DB103 * 3CD3 ■●□□□⊙■ R 0.01 18 18.5 11 0.8 15 DB103 * 3DD6 ■●□□□⊙■ R 0.012 18 14.5 8.5 0.8 15 DB123 * 3CD4 ■●□□□⊙■ R 0.012 26.5 17 8.5 0.8 22.5 DB123 * 3DE3 ■●□□□⊙■ R 0.015 18 17 8.5 0.8 15 DB153 * 3CD42 ●□□□⊙■ R 0.015 26.5 19 10 0.8 22.5 DB153 * 3DE4 ■●□□□⊙■ R 0.018 18 16 8.5 0.8 15 DB183 * 3CD5 ■●□□□⊙■ R 0.018 26 20 11 0.8 22.5 DB183 * 3DE5 ■●□□□⊙■ R 0.022 18 18.5 11 0.8 15 DB223 * 3CD6 ■●□□□⊙■ R 0.022 26 21.5 12 0.8 22.5 DB223 * 3DE6 ■●□□□⊙■ R DB273 * 3CE3 ■●□□□⊙■ R 0.027 32 22 13 0.8 27.5 DB273 * 3DF2 ■●□□□⊙■ R 0.033 32 22 13 0.8 27.5 DB333 * 3DF2 ■●□□□⊙■ R 0.027 26.5 17 8.5 0.8 22.5 0.033 26.5 19 10 0.8 22.5 DB333 * 3CE4 ■●□□□⊙■ R 0.039 26.5 19 10 0.8 22.5 DB393 * 3CE4 ■●□□□⊙■ R 0.039 32 25 15 0.8 27.5 DB393 * 3DF3 ■●□□□⊙■ R 0.047 26 20 11 0.8 22.5 DB473 * 3CE5 ■●□□□⊙■ R 0.047 32 25 15 0.8 27.5 DB473 * 3DF3 ■●□□□⊙■ R 0.056 26 21.5 12 0.8 22.5 DB563 * 3CE6 ■●□□□⊙■ R 0.068 32 30 18 0.8 27.5 DB683 * 3DF4 ■●□□□⊙■ R 备注: 2500VDC CAP (μF) DIMENSIONS 尺寸 (mm) W H (±0.5 (±0.5 mm) mm) T (±0.5 mm) dΦ (±0.05 mm) P (±1 mm) CARLI P/N 0.001 18 11 5 0.8 15 DB102 * 3ED1 ■●□□□⊙■ R 0.0012 18 11 5 0.8 15 DB122 * 3ED1 ■●□□□⊙■ R 0.0015 18 12 6 0.8 15 DB152 * 3ED2 ■●□□□⊙■ R 0.0018 18 12 6 0.8 15 DB182 * 3ED2 ■●□□□⊙■ R 0.0022 18 13 6.5 0.8 15 DB222 * 3ED25 ●□□□⊙■ R 0.0027 18 13.5 7.5 0.8 15 DB272 * 3ED3 ■●□□□⊙■ R DB332 * 3ED4 ■●□□□⊙■ R 0.0033 18 14.5 8.5 0.8 15 0.0039 18 17 8.5 0.8 15 DB392 * 3ED42 ●□□□⊙■ R 0.0047 18 16 10 0.8 15 DB472 * 3ED5 ■●□□□⊙■ R 0.0056 18 18.5 11 0.8 15 DB562 * 3ED6 ■●□□□⊙■ R 0.0068 18 18.5 11 0.8 15 DB682 * 3ED6 ■●□□□⊙■ R DB822 * 3EE3 ■●□□□⊙■ R 0.0082 26.5 17 8.5 0.8 22.5 0.01 26.5 19 10 0.8 22.5 DB103 * 3EE4 ■●□□□⊙■ R 0.012 26.5 19 10 0.8 22.5 DB123 * 3EE4 ■●□□□⊙■ R DB153 * 3EE5 ■●□□□⊙■ R 0.015 26 20 11 0.8 22.5 0.018 32 20 11 0.8 27.5 DB183 * 3EF1 ■●□□□⊙■ R 0.022 32 22 13 0.8 27.5 DB223 * 3EF2 ■●□□□⊙■ R 0.033 32 25 15 0.8 27.5 DB333 * 3EF3 ■●□□□⊙■ R 0.047 32 28 18 0.8 27.5 DB473 * 3EF4 ■●□□□⊙■ R 1.“*”表示容量误差。 2."■"表示内部特征码。 3.“●”表示引線加工形式代码。 4."□□□"表示引線长度代码。 5.“⊙”表示引線长度误差代码。 6."R"=ROHS符合型; "H"=Halogen-Free无鹵型. 7. "# "当额定电压为1250Vdc时 ,第7~8位是3V。 1."*"=capacitance tolerance code, J=±5%, K=±10%, M=±20%. 2. "■"=Internal use。 3."●"=Lead Form Code :“L","H","K","M","N"…… 4."□□□"=Lead Length Code :“270”,“200”,“035”…… 5."⊙"=Lead Length Tolerance Code :“±0.3”,“±0.5,“±1”…… 6."R"=ROHS compliant. "H"=Halogen-Free compliant. 7."# "when the rated voltage is 1250Vdc ,the digit 7~8 is 3V . 75
DB682J3CD25H200D9R 价格&库存
很抱歉,暂时无法提供与“DB682J3CD25H200D9R”相匹配的价格&库存,您可以联系我们找货
