BMS13-48T10C01G022
BMS13-48T10C01G022
    BOEING
    BOEING - BMS13-48T10C01G022 - Wire, ETFE, Green, 22 AWG, 328 ft, 100 m
BMS13-48T10C01G022 数据手册
Boeing Spec Wire BMS 13-48 RoHS compliant Boeing Spec Wire BMS 13-48 product is available for the aerospace and military industries. All of our Boeing Spec Wire products are designed and tested to meet Boeing specifications for use in most areas of construction. Whether you are transmitting power, data, or signals. BMS13-48 cable is available in various configurations and made from the highest quality materials. You can choose conductors made from high strength copper alloy, silver coated, nickel coated, tinplated and more. BMS13-48 T20 C2 G20 Part number example BMS Specification BMS 13-48 Wire/Cable Type See first column of table below Cables can operate in temperatures from -65°C to +310°C, data bus from 50-120 ohms and can carry up to 600 volts. You should choose a design of cable based on the needs and conditions of your specific application. Class (Number of Conductors) Select a number between the Min and Max provided in the table below Wire Size (AWG) Select number between the Min and Max provided in the table below BMS 13-48 • Extruded XL-ETFE, 600V Wire and Cable -65ºC to +150ºC Type Class ‘C’ Wire Size ‘G’ Conductor Shield Plating Material Plating Jacket Material Min. Max. Min. Max. Material 1 1 5 24 10 Annealed Copper Tin - - - 2 1 5 24 16 HSCA Nickel - - - 3 1 5 24 10 Annealed Copper Tin Copper Tin XL-ETFE 4 2 5 24 12 Annealed Copper Tin - - XL-ETFE 5 1 5 24 16 HSCA Silver - - - 6 1 5 24 16 HSCA Silver Copper Tin XL-ETFE 7 2 5 24 16 HSCA Silver - - XL-ETFE 8 1 6 24 0000 Annealed Copper Tin - - - 9 1 6 24 16 HSCA Silver - - - 10 1 7 24 0000 Annealed Copper Tin - - - Other Boeing specifications available on request
BMS13-48T10C01G022 价格&库存
很抱歉,暂时无法提供与“BMS13-48T10C01G022”相匹配的价格&库存,您可以联系我们找货
