HDF1588E-B2
HDF1588E-B2
    HD(高清数字)
    SMD,1.1x1.4mm
    低损耗RF GPS + COMPASS + GLONASS滤波器,适用于GPS、COMPASS和GLONASS系统。支持2.0 MHz(GPS)、4.092 MHz(COMPASS)和8.34 MHz...
HDF1588E-B2 数据手册
规格书编号 SPEC NO: HDF1588EB5SP02 产品 规 格书 SPECIFICATION CUSTOMER 客 户: PRODUCT 产 品: SAW FILTER MODEL NO 型 号: HDF1588E-B2 MARKING 印 字: B044 PREPARED 编 制: CHECKED 审 核: APPROVED 批 准: D A T E 日 期: 2016-4-13 客户确认 CUSTOMER RECEIVED: 审核 CHECKED 批准 APPROVED 日期 DATE 无锡市好达电子有限公司 Shoulder Electronics Limited Factory Address: NO. 115, Gaoyun Road, Binhu Economic & Technology Development Area, Wuxi, Jiangsu, China. Tel:86-510-85629111 Country of origin: China www.shoulder.cn Tel:0755-82916880 Fax:0755-82916881 E-mail:info@shoulder.cn Page 1 of 9 SAW FILTER HDF1588E-B2 更改历史记录 History Record 更改日期 Date 2016-4-13 www.shoulder.cn 规格书编号 Spec. No. SP02 产品型号 Part No. 客户产品型号 Customer No. HDF1588E-B 2 Tel:0755-82916880 Fax:0755-82916881 更改内容描述 Modify Content 备注 Remark Complete specifications. Add product application, reliability and other information. E-mail:info@shoulder.cn Page 2 of 9 SAW FILTER HDF1588E-B2 1. Application ● Low-loss RF GPS + COMPASS + GLONASS filter ● Usable passband: 2.0 MHz for GPS, 4.092 MHz for COMPASS and 8.34 MHz for GLONASS ● Impedance 50 ohm input and output ● Unbalanced to unbalanced operation ● RoHS compatible 2. Package Dimension (PKG SIZE 1.4 x 1.1mm) 3. Maximum Rating Items Operation temperature rang Storage temperature rang ESD voltage Sensitive discharge device DC Voltage VDC Max Input Power Moisture Sensitivity Level Conditions -30℃ ~ +85℃ -40℃ ~ +85℃ ESD(MM) : 50VDC ESD(HBM) : 175VDC 5V 15dBm 2000h MSL 2 4. Test Circuit www.shoulder.cn Tel:0755-82916880 Fax:0755-82916881 E-mail:info@shoulder.cn Page 3 of 9 SAW FILTER HDF1588E-B2 5. ELECTRICAL SPECIFICATION Center Frequency Unit Minimum Typical Maximum MHz - 1582.4 - 1.3 1.8 1.5 1.8 1.5 2.0 2.0 2.0 1.2 1.6 1.4 1.6 2.0 2.0 2.0 2.0 4 12 Insertion Loss 1574.42~1576.42 MHz 1559.05~1563.15 MHz 1573.37~1577.47 MHz 1597.78~1605.66 MHz dB VSWR 1574.42~1576.42 MHz 1559.05~1563.15 MHz 1573.37~1577.47 MHz 1597.78~1605.66 MHz Group delay ripple 1597.78~1605.66 MHz Attenuation 10~824 MHz 824~925 MHz 1427~1453 MHz 1710~1785 MHz 1850~1910 MHz 1920~1980 MHz 2400~2500 MHz 2500~2570 MHz 2600~3000 MHz 4900~5850 MHz Input/Output Impedance www.shoulder.cn Tel:0755-82916880 Fax:0755-82916881 dB ns dB 47 47 40 40 40 39 43 37 30 15 Ohms E-mail:info@shoulder.cn 51 51 45 45 44 44 45 42 38 24 50 - Page 4 of 9 SAW FILTER HDF1588E-B2 6. Frequency Characteristics 7. ENVIRONMENTAL CHARACTERISTICS 7.1 High temperature exposure Subject the device to +85℃ for 16 hours. Then release the filter into the room conditions for 24 hours prior to the measurement. It shall fulfill the specifications in 5. 7.2 Low temperature exposure Subject the device to -40℃ for 16 hours. Then release the device into the room conditions for 24 hours prior to the measurement. It shall fulfill the specifications in 5. 7.3 Temperature cycling Subject the device to a low temperature of -40℃ for 30 minutes. Following by a high temperature of +85℃ for 30 Minutes. Then release the device into the room conditions for 24 hours prior to the measurement. It shall meet the specifications in 5. 7.4 Resistance to solder heat 1、immerge the solder bath at 260℃ for 10 sec. 2、the iron at 370℃ for 3 sec 7.5 Solderability Submerge the device terminals into the solder bath at 245℃ ±5℃ for 5s, More than 95% area of the soldering pad must be covered with new solder. It shall meet the specifications in 5. 7.6 Reflow soldering www.shoulder.cn Tel:0755-82916880 Fax:0755-82916881 E-mail:info@shoulder.cn Page 5 of 9 SAW FILTER HDF1588E-B2 The specimen shall be passed through the reflow furnace with the condition shown in the above profile for 1 time. The specimen shall be stored at standard atmospheric conditions for 1h, after which the measurement shall be made. Test board shall be 1.6 mm thick. Base material shall be glass fabric base epoxy resin. 7.7 Mechanical shock Drop the device randomly onto the concrete floor from the height of 1m 3 times. the device shall fulfill the specifications in 5. 7.8 Vibration Subject the device to the vibration for 1 hour each in x,y and z axes with the amplitude of 1.5 mm at 10 to 55 Hz. The device shall fulfill the specifications in 5. 8. REMARK 8.1 Static voltage Static voltage between signal load & ground may cause deterioration &destruction of the component. Please avoid static voltage. 8.2 Ultrasonic cleaning Ultrasonic vibration may cause deterioration & destruction of the component. Please avoid ultrasonic cleaning 8.3 Soldering Only pad component may be solded. Please avoid soldering another part of component. 9. Packing 9.1 Dimensions (1) Carrier Tape: Figure 1 (2) Reel: Figure 2 (3) The product shall be packed properly not to be damaged during transportation and storage. 9.2 Reeling Quantity 3000 pcs/reel φ 178mm 10000 pcs/reel φ 259mm 9.3 Taping Structure (1) The tape shall be wound around the reel in the direction shown below. www.shoulder.cn Tel:0755-82916880 Fax:0755-82916881 E-mail:info@shoulder.cn Page 6 of 9 SAW FILTER HDF1588E-B2 (2) Label Device Name Marking User Product Name Quantity Lot No. (3) Leader part and vacant position specifications. 10. TAPE SPECIFICATIONS 10.1 Tensile Strength of Carrier Tape: 4.4N/mm width 10.2 Top Cover Tape Adhesion (See the below figure) (1) pull off angle: 0~15º (2) speed: 300mm/min. (3) force: 20~70g www.shoulder.cn Tel:0755-82916880 Fax:0755-82916881 E-mail:info@shoulder.cn Page 7 of 9 SAW FILTER HDF1588E-B2 [Figure 1] Carrier Tape Dimensions [Figure 2] 3000 pcs/reel φ 178mm 10000 pcs/reel φ 257.5mm www.shoulder.cn Tel:0755-82916880 Fax:0755-82916881 E-mail:info@shoulder.cn Page 8 of 9 SAW FILTER www.shoulder.cn Tel:0755-82916880 HDF1588E-B2 Fax:0755-82916881 E-mail:info@shoulder.cn Page 9 of 9
HDF1588E-B2 价格&库存
很抱歉,暂时无法提供与“HDF1588E-B2”相匹配的价格&库存,您可以联系我们找货
