HDDB01NSB-B11
HDDB01NSB-B11
    HD(高清数字)
    SMD,1.4x1.8mm
    低损耗声表面波双工器
HDDB01NSB-B11 数据手册
规格书编号 SPEC NO : HDDB01NSBB11SP01 产品 规 格书 SPECIFICATION CUSTOMER 客 户: PRODUCT 产 品: SAW DUPLEXER MODEL NO 型 号: HDDB01NSB –B11 MARKING 印 字: B080 PREPARED 编 制: CHECKED 审 核: APPROVED 批 准: DAT E 日 期: 2016-3-31 客户确认 CUSTOMER RECEIVED: 审核 CHECKED 批准 APPROVED 日期 DATE 无锡市好达电子有限公司 Shoulder Electronics Limited Factory Address: NO. 115, Gaoyun Road, Binhu Economic & Technology Development Area, Wuxi, Jiangsu, China. Tel:86-510-85629111 Country of origin: China www.shoulder.cn Tel:0755-82916880 Fax:0755-82916881 E-mail:info@shoulder.cn Page 1 of 9 SAW DUPLEXER HDDB01NSB-B11 更改历史记录 History Record 更改日期 Date 2015-7-28 规格书编号 Spec. No. SP00 产品型号 Part No. 客户产品型号 Customer No. HDDB01NSB -B11 The new specification HDDB01NSB -B11 Complete specifications. Add product application, reliability and other information. 2016-3-31 SP01 www.shoulder.cn 更改内容描述 Modify Content Tel:0755-82916880 Fax:0755-82916881 E-mail:info@shoulder.cn 备注 Remark Page 2 of 9 SAW DUPLEXER HDDB01NSB-B11 1. Application ● Low-loss Saw duplexer for mobile telephone LTE and WCDMA Band1 systems. ● Low insertion attenuation and low passband ripple. ● Usable passband 60MHz ● High isolation between Tx and Rx. ● RoHS compatible 2. DIMENSION (PKG SIZE 1.8 x 1.4 x 0.6mm) 3. Maximum Rating Items Operation temperature rang Storage temperature rang ESD voltage Sensitive discharge device DC Voltage VDC Moisture Sensitivity Level Conditions -30℃ ~ +85℃ -40℃ ~ +85℃ ESD(MM) : 50VDC ESD(HBM) : 175VDC 3V (25+/-2 deg.C) MSL 2 4.TEST CIRCUIT www.shoulder.cn Tel:0755-82916880 Fax:0755-82916881 E-mail:info@shoulder.cn Page 3 of 9 SAW DUPLEXER HDDB01NSB-B11 5. ELECTRICAL SPECIFICATION Table1. Electrical Specification Item Condition (MHz) 1920~1980 1920~1980 TX Insertion loss to Pass band ripple ANT VSWR ANT 1920~1980 Tx Input Power 1920~1980 Absolute attenuation 420~494 843~894 1566~1574 1574~1605 1605~1865 1865~1880 2010~2025 2110~2170 2400~2500 2620~2690 3840~3960 5150~5940 2110~2170 ANT Insertion loss to Pass band ripple 2110~2170 RX VSWR ANT 2110~2170 Rx Absolute attenuation 1920~1980 1980~2025 2250~2400 2400~2484 2484~6000 Table2. Electrical Specification Item Condition (MHz) TX to Isolation 1920~1980 RX 2110~2170 Terminating Tx port Impedance Rx port Ant port Operating Temperature www.shoulder.cn Tel:0755-82916880 Fax:0755-82916881 Specification Min Typ Max 2.0 2.5 0.5 1.0 - 1.6 1.6 2.0 2.0 +29dBm Ta=+50℃ 5000h,CW 44 40 38 40 25 10 18 42 33 30 26 18 45 27 15 30 35 Unit dB dB - 53 43 42 43 36 37 25 47 36 33 33 22 2.0 2.5 dB dB dB dB dB dB dB dB dB dB dB dB dB 0.3 1.0 dB 1.6 1.6 58 37 44 45 45 2.0 2.0 - dB dB dB dB dB Specification Unit Min Typ Max 55 57 dB 50 57 dB 50Ω 100Ω (balanced)//22nH 50Ω //3.0nH -30 to +85℃ E-mail:info@shoulder.cn Page 4 of 9 SAW DUPLEXER HDDB01NSB-B11 6. Typical frequency response Tx to Ant Ant to Rx Tx to Rx Isolation www.shoulder.cn Tel:0755-82916880 Fax:0755-82916881 E-mail:info@shoulder.cn Page 5 of 9 SAW DUPLEXER HDDB01NSB-B11 7. ENVIRONMENTAL CHARACTERISTICS 7.1 High temperature exposure Subject the device to +85℃ for 16 hours. Then release the filter into the room conditions for 24 hours prior to the measurement. It shall fulfill the specifications in 5. 7.2 Low temperature exposure Subject the device to -40℃ for 16 hours. Then release the device into the room conditions for 24 hours prior to the measurement. It shall fulfill the specifications in 5. 7.3 Temperature cycling Subject the device to a low temperature of -40℃ for 30 minutes. Following by a high temperature of +85℃ for 30 Minutes. Then release the device into the room conditions for 24 hours prior to the measurement. It shall meet the specifications in 5. 7.4 Resistance to solder heat 1、immerge the solder bath at 260℃ for 10 sec. 2、the iron at 370℃ for 3 sec 7.5 Solderability Submerge the device terminals into the solder bath at 245℃ ±5℃ for 5s, More than 95% area of the soldering pad must be covered with new solder. It shall meet the specifications in 5. 7.6 Reflow soldering The specimen shall be passed through the reflow furnace with the condition shown in the above profile for 1 time. The specimen shall be stored at standard atmospheric conditions for 1h, after which the measurement shall be made. Test board shall be 1.6 mm thick. Base material shall be glass fabric base epoxy resin. 7.7 Mechanical shock Drop the device randomly onto the concrete floor from the height of 1m 3 times. the device shall fulfill the specifications in 5. 7.8 Vibration Subject the device to the vibration for 1 hour each in x,y and z axes with the amplitude of 1.5 mm at 10 to 55 Hz. The device shall fulfill the specifications in 5. www.shoulder.cn Tel:0755-82916880 Fax:0755-82916881 E-mail:info@shoulder.cn Page 6 of 9 SAW DUPLEXER HDDB01NSB-B11 8. REMARK 8.1 Static voltage Static voltage between signal load & ground may cause deterioration &destruction of the component. Please avoid static voltage. 8.2 Ultrasonic cleaning Ultrasonic vibration may cause deterioration & destruction of the component. Please avoid ultrasonic cleaning 8.3 Soldering Only pad component may be solded. Please avoid soldering another part of component. 9. Packing 9.1 Dimensions (1) Carrier Tape: Figure 1 (2) Reel: Figure 2 (3) The product shall be packed properly not to be damaged during transportation and storage. 9.2 Reeling Quantity 10000 pcs/reel φ 257.5mm 9.3 Taping Structure (1) The tape shall be wound around the reel in the direction shown below. (2) Label Device Name Marking User Product Name Quantity Lot No. (3) Leader part and vacant position specifications. www.shoulder.cn Tel:0755-82916880 Fax:0755-82916881 E-mail:info@shoulder.cn Page 7 of 9 SAW DUPLEXER HDDB01NSB-B11 10. TAPE SPECIFICATIONS 10.1 Tensile Strength of Carrier Tape: 4.4N/mm width 10.2 Top Cover Tape Adhesion (See the below figure) (1) pull off angle: 0~15º (2) speed: 300mm/min. (3) force: 20~70g [Figure 1] Carrier Tape Dimensions www.shoulder.cn Tel:0755-82916880 Fax:0755-82916881 E-mail:info@shoulder.cn Page 8 of 9 SAW DUPLEXER HDDB01NSB-B11 [Figure 2] 10000 pcs/reel www.shoulder.cn Tel:0755-82916880 φ 257.5mm Fax:0755-82916881 E-mail:info@shoulder.cn Page 9 of 9
HDDB01NSB-B11 价格&库存
很抱歉,暂时无法提供与“HDDB01NSB-B11”相匹配的价格&库存,您可以联系我们找货
