B6840400-D-15-5U
B6840400-D-15-5U
    GDHY(华裕)
    插件,P=15mm
    680NF 400V
B6840400-D-15-5U 数据手册
GDHY 金属化薄膜电容器 R CBB22 Metallized Polypropylene Film capacitors 金属化聚丙烯膜电容器  产品特点.Characteristics ● ● ● ● 金属化聚丙烯膜材质; 无感卷绕结构; 阻燃环氧树脂粉末包封; 耐压高,损耗(tgδ)小; 内部温升低 ● ● ● ● 产品应用.Application ● ● 广泛应用于高频、直流、交流和脉冲电路中; 显示器的S校正电路中; 性能参数.Technical Data ● ● ● ● ● ● ● ● ● ● ● ● Metallized polypropylene film dielectric Non-inductive winding structure Flame retardant epoxy resin powder encapsulation Resistance to high voltage, small tgδ, low temperature rise Widely used in High Frequency, DC, AC, Pulse Circuits S-correction circuits of the display device 引用标准 Reference Standards GB/T 10190(IEC 60384-16) 工作温度范围Operating Temperature Range -40℃~85℃ 气候类别 Climate Category 额定电压Rated Voltage 电容量范围Capacitance Range 电容量偏差Capacity Tolerance 耐电压Withstand Voltage 损耗角正切Dissipation Factor 绝缘电阻Insulation Resistance 最大脉冲爬升速度Maximum Pulse Rise Time (dV/dt) 40/085/21 100VDC、250VDC、400VDC、630VDC 0.01μF~20 μF ±5%(J);±10%(K);±20%(M) Vt-t:1.6UN 5S(at20±5℃) tgδ≤0.0010 (20℃, 1KHz) C≤0.33μF R≥100000MΩ(at20℃ 100VDC 1Min) C>0.33 μF RCN≥30000S (at20℃ 100VDC 1Min) UN(V) dV/dt(V/µS) P=7.5 P=10 P=15 P=20 250VDC 240 220 200 120 630VDC --- 320 400 240 100VDC 400VDC 120 --- 110 330 100 300 70 180 结构图.Construction Diagram 金属化聚丙烯薄膜 Metallized polypropylene film 喷金层 End metal spray Url: www.gdhy.com Eml: hy@gdhy.com Copyright @ Guangdong Huayu Electronic 1 GDHY 金属化薄膜电容器 R Metallized Polypropylene Film capacitors CBB22 产品外形.Product Shape 频率特性.Temperature Characteristics DF (%) △C/C(%) 3.0 2 2.5 2.0 0 PP 1.5 1.0 -2 0.5 -4 0.1 1 100 KHz 10 PP 0 0.1 100 KHz 10 1 温度特性.Frequency Characteristics △C/C(%) DF (%) 6 1.6 4 1.4 1.2 2 1.0 0 0.8 -2 PP -4 0.6 0.4 0.2 -6 -40 -20 0 20 40 60 80 100 120℃ 0 -40 -20 PP 0 20 40 60 80 100 120℃ RC (s) RV 10 6 100% 10 5 90% 80% 10 4 70% 10 3 60% PP 50% 0 Url: www.gdhy.com +20 +40 +60 Eml: hy@gdhy.com Copyright @ Guangdong Huayu Electronic +80 +100 10 2 -40 -20 PP 0 20 40 60 80 100 120 140℃ 2 GDHY 金属化薄膜电容器 R Metallized Polypropylene Film capacitors CBB22 参数表.Article Table R 系列 Capacity 尺寸标注 250V (μF) Size mark Wmax Hmax Tmax 400V 0.0100 R 13.0 4.5 0.0150 R 13.0 5.5 9.5 10.0 0.6 13.0 5.5 9.5 10.0 0.6 0.0220 R 13.0 6.5 10.5 10.0 0.6 13.0 6.5 10.5 10.0 0.6 0.0330 R 0.0470 R 10.0 4.5 8.5 0.0680 R 10.0 5.0 9.0 7.5 0.5 13.0 5.0 9.0 0.0820 R 13.0 5.0 9.0 10.0 0.6 13.0 5.5 9.5 0.1000 R 13.0 5.5 9.5 10.0 0.6 13.0 6.0 10.0 10.0 0.1500 R 13.0 6.0 10.0 10.0 0.6 13.0 7.5 11.5 10.0 0.2200 R 13.0 7.5 11.5 10.0 0.6 18.0 6.5 11.5 0.3300 R 18.0 5.5 9.5 15.0 0.6 18.0 8.0 0.4700 R 18.0 6.5 11.5 15.0 0.8 18.0 0.6800 R 18.0 7.5 12.0 15.0 0.8 0.8200 R 18.0 8.5 13.0 15.0 1.0000 R 23.0 7.5 12.5 1.2000 R 23.0 8.0 1.5000 R 23.0 2.2000 R 23.0 3.3000 R 30.5 4.7000 R 10.0000 R P d Wmax Hmax Tmax 8.5 630V P d 10.0 0.6 Wmax Hmax Tmax 13.0 5.0 9.0 P d 10.0 0.6 13.0 5.0 9.0 10.0 0.6 13.0 5.0 10.0 10.0 0.6 13.0 4.5 8.5 10.0 0.6 13.0 6.0 10.0 10.0 0.6 10.0 0.6 13.0 7.0 11.0 10.0 0.6 10.0 0.6 0.6 13.0 8.0 12.5 10.0 0.8 0.6 18.0 6.0 12.5 15.0 0.6 15.0 0.8 18.0 8.0 13.0 15.0 0.8 13.0 15.0 0.8 18.0 9.5 14.0 15.0 0.8 8.5 12.5 15.0 0.8 23.0 9.0 15.5 20.0 0.8 23.0 8.0 13.0 20.0 0.8 23.0 11.0 17.0 20.0 0.8 0.8 23.0 8.5 15.0 20.0 0.8 23.0 12.0 18.5 20.0 0.8 20.0 0.8 23.0 9.0 15.5 20.0 0.8 23.0 13.0 19.5 20.0 0.8 14.0 20.0 0.8 23.0 10.0 16.5 20.0 0.8 30.5 12.0 18.0 27.0 0.8 9.5 14.0 20.0 0.8 23.0 11.5 18.0 20.0 0.8 30.5 13.5 19.5 27.0 0.8 11.0 17.0 20.0 0.8 30.5 11.5 17.5 27.0 0.8 30.5 16.5 22.5 27.0 0.8 11.0 17.5 27.0 0.8 30.5 14.0 20.5 27.0 0.8 34.5 19.0 25.5 31.0 0.8 30.5 13.5 20.0 27.0 0.8 30.5 17.5 24.0 27.0 0.8 34.5 23.0 29.0 31.0 0.8 30.5 20.0 26.0 27.0 0.8 P d P d 7.5 0.5 U 系列 Capacity 尺寸标注 250V (μF) Size mark Wmax Hmax Tmax 400V 0.0470 U 0.1000 U 13.0 4.5 9.0 10.0 0.1500 U 13.0 6.5 10.5 10.0 0.2200 U 13.0 7.5 11.5 0.3300 U 18.0 7.0 0.4700 U 18.0 0.6800 U 0.8200 630V P d 11.5 4.0 8.0 10.0 0.6 0.6 13.0 6.0 10.0 10.0 0.6 0.6 13.0 7.5 12.0 10.0 0.6 10.0 0.6 18.0 6.5 11.5 15.0 0.8 11.0 15.0 0.8 18.0 8.0 13.0 15.0 0.8 6.5 11.0 15.0 0.6 18.0 9.0 15.5 15.0 0.8 18.0 7.5 12.5 15.0 0.6 23.0 9.0 15.5 20.0 0.8 U 23.0 7.5 12.0 20.0 0.6 23.0 10.0 16.5 20.0 0.8 1.0000 U 23.0 7.5 12.5 20.0 0.8 30.5 10.0 16.0 27.0 0.8 1.2000 U 23.0 8.5 13.5 20.0 0.8 30.5 10.0 16.5 27.0 0.8 1.5000 U 23.0 8.5 15.0 20.0 0.8 30.5 12.0 17.0 27.0 0.8 2.2000 U 30.5 9.0 15.5 27.0 0.8 30.5 14.0 20.5 27.0 0.8 3.3000 U 30.5 12.5 19.0 27.0 0.8 34.5 16.0 22.5 31.0 0.8 4.7000 U 34.5 19.5 26.0 31.0 0.8 10.0000 U 以上表格/图形仅供参考,以实物为准. Wmax Hmax Tmax Wmax Hmax Tmax The above table / graphics are for reference only, subject to the actual product (unit: mm) 特别说明: R:出厂测试电压为耐电压的2倍,体积较U产品略大 U:出厂测试电压为耐电压的1.6倍,体积较R产品略小 (产品体积详细参考以上表格内容) Remark: The R: factory test voltage is 2 times the withstand voltage, and the volume is slightly larger than that of the U product. The U: factory test voltage is 1.6 times the withstand voltage, and the volume is slightly smaller than that of the R product. (volume of products refer to the above table). Url: www.gdhy.com Eml: hy@gdhy.com Copyright @ Guangdong Huayu Electronic 3
B6840400-D-15-5U 价格&库存
很抱歉,暂时无法提供与“B6840400-D-15-5U”相匹配的价格&库存,您可以联系我们找货
