Ⱨᅛ(佭␃)᳝䰤݀ৌ
֮ٙᒳᇆ
HY-WI-32
HAOYU (HONG KONG) LIMITED
࿇۩ֲཚ
2008-07-23
SPECIFICATION
ࢭᎁ
ร B-2 ठ
ร1
٥3
SERIES ขߓ٨
XLR ߓ٨Ꮮ༺ஆ
TYPE ขীᇆ
ᛩঅ
DRAWN
LIU FAZHAN
APVD ᐉ
ZHOU ZHIQUAN
ૠ
ޅ
1A. ᠰࡳ๛
RATED LOAD
SURFACE:
AS
DC 50V 1A
SHOWN
IN
THE
APPLICABLE DRAWING
2ΗOPERATING TEMPERATURE RANGE
ᖙ܂ᄵ৫ᒤ
ITEM
ႈؾ
CONSTRUCTION DIMENSION
Apply to the appended drawing.
ዌ֡՚
ฤףॵٽቹ
-20к~70к
PRESERVATIVE TEMPERATURE RANGE
20к~70к
ᚏژᄵ৫ᒤ
TEST CONDITIONS ྒྷᇢයٙ
SPECIFICATIONS
3ΗELECTRICAL PERFORMANCEΰሽࢤ౨α
Κ
TO BE MEASURED AT 1kHz AND 100m A MAX. WHEN THE
CONTACT
3A
RESISTANCE
൷ᤛሽॴ
MEASUREMENT SHALL BE MADE BY A MATING PLUG,
70mӨ
OXIDATION
70 ශᑛאՀ
FILM
ON
THE
SURFACE
MUST BE
WIPED.
max
RESISTANCE OF A PLUG CODE SHALL NOT BE INCLUDED AS A
MEASUREMENT VALUE.
ࠌ༺شᙰ༺Ե ܛ1kHz 100mA אՀऱპሽੌၞ۩ྒྷࡳ
TO BE MEASURED BETWEEN ADJACENT TERMINALS AT 500V
INSULATION
3B
RESISTANCE
DC
100MӨ
ᖄ᧯հၴ ڇDC500V ऱणኪՀ
ᒴॴݼ
DIELECTRIC
3C
STRENGTH
રሽᚘ
A VOLTAGE OF AC 1500VSHALL BE APPLIED BETWEEN
ADJACENT TERMINALS FOR 1 MIN. AT 50~60Hz
ڇᖄ᧯ઌյհၴ؆ ףAC1500V 50~60Hz 1 ։ᤪ
min
100 ٢ᑛאՂ.
WITHOUT DAMAGE
TO PARTS ARCING
OR BREAKDOWN ETC
ڶჾ႞ ᧢ݮᒴధᡏฆൄ.
4.MECHANICAL PERFORMANCE(ᖲඳࢤ౨)
4A
INSERTION
AND
WITHDRAW
FORCE ༺ࢸԺ
THE FORCE WHEN A JACK SHALL BE INSERTED AND
EXTRACTED SLOWLY AFTER FIXING A MATING PLUG AS
SHOWN IN SECTION 1B TO THE PUSH-PULL SCALE.
ࠌشᑑᄷ༺ᙰၞ۩ྒྷࡳ
Insertion and extraction force
4~40N
༺ࢸԺ
4~40N ׄቅ
WITHOUT
4B
TERMINAL
THE FORCE OF 4.9N SHALL BE APPLIED TO THE TERMINAL FOR
STRENGTH
10 SEC(3 DIRECTION)
ጤൎ৫
LOOSING
BREAKDOWN.
AND
TERMINAL
BEND SHALL BE ACCEPTEDΖ
ش4.9N ऱԺڇጤऱԿଡֱٻՂೖఎ 10 ઞ
լᚨנๅᆵΔధჾᦛאױ܀
ڴ
UNLESS OTHERWISE SPECIFIED. THE STANDRD RANGE
STANDARD
4C
ATMOSPHEIC
CONDITIONS
ࠌشᑑᄷणኪ
OF ATMOSPHERIC CONDITIONS FOR MAKING MEASUREMENTS
ڶڇਐࡳऱൣउՀྒྷᇢᄵ৫ᛘ
AND TESTS ARE AS FOLLOWS:
৫ΕᚘڕՀΚ
AMDIENT TEMPERATURE: 15к TO 35к
˄1˅
ᄵ৫ 15к~35к
RELATIVE HUMIDITY
˄2˅
ᛘ৫ 25%~75%RH
˄3˅
ᚘ 80Kpa ~106Kpa
AIR PRESSURE
:25%TO75%RH
:80Kpa TO 106Kpa
Ⱨᅛ(佭␃)᳝䰤݀ৌ
֮ٙᒳᇆ
HY-WI-32
࿇۩ֲཚ
2008-07-23
SPECIFICATION
ࢭᎁ
ร B-2 ठ
ร2
٥3
5ΗDURABILITY ΰરՆࢤα
RESISTANCE
TO
5A
SOLDERING
HEATʳ TEST
ર෬ࢤᇢ᧭
5B
LIFE TEST.
ኂࡎᇢ᧭
WITHOUT DEFORMATION OF CASE
THE TOP OF THE TERMINALS SHALL BEDIPPED 2mm .
THE PLASTIC BODY IS 1.6mm ABOVE THE TIN LIGUID.
ጤືຝ௦Ե෬ᙔۃխ 2mm , ᓄߪ၏ᠦᙔ 1.6mmΖ
Wave-soldering is to be performed within 3seconds at 260 +/-5
к ं෬൷ᄵ৫ 260 +/-5к ழၴ 3 ઞΖ
Hand weilding to be performed within 3 seconds at 380к or
below. ֫ՠ෬൷ᄵ৫ 380кࢨאփΔழၴ 3̈́0.5 ઞΖ
ࣹΚءขᔞ֫شٽ෬Εं෬Ζ
OREXCESSIVE
LOOSENESS
OF
TERMINALSELECTRICAL
CHARACTERISTICS SHALL
BE SATISFIED.
ݮ᧢ྤ᧯ءΔ ౨የߩ࣍ᖲඳΕሽࢤ
౨Ζ
WITHOUT LOAD INSERTIONS AND EXTRACTIONS OF
5000 CYCLES SHALL BE MADE AT RATE OF 10 TO 20
CYCLES PER MINUTE
ڇ๛णኪՀ 10~20/։ᤪΔࠐ༺ڃԵ֗ࢸ ۟נ5000 ڻ
˄1˅ CONTACT
RESISTANCE
SHALLBE 200mӨmax
˄2˅ MECHANICAL
AND
ELECTRICAL
BESATISFIEDΖ
˄1˅ ൷ᤛሽॴլ౨၌࣍ 200mӨ
˄2˅ ࠡהየߩ࣍ᖲඳሽᕴࢤ౨Ζ
85̈́2к FOR 96 HOURS AFTER TEST KEEP IN NORMAL
5C
HEAT TEST.
રᑷᇢ᧭
CONDITION FOR 1 HOUR.
ڇ85̈́2кᛩቼխ࣋ 96 ՛ழ,٦࣋إڇൄᛩቼխ 1 ՛ழ৵ၞ۩
ྒྷᇢΖ
40 ̈́ 2 к
5D
HUMIDITY TEST.
રᛘᇢ᧭
90~96%RH FOR 96 HOURS, TEST AFTER
THERE SHALL BE NO DAMAGE ON
KEEPING IN NORMAL CONDITION FOR 1 HOUR.
APPEARANCEΖ
ڇ40̈́2к 90~96иRH ᛩቼխ࣋ 96 ՛ழΔ٦࣋إڇൄᛩቼ
MECHANICAL AND ELECTRICAL
խΔ1 ՛ழ৵ၞ۩ྒྷᇢΖ
CHARACTERISTICS
SHALL
BE
SATISFIED
At –40̈́2к for 96 HRS. AFTER TEST KEEP IN NORMAL
؆ᨠྤฆൄΔየߩ࣍ᖲඳΔሽᕴࢤ౨Ζ
5E
COLD TEST.
રܐᇢ᧭
SALT SPRAY TEST
5F
Ᏼᣆᇢ᧭
ڇ-40̈́2кᛩቼխ࣋ 96 ՛ழ,٦ᆜ࣍إൄᛩቼխ 1 ՛ழ৵ၞ۩
ྒྷᇢΖ
5% SALT SOLUTION CONCENTRATION BY WEIGHT AT
35̈́1к FOR 24 HOURS(SPRAY 8 HOURS,REST 16 HOURS
BY WATER) MEASUREMENT SHALL BE MADE, AFTER
WASHING
PRODUCT
WITHOUT
USING
SOAP,
REMOVING WATER DROP, AND REMAINING AT ROOM
CONDITION FOR 30 MINUTES.
ᖺ৫ 5%ऱᨖֽΔᆖ 8 ՛ழᏴᣆΕ16 ՛ழֽੑۘஐᦫ৵Δ࣋
ԵൄᄵՀ 30 ։ᤪၞ۩ྒྷᇢΰᇢ᧭ᄵ৫Κ35̈́1кα
6ΗࣹრࠃႈΰAPPLICATION NOTES:α
WITHOUT EXCESSIVE CORROSION
OR CRACK IN APPEARANCE
।૿ྤࣔ᧩ፍ፱ࢨᝳᐋๅᆵွ
Ⱨᅛ(佭␃)᳝䰤݀ৌ
֮ٙᒳᇆ
HY-WI-32
࿇۩ֲཚ
2008-07-23
SPECIFICATION
ࢭᎁ
ร B-2 ठ
ร3
٥3
Εڇર෬൷መ࿓խ,լ࣪ނଉᒴΕڶፍ፱ࢤढᔆ௦ԵขփΖ
ΰROSIN AND OTHER INSULATING AND CAUSTIC MATERIAL CAN NOT BE DIPPED INTO THE ROCKET DURING
SOLDERING.α
2Εข෬൷৵լ౨شዓشࢨܬᄫᕪޱੑΖ
ΰPRODUCTS CAN NOT BE BLOWN WITH AIR GUN OR CLEANED WITH A SOLVENT AFTER SOLDERING.)
3Εข෬൷ছٺሿٙլ౨ᄫ֏Ζ
ΰALL PARTS OF THE PRODUCTS CAN NOT BE DISSOLVED BEFORE SOLDERING.α
4Εᝩ܍ᚏ៲࣍ᄵΕᑪᛘ֗ፍ፱ऱࢬΖ
ΰAVOID STORING THE PRODUCTS IN A PLACE AT HIGH TEMPERATURE, HIGH HUMIDITY AND
IN CORROSIVE GASES.)
5Εဿژཚૻ:۞࿇ຄհֲದ,ဿژཚլ၌መ 180 ֚.ૉ၌נဿژཚૻ,ขسլߜ,ءֆᄗլຂΖ
ΰSHELF LIFE IS LESS THAN 180 DAYS SINCE THE GOODS WARE SENT OUT FROM OUR FACTORY. OUR COMPANY
DOESN’T ACCEPT RESPONSIBILITY FOR REJECTS IF THE SHELF LIFE OF GOODS EXCEEDS 180 DAYS.α
6ΕءขڶڕլߜࠃٙΔඨᐗ୮֗ழڃ墅Δ֗ঁאழಖᙕΕுΕޏΕᇿ᠋Ζ
ΰPLEASE FEEL FREE TO REPORT TO US IF YOU DISCOVER THE INFERIOR GOODS, SO THAT WE CAN TAKE NOTE,
CHECK, TRACK AND IMPROVE THEM. THANKS.α
Ⱨᅛ(佭␃)᳝䰤݀ৌ
很抱歉,暂时无法提供与“DIN-323PP”相匹配的价格&库存,您可以联系我们找货
