ESDPSA0402V05
ESDPSA0402V05
    SEMITEL(晶讯)
    DFN1006-2
    双向ESD 5V截止
ESDPSA0402V05 数据手册
ESD Protection Devices Description ■ This device is an ultra low capacitance ESD product ESDPSA0402V05 designed to protect very high speed data interfaces. ESDPSA0402V05 has a typical capacitance of only 0.05pf (I/O to GND), and it can be used to meet the ESD immunity requirements of IEC61000-4-2 (15KV air, 8KV contact discharge). Feature ■ ESD protection for high speed data lines to ■ ESD contact discharge typical 8KV, max 15KV ■ ESD air discharge typical 15KV, max 25KV ■ Surface mount Schematic Diagram ■ Extremely low capacitance ■ Very low leakage current ■ Fast response time ■ Bi-directional ESD protection ■ Lead free solder termination ■ The best ESD protection for high frequency, low voltage applications Application ESD Protection Devices IEC61000-4-2 ■ High Definition Multi-Media Interface (HDMI) ■ Digital Visual Interface (DVI) ■ Display Port Interface (DP) ■ Unified Display Interface (UDI) ■ Mobile Display Digital Interface (MDDI) ■ Gigabit Ethernet ■ USB2.0 and USB3.0 ■ IEEE1394 interface Caution: This component is designed for signal line protection only, Not intended to be used under bias, not for application with a power line. Doc.No.SSME/JS-100-0041 @copyright Semitel 2011 1 www.semiteltech.com ESDPSA0402V05 Absolute Maximum Ratings Parameter Symbol Value Unit Maximum Contact discharge voltage Per IEC61000-4-2 --- 15KV V Maximum Air discharge voltage Per IEC61000-4-2 --- 25KV V Maximum Operating temperature TOPER -40 to +90 ℃ Maximum Storage temperature TSTG -55 to +125 ℃ Maximum lead temperature for soldering during 10s TL 260 ℃ Electrical Characteristics(TA=25℃) Symbol Test Conditions Rated Voltage VR --- --- --- 5 V Trigger voltage VT IEC61000-4-2 8KV contact discharge --- 350 --- V Clamping voltage VC IEC61000-4-2 8KV contact discharge --- 35 --- V Leakage current IL DC 5V shall be applied on component --- 0.10 uA Capacitance CP VR = 0V, f = 1MHz --- Note: Min Typ Max Units 0.05 pF 1 Trigger and clamping voltage are measured per IEC 61000-4-2, 8KV contact discharge method. 2 After reliability tests such as high temp storage, temp cycles, continuous ESD strike etc, the maximum leakage current is less than 10uA. ESD Clamping Test ESD Protection Devices Parameter ESD TESTER RZ 450 Ω RG 223/U 50 Ω coax 4 GHz DIGITAL 10× OSCILLOSCOPE ATTENUATOR 50 Ω CZ DUT (DEVICE UNDER TEST) IEC 61000-4-2 network CZ = 150 pF; RZ = 330 Ω 2 Doc.No.SSME/JS-100-0041 @copyright Semitel 2011 www.semiteltech.com ESDPSA0402V05 ESD Clamping Test Waveforms ESD Wave after Clamping IPP 400 100% 90% 10% t ‐50 30 ns 50 150 250 60 ns Product Dimension Dim min  max  A  0.90  1.20  B  0.45  0.65  C  0.30  0.40  D  0.00  0.05  E F G  H  PAD Dimension millmeters   ESD Protection Devices 0 tr = 0.7 ns to 1ns 0.125REF  0.40  0.50  0.65BSC  0.25  0.35  0.9mm 0.65mm 0.5mm Solder thickness 0.15 to 0.2mm 3 Doc.No.SSME/JS-100-0041 @copyright Semitel 2011 www.semiteltech.com ESDPSA0402V05 Solder Reflow Recommendations Temperatures (°C) 300 250 200 150 100 0 0 50 100 150 200 250 Time(seconds) Package Information Dimension Typical A0 0.75 B0 1.22 D 1.55 P0 4.00 P1 2.00 P2 2.00 E 1.75 F 3.50 W 8.00 Unit ESD Protection Devices 50 mm P1 4 Doc.No.SSME/JS-100-0041 @copyright Semitel 2011 www.semiteltech.com ESDPSC0402V05 Part Number System ESDP SA 0402 V05 Rated Voltage Size Standard Type Product Series Order Information Device Net Weight Carrier Quantity HSF Status 0402 0.44 mg Tape & Reel 10,000pcs/reel RoHS compliant Revision history Date 1-Apr-2013 Revision 3.0 Description of changes Change Dimensions ESD Protection Devices ESDPSA0402V05 Package CAUTION / WARNING · Information in this document is believed to be accurate and reliable. However, SEMITEL does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. · Users should independently evaluate the suitability of and test each product selected for their own applications, and SEMITEL assumes no liability whatsoever relating to the choice, selection or use of the SEMITEL products and services described herein. · SEMITEL reserves the right to change or update, without notice, any information contained in this publication; to change, without notice, the design, construction, processing, or specification of any product; and to discontinue or limit production or distribution of any product. · Information in this document supersedes and replaces all information previously supplied. · Products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an SEMITEL product can reasonably be expected to result in personal injury, death or severe property or environmental damage. SEMITEL accepts no liability for inclusion and/or use of SEMITEL products in such equipment or applications and therefore such inclusion and/or use are at the customer’s own risk. · This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. · Resale of SEMITEL products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by SEMITEL for the SEMITEL product or service described herein and shall not create or extend in any manner whatsoever, any liability of SEMITEL. · SEMITEL expressly disclaims all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of merchantability or fitness for a particular purpose. SEMITEL only obligations are those in the SEMITEL Standard Terms and Conditions of Sale and in no case will SEMITEL be liable for any incidental, indirect, or consequential damages arising from the sale, resale, use, or misuse of its products. Specifications are subject to change without notice © Copyright 2005, Semitel Electronics . ® is a registered trademark of Semitel Electronics All rights reserved 5 Doc.No.SSME/JS-100-0041 @copyright Semitel 2011 www.semiteltech.com
ESDPSA0402V05 价格&库存
很抱歉,暂时无法提供与“ESDPSA0402V05”相匹配的价格&库存,您可以联系我们找货
