ASK3001
ASK3001
    TINYCIRCUITS
    TINY CIRCUITS - ASK3001 - Tiny Arcade - Retro Tiny Playable Game Cabinet
ASK3001 数据手册
12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US Home / Learn / Tiny Arcade Assembly Instructions TINY ARCADE ASSEMBLY INSTRUCTIONS by TinyCircuits Staff        C Search Learn... R E C E N T A RT I C L E S September 18, 2016 Tiny Screen Video(TSV) Converte Install for macOS December 19, 2018 Tiny Video Player Tutorial December 19, 2018 TinyZero Accelerometer BMA250 Internet of Things Project with Cayenne November 21, 2018 TinyZero Setup Tutorial November 21, 2018 Using the TinyZero Acceleromete November 21, 2018 SRAM TinyShield Tutorial July 02, 2018 Servo Controller TinyShield Tutor June 26, 2018 Battery Voltage Reading Using th TinyScreen+ June 15, 2018 Port Trouble: Windows and Mac H June 06, 2018 WiFi Connection via TinyDuino an WiFi TinyShield June 05, 2018 OVERVIEW: The following video is a step by step guide to assembling your Tiny Arcade. The full written instructions are posted below. Have fun! Note: These instructions are for Tiny Arcades shipped after Sept 1st, 2016. If your Tiny Arcade kit doesn't look like this, try the instructions for the Kickstarter version of the Tiny Arcade here. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 1/41 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits Tiny Arcade DIY Kit Assembly Instructions SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       PARTS: INSTRUCTIONS https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 2/41 C 12/24/2018 Tiny Arcade Assembly - TinyCircuits Putting together your Tiny Arcade kit is very simple and takes about 10 - 15 minutes. The onlyInstructions tools you will need are a flat head screwdriver and some tape (such as scotch tape), which is used to hold the acrylic case together during assembly. SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US STEP ONE:       First we want to assemble the electronics to make sure everything is working. Take the Battery and plug it into the connector marked BATT on the Processor board. Note: The speaker and the battery connector are the same size, so it is possible to plug this into the incorrect position. This will not damage anything, it just won't allow the unit to work. STEP TWO: Take Speaker and plug it into connector marked SPKR on the Processor Board. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 3/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP THREE: Take the Screen Board, remove the protective covering over the screen, and plug it into the grey connector on the Processor Board, such that the glass side of the board is facing the joystick. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 4/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP FOUR: Turn on the Tiny Arcade by flipping the switch on the back side of the Processor Board, make sure that the joystick works, the two buttons work, and the speaker is putting out sound. If not, try to move the volume knob all the way one way, then the other way to see if the sound comes on. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 5/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP FIVE: Take the acrylic sheet of arcade cabinet pieces and snap the various pieces apart, these break apart very easily. Try to knock off any of the little hanging pieces that are attached to the acrylic, you can use your fingers, or a small knife (like an X-acto knife) to break these off. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 6/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions       7/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP SIX: Peel off the protective covering on all of the acrylic pieces. You can do this using your fingernail, or you can use some tweezers or a knife tip. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 8/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP SEVEN: Take one of the side acrylic pieces (either 6 or 9, it doesn't matter which since they are both the same), and put a nylon screw through the hole in the lower middle of this piece, and thread it into the nylon spacer. Hand tighten the screw to the spacer. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 9/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions       10/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions       11/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP EIGHT: Take the piece of foam double sided tape, and remove one side of the protective covering. Note: If you do not have any tape in your Kit, or do not want to use it, jump to step Eight A for an alternative way to place the battery. Place the tape is the center of acrylic piece 3. Then remove the other protective piece from the tape, and attach it to the battery. You should attach it to the battery side that has the writing on it. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 12/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions       13/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP EIGHT A: If no foam tape is included in your kit, or you do not want to use it, the battery can be placed between the speaker and the main processor board. Do this after you put the speaker into place in step seventeen. See the below picture for where the battery will be placed. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 14/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP NINE: Take the electronics assembly, and make a small gap between the Screen Board and the Processor Board, this will let you put the electronics into the acrylic easier. Make sure that the speaker is positioned below the processor board, and the wires go through a small channel in the board. The battery should be positioned above the processor board. Align the board tabs to the side acrylic piece (the one with the screw that you put in during step 7) and push the electronic boards into the side acrylic such that the board tabs fit nicely in the slots. You will likely have to wiggle this a bit to get it into place. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 15/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions       16/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP TEN: Using some tape (Scotch tape works well for this), attach piece 3 (this is the part with the battery already taped to it) to the side piece. Piece 3 should slide into the holes that are in the side piece, and use the tape to wrap around the side of the acrylic to help hold it in place. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 17/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions       18/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP ELEVEN: Apply tape to acrylic piece 5 and place it into the very top of the arcade cabinet and slide it into the slots on the side piece. Wrap the tape around so it attaches to Piece 3 (the piece with the battery on it). Add another piece of tape from piece 5 to the side piece to help hold it in place. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 19/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions       20/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP TWELVE: Apply tape to acrylic piece 8 and place it into the very top front of the arcade cabinet and slide it into the slot on the side piece. Wrap the tape around so it attaches to Piece 5 (the top piece). https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 21/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions       22/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP THIRTEEN: Take piece 10 which has holes in it for the joystick and buttons. Rotate this the correct way so it lines up with the joystick and buttons, and slide it over the joystick and buttons. Move the Processor board out a slight bit so you can get piece 10 to slide into the side piece, then once in place, make sure the Processor board is back in the slots on the side. Note: Tape isn't needed for this part, but it's not a problem if you add some to hold it. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 23/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions       24/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP FOURTEEN: Take piece 7 and place it over where the screen is. The cutout in this piece is not centered so it does matter which way it fits in. The hole will be more aligned to the top of the cabinet, the bottom side has more material and should go towards the joystick. Note: Tape isn't needed for this part, but it's not a problem if you add some to hold it. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 25/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP FIFTEEN: Apply tape to acrylic piece 4 and place it into the very bottom of the arcade cabinet and slide it into the slots on the side piece. Wrap the tape around so it attaches to the side piece. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 26/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP SIXTEEN: Apply tape to piece 11, such that it wraps over notch in the part. Place this part at the bottom front of the arcade cabinet, and wrap the tape around to attach this to piece 4 (the very bottom piece). https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 27/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions       28/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions       29/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP SEVENTEEN: Take the speaker and place it at the bottom of the arcade cabinet, the sides of the speaker should fit nicely through the notch on the side piece and on piece 11. Make sure the wires of the speaker are clear of the holes, we don't want to pinch these wires when we tighten the cabinet together. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 30/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions       31/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP EIGHTEEN: Apply tape to piece 1, such that it wraps over notch in the piece. Place this piece at the bottom back of the arcade cabinet, and wrap the tape around to attach this to piece 4 (the very bottom piece). https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 32/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions       33/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP NINETEEN: Apply tape to piece 2, and place it in the front of the arcade under the joystick, and wrap the tape around to piece 10. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 34/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP TWENTY: Take the other side piece (either piece 6 or 9) and start to place it over the other arcade pieces and try to get the pieces to start fitting into the holes. You will likely have to wiggle this piece a lot, and move around to all of the acrylic pieces to get them to fit in the holes. When all the pieces are in, take the second nylon screw, and put it through the hole in the side piece and screw this into the nylon standoff. Use a screwdriver to tighten this slightly, so the arcade will hold together. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 35/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions       36/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions       37/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       STEP TWENTY ONE: Remove all of the pieces of tape that you used to temporarily hold the arcade together. GAME PLAY In order to play games on your Tiny Arcade, simply flip the switch on the back of the cabinet to the ON position and use the joystick and buttons to select your game. The Tiny Arcade comes with three preloaded games installed. https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 38/41 C 12/24/2018 Tiny Arcade Assembly Instructions - TinyCircuits SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       MICROSD CARD EXPANSION There is a microSD card slot in the back of the unit, you can insert a microSD card loaded with Tiny Arcade games or videos into this slot to add more games to your Tiny Arcade. You can find games on the main Tiny Arcade page here. USB CHARGING & PROGRAMMING https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 39/41 C 12/24/2018 Tiny is Arcade Assembly - TinyCircuits The Tiny Arcade will recharge the Lithium Polymer battery when the USB plugged in, this isInstructions a standard Micro USB B type connector. The Tiny Arcade can also be directly programmed as an Arduino type device, the processor board in the Tiny Arcade DISTRIBUTORS FORUM ABOUT US programs the same way as the TinyCircuits TinyScreen+, so ifSHOP you are BLOG interestedLEARN in programming this, follow these instructions.       Note: The Tiny Arcade comes preprogrammed, so there is no need to program this just to play games, just turn it on and start playing! T I N Y C I R C U I T S S TA F F Author A L SO IN L E A RN TINY SCREEN VIDEO(TSV) C O N V E R T E R I N S TA L L F O R TINYZERO ACCELEROMETER MACOS by Laverena Wienclaw BMA250 INTERNET OF December 19, 2018 T I N Y V I D E O P L AY E R In this tutorial we'll talk about how you can get a Windows application running TUTORIAL by Laverena Wienclaw C AY E N N E by Laverena Wienclaw November 21, 2018 December 19, 2018 on your Mac (for free) using Wine... View full article → THINGS PROJECT WITH This tutorial will show you how to upload videos to your Tiny Video Player Kit. You can take this project... View full article → https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions In this tutorial, we will use Cayenne to capture some accelerometer readings on their nice Internet of Things dashboard View full article → 40/41 C 12/24/2018 C O M PA N Y Tiny Arcade Assembly Instructions - TinyCircuits HELP ABOUT TINYCIRCUITS N E W S & U P D AT E S SHOP BLOG LEARN DISTRIBUTORS FORUM ABOUT US       C About TinyCircuits Customer Service TinyCircuits is a Maker of Tiny Open Source Sign up to get the latest on sales, ne Contact Us Terms & Conditions Electronics that are easy to use and let you releases and more … Distributors create miniature electronic projects. Privacy Policy  Enter your email address... SIGN UP © 2018 TinyCircuits. Powered by Shopify https://tinycircuits.com/blogs/learn/tiny-arcade-assembly-instructions 41/41
ASK3001 价格&库存
很抱歉,暂时无法提供与“ASK3001”相匹配的价格&库存,您可以联系我们找货
