HAT-MAKER
HAT-MAKER
    CYTRON
    CYTRON - HAT-MAKER - Education Kit, HAT-MAKER, FT231X, Raspberry Pi 3B/3B+/Zero/W/WH
HAT-MAKER 数据手册
Maker pHAT HAT-MAKER User’s Manual Rev 1.10 Feb 2019 Information contained in this publication regarding device applications and the like is intended through suggestion only and may be superseded by updates. It is your responsibility to ensure that your application meets with your specifications. No representation or warranty is given and no liability is assumed by Cytron Technologies Incorporated with respect to the accuracy or use of such information or infringement of patents or other intellectual property rights arising from such use or otherwise. Use of Cytron Technologies’s products as critical components in life support system is not authorized except with express written approval by Cytron Technologies. No licenses are conveyed, implicitly or otherwise, under any intellectual property rights. ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER INDEX PAGES 1. INTRODUCTION 2 2. PACKING LIST 3 3. PRODUCT SPECIFICATIONS 4 4. BOARD LAYOUT 5 5. HARDWARE INSTALLATION 6 6. GETTING STARTED 8 7. HIGHLIGHTED FEATURES 20 8. PYTHON DEMO CODE 21 9. SCHEMATIC 24 10. GALLERY 25 11. WARRANTY 27 Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 1 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER 1. INTRODUCTION What is HAT? HAT means Hardware Attached on Top. If Arduino have Shield, Raspberry Pi (refer to Raspberry Pi B+/2/3/3B+) uses HAT. But with the smaller board, Raspberry Pi Zero/W/WH is introduced, pHAT (partially Hardware Attached on Top) emerged too. Shield and HAT/pHAT have the same objective - to ease the hardware development. Raspberry Pi aims to bring the power of computing and digital making to the masses. It is being used by many educators, makers, and also engineers. I am sure you will have similar constraints when get started from scratch, example: ● Lack of on board USB to UART communication for your computer to get the ip address for SSH (headless), or to kick start configuration directly. ● There is no GPIO status indicator when you write program to control particular pin. ● Access to GPIO is kind of difficult because there is no label, you need to search online to get the designated pin. ● And there is no extra programmable push button for proper shutdown (hardware) :( We would like to introduce Maker pHAT. It is designed to ease everyone in getting started with Raspberry Pi in the absence of additional monitor, keyboard or mouse (Headless); and also prototyping. It helps user to remote access Raspberry Pi through serial with minimum steps. The on board LEDs, push buttons and buzzer will further assist beginner in interfacing with sensors, actuator and coding. “Maker pHAT is designed for anyone who want to get start with any Raspberry Pi projects” Maker pHAT comes with the following features: ● ● ● ● ● ● ● ● ● ● ● Raspberry Pi Zero Size, stack perfectly on to Pi Zero Series of SBC (Single Board Computer). Compatible with standard Raspberry Pi 3B/3B+ and small size Raspberry Pi Zero/W/WH. Standard Raspberry Pi GPIO footprint. LED array for selected GPIO pins (GPIO 17, 18, 27, 22, 25, 12, 13, 19). 3x on board programmable push buttons (GPIO 21, 19 and 20, need to configure as input pull up). On board active buzzer (GPIO 26). Proper label for all GPIOs, including SPI, UART, I2C, 5V, 3.3V, and GND. Utilize USB Micro-B socket for 5V input and USB to UART communication. USB serial facilitated by the CH340. Input voltage: USB 5V, from computer, power bank or standard USB adapter. PURPLE PCB! Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 2 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER 2. PACKING LIST Please check the parts and components according to the packing list. If there are any parts missing, please contact us at sales@cytron.io immediately. No ITEMS QUANTITY 1 Maker pHAT (Code: HAT-MAKER) 1 2 2x20 Stacking Header (Code: CN-PH-PC104) 1 Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 3 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER 3. PRODUCT SPECIFICATIONS Dimension: Absolute Maximum Rating of Maker pHAT: No PARAMETERS 1 Input Voltage via USB connector 2 DC Current for 5V Pin (Max Continuous) Min Typ Max Unit 4.8 – 5.2 V – – USB mA Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 4 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER 4. BOARD LAYOUT LABEL FUNCTION A RASPBERRY PI STANDARD 40 HEADER PIN B BREAKOUT POWER PIN C BREAKOUT I2C PIN D BREAKOUT UART PIN E BREAKOUT GPIO PIN F Stack this pHAT to Raspberry Pi through this standard 40 header pin. User can access 5V, 3.3V and GND through power pins. User can access SDA (GPIO 2) and SCL (GPIO 3) through I2C pins. User can access TX (GPIO 14) and RX (GPIO 15) through UART pins. User can access GPIO 17, 18, 27, 22, 25, 12, 13, 19 through GPIO pins. BREAKOUT SPI PIN User can access MOSI (GPIO 10), MISO (GPIO 9), SCK (GPIO 11), CE0 (GPIO 8) and CE1 (GPIO 7) through SPI pins. G GPIO INDICATOR LED H USB MICRO B CONNECTOR I USB-SERIAL INDICATOR LED J USB-SERIAL IC CONVERTER (FT231X) K L Selected GPIO is equipped with LED, where it can controlled or act as indicator for input. Supply (alternative) to Raspberry Pi and to remote through SSH serial. Indicates USB-Serial activity. Converts USB data to serial data. Used to remote Raspberry Pi using SSH serial. ACTIVE BUZZER Active buzzer is connected to GPIO 26. Signal HIGH will activate the buzzer and signal LOW will turn off the buzzer. PROGRAMMABLE PUSH BUTTONS 3 programmable push button is connected to GPIO 21, 16 and 20. To use it, user need to configure it as input pull up. Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 5 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER 5. HARDWARE INSTALLATION 5.1 Raspberry Pi Zero WH Maker pHAT is designed to fit in Raspberry Pi Zero footprint, means it can fit on Raspberry Pi Zero W and Raspberry Pi Zero WH. It can stack to Raspberry Pi Zero WH directly without any extra components. 5.2 Raspberry Pi 3 Model B and Model B Plus Maker pHAT has standard Raspberry Pi GPIO footprint. So, it is compatible with Raspberry Pi 3 Model B or Model B Plus too. You need PC104 Header Pin (2x20) in order to stack Maker pHAT on Raspberry Pi. Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 6 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER 5.3 Access Breakout Pads on Maker pHAT Maker pHAT Rev1.10 comes with pre-soldered SMD header pin on the breakout pads. No worry about short circuit when you stack the Maker pHAT Rev1.10 on the Raspberry Pi Zero WH. Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 7 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER 6. GETTING STARTED 6.1 Preparing Hardware To get started, we recommend you to have: 1. Maker pHAT 2. Raspberry Pi Zero WH 3. 16GB Micro SD Card 4. USB Micro B Cable 6.2 Install the latest Raspbian OS Note: The latest NOOBS (V2.9.0) already comes with Raspbian pre-installed. If you get 16GB Micro SD Card with NOOBS for RPI, you don't need to write Raspbian image. Download the latest Raspbian OS (Raspbian Stretch with Desktop) and write the image on the SD card using Etcher. Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 8 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER After done flashing, take the SD card out and insert back to your laptop. Open SD card directory (e.g. D:/boot) and open config.txt file. Put enable_uart=1 at the bottom of the line. Save and eject the SD card. Then insert the SD card into Raspberry Pi Zero WH. 6.3 Install Maker pHAT Driver Don’t stack the Maker pHAT to Raspberry Pi Zero WH yet. Connect Maker pHAT to your laptop using USB Micro B Cable. Check either your laptop is able to detect the Maker pHAT. Open Device Manager, and check under Ports (COM & LPT) category. It should be detected as USB Serial Port (COM number). If yes, you can proceed to the next step. If not, download and install Maker pHAT driver. Download and install Maker pHAT driver. Please choose appropriate driver depends on your laptop/PC operating system: ● Windows 10 ● MacOS Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 9 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER Once detected, disconnect the USB cable. Stack Maker pHAT on the top of Raspberry Pi Zero WH. 6.4 Install PuTTY (Windows) For Windows user, download and install PuTTY. Connect your Maker pHAT to your laptop using USB Micro B Cable. Since Maker pHAT is already stacked on the Raspberry Pi, this connection will power up Raspberry Pi through Maker pHAT. Please be reminded to not simply disconnect the cable without proper shutdown, it might corrupt the microSD card. Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 10 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER Open PuTTY software. Tick on the Serial, then write your COM number (e.g. COM3). Please refer to your Device Manager. Set Speed to 115200. Then click Open. Press Enter, then insert Raspberry Pi default login information as follow. raspberrypi login: pi Password: raspberry You can’t see while typing the password. So far, you’re able to access Raspberry Pi through serial remote (Maker pHAT). We will further guide you until we can remote using VNC Viewer (Virtual Network Computing). Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 11 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER 6.5 Connect to WiFi To remote using VNC Viewer, we need a WiFi connection. We can set the WiFi connection in Raspberry Pi Software Configuration Tool. Write the following command and Enter. pi@raspberrypi:~$ sudo raspi-config To enter Raspberry Pi Configuration Tool. Go to number 2 Network Options. Then Enter. Choose N2 Wi-fi and Enter. Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 12 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER Choose your country and press Enter. Confirm your WiFi country by pressing Enter. Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 13 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER Write your WiFi SSID (WiFi name) then Enter, followed by WiFi passphrase (WiFi password) then Enter. Done setting for WiFi connection. Press Enter to . Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 14 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER Next, we need to enable VNC server in Raspberry Pi. Go back to the top menu, and select to the number 5 Interfacing Options. Select P3 VNC and Enter. Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 15 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER Choose and Enter. VNC server is enabled. Press Enter to . Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 16 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER Press Esc to exit Raspberry Pi Configuration Tool. Now, reboot Raspberry Pi to enable WiFi connection and VNC server. Write following command followed by Enter. pi@raspberrypi:~$ sudo reboot Restart Raspberry Pi. Login to Raspberry Pi like previous. If all your setting is correct, your Pi will connect to WiFi. Next we need to trace the IP address. Write following command and Enter. pi@raspberrypi:~$ ifconfig Check Raspberry Pi IP address. Your Raspberry Pi will display IP address (e.g. 192.168.0.106). Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 17 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER We recommend you to update your Raspbian with following command. pi@raspberrypi:~$ sudo apt-get update Update Raspbian OS. Done update, open VNC Viewer and insert Raspberry Pi’s IP address on the text bar. Then press Enter. Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 18 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER A warning window will popup. Sometimes the warning is in yellow and sometimes in red. Proceed with Continue button. Fill up Raspberry Pi default login information. Username: pi Password: raspberry Press OK. Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 19 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER Tadaa. Your VNC remote is successful. Now you can access Raspberry Pi Desktop through VNC Viewer and WiFi connection. Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 20 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER 7. HIGHLIGHTED FEATURES Maker pHAT incorporates 4 interesting features which make it interesting and more suitable for beginner. Below are the detailed descriptions for each feature. 7.1 LEDs at Selected GPIO Pins 8 LEDs is connected to GPIO 17, 18, 27, 22, 25, 12, 13 and 19. Those LED can be controlled as an output or can be act as an input (signal monitoring). In other words, GPIO that connected to the LED, can be configured as output, input and input pull up. 7.2 Programmable Push Buttons 3 units of programmable push button are included in the Maker pHAT. To utilize it, user need to configure push button GPIO as input pullup. ● SW1 is connected to GPIO 21 ● SW2 is connected to GPIO 16 ● SW3 is connected to GPIO 20 7.3 On-board Active Buzzer Maker pHAT also comes with on-board active buzzer. It is standard output digital device connected to GPIO 26. To activate it, set GPIO to high, and to mute it, just set GPIO to low. 7.4 USB to Serial for Serial Remote Serial remote is a helpful tool to get started with Raspberry Pi. Luckily, Maker pHAT comes with USB to Serial module for this purpose. It is connected to Raspberry Pi’s UART pin (RX and TX). Please refer to Getting Started section for more detail. Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 21 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER 8. PYTHON DEMO CODE User can try this python demo code to control the LEDs and buzzer using push button on Maker pHAT. Click on Menu - Programming - Python 3 (IDLE). Then click File - New File. Write (or copy and paste) the following python code (gist). MakerpHATDemo.py - /home/pi/Documents/MakerpHATDemo.py (3.5.3) File Edit Format Run Options Window Help from gpiozero import LED, Button, Buzzer from time import sleep import os LED1 LED2 LED3 LED4 LED5 LED6 LED7 LED8 = = = = = = = = LED(17) LED(18) LED(27) LED(22) LED(25) LED(12) LED(13) LED(19) SW1 = Button(21) SW2 = Button(16) SW3 = Button(20) BUZZER = Buzzer(26) NONE = 0 DECREASE = 1 INCREASE = 2 ALL_OFF = 9 ALL_ON = 10 def beep(times, sec): for x in range(times): BUZZER.on() sleep(sec) BUZZER.off() sleep(sec) def led(ledNumber): if ledNumber == 1: LED1.on() else: LED1.off() if ledNumber == 2: LED2.on() else: LED2.off() if ledNumber == 3: LED3.on() else: LED3.off() Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 22 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER if ledNumber == 4: LED4.on() else: LED4.off() if ledNumber == 5: LED5.on() else: LED5.off() if ledNumber == 6: LED6.on() else: LED6.off() if ledNumber == 7: LED7.on() else: LED7.off() if ledNumber == 8: LED8.on() else: LED8.off() if ledNumber == ALL_OFF: LED1.off() LED2.off() LED3.off() LED4.off() LED5.off() LED6.off() LED7.off() LED8.off() elif ledNumber == ALL_ON: LED1.on() LED2.on() LED3.on() LED4.on() LED5.on() LED6.on() LED7.on() LED8.on() mode = NONE ledPosition = 0 led(ALL_ON) beep(1, 0.1) led(ALL_OFF) try: while True: if SW1.is_pressed and mode != DECREASE: beep(2, 0.07) mode = DECREASE Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 23 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER elif SW2.is_pressed and SW3.is_pressed: sleep(0.5) for loop in range(times): BUZZER.on() led(ALL_ON) sleep(0.2) BUZZER.off() led(ALL_OFF) sleep(0.2) sleep(0.5) os.system(“sudo shutdown -h now”) elif SW2.is_pressed and mode != INCREASE: beep(2, 0.07) mode = INCREASE elif SW3.is_pressed and mode != NONE: beep(1, 0.07) mode = NONE if mode == INCREASE: if ledPosition < 8: ledPosition = ledPosition + 1 else: ledPosition = 0 elif mode == DECREASE: if ledPosition > 0: ledPosition = ledPosition - 1 else: ledPosition = 8 led(ledPosition) sleep(0.05) except KeyboardInterrupt: led(ALL_OFF) Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 24 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER To run it, click Run - Run Module (or can press F5). You need to save your python code first. You can save your code in Documents folder. Write MakerpHATDemo.py and save. Python Shell window will popup. Wait until you hear a beep from Maker pHAT. Now you can control the LED by pressing the push buttons. ● SW1: Buzzer will produce double beep. LED will running from right (GPIO 19) to left (GPIO17). ● SW2: Buzzer will produce double beep. LED will running from left (GPIO 17) to right (GPIO19). ● SW3: Buzzer will produce single beep. LED stop running. ● Hold SW2 and SW3: Raspberry Pi shutdown. Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 25 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER 9. SCHEMATIC Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 26 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER 10. GALLERY Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 27 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 28 ROBOT.HEAD to TOE Product User’s Manual - HAT-MAKER 11. WARRANTY ● ● ● ● Product warranty is valid for 1 year. Warranty only applies to manufacturing defect. Damaged caused by misuse is not covered under warranty. Warranty does not cover freight cost for both ways. Prepared by: Cytron Technologies Sdn Bhd www.cytron.io No. 1, Lorong Industri Impian 1, Taman Industri Impian, 14000 Bukit Mertajam, Penang, Malaysia. Tel: Fax: +604 - 548 0668 +604 - 548 0669 Email: support@cytron.io sales@cytron.io Created by Cytron Technologies Sdn Bhd – All Rights Reserved Back to INDEX 29
HAT-MAKER 价格&库存
很抱歉,暂时无法提供与“HAT-MAKER”相匹配的价格&库存,您可以联系我们找货
