HSM6524A
HSM6524A
    ONMICRO(汉天下)
    SMD,1.1x14mm
    HSM6524A
HSM6524A 数据手册
HSM6524A WiFi Filter (2402.5 – 2481.5 MHz) Description 5 4 2 3 GND GND Function Input Output Ground S 1 nM Features te r Su 50Ω Input/Output Package for Surface Mount Technology (SMT) Miniature Size: 1.4 mm x 1.1 mm x 0.6 mm Fast roll-off from WiFi to near LTE bands High rejection at LTE bands Ni, Au-plated terminals Excellent ESD protection ability Moisture Sensitivity Level 3 un ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ Pin No. 1 4 2, 3, 5 Co OUTPUT EM INPUT GND Pin Connections nf id Functional Block Diagram en tia l HSM6524A is designed to enable concurrent operation of Wireless LAN and Bluetooth applications which coexist with other wireless standards. HSM6524A is designed with Surface Acoustic Wave (SAW) technology. Typical insertion loss in the pass band is less than 1.7 dB. Typical rejection at LTE Band 40 is more than 40 dB, at Band 7 and Band 41 is more than 30 dB. H Applications 802.11 b/g/n WLAN or Bluetooth datacom in handsets, mobile and portable communication devices. Copyright © 2015-2019 HunterSun-MEMS All Rights Reserved 1/5 HSM6524A WiFi Filter (2402.5 – 2481.5 MHz) Parameter Min Typ Max Unit *Insertion Loss (2402.5-2421.5MHz)(Ch.1) \ 1.7 2.4 l Electrical Specifications, Z0 = 50Ω, Tc = -30℃ to 85℃ *Insertion Loss (2407.5-2426.5 MHz)(Ch.2) \ 1.3 2.0 dB *Insertion Loss (2412.5-2471.5 MHz)(Ch.3-11) \ 1.1 1.6 dB en tia nf id \ 1.4 2.0 dB \ 1.7 2.5 dB 10 15 \ dB 28 30 \ dB 2000 - 2170 MHz 28 30 \ dB nM *Insertion Loss (2457.5-2476.5 MHz)(Ch.12) dB 2300 - 2370 MHz 38 40 \ dB 2500 - 2570 MHz 30 35 \ dB 2570 - 2690 MHz 30 32 \ dB 4800 - 6000 MHz 40 45 \ dB Co *Insertion Loss (2462.5-2481.5 MHz)(Ch.13) Return Loss (2402.5-2481.5 MHz) (Ch.1-13) un te r Su EM 800 - 2000 MHz S Absolute Attenuation H *Typical data is the average value over the indicated channel. Copyright © 2015-2019 HunterSun-MEMS All Rights Reserved 2/5 HSM6524A WiFi Filter (2402.5 – 2481.5 MHz) Typical Performance at Tc = 25°C EM S Co nf id en tia l Pass Band Response (S21) H un te r Su nM Pass Band Response (S11&S22) Copyright © 2015-2019 HunterSun-MEMS All Rights Reserved 3/5 HSM6524A WiFi Filter (2402.5 – 2481.5 MHz) S Co nf id en tia l Rejection Band Response (Rejection@B40、B7&B41) H un te r Su nM EM Wide Band Response Copyright © 2015-2019 HunterSun-MEMS All Rights Reserved 4/5 HSM6524A WiFi Filter (2402.5 – 2481.5 MHz) Package Outline Drawing 1.4 (1.48 MAX) (2) + TX/RX (1) (1) 1.1 (1.18 MAX) 0.288 + 0.575 nf id GND (5) + (5) TOP VIEW Co 0.325 S 1. Dimensions in millimeters 2. Tolerance: X.XX ± 0.05 X.XXX ± 0.025 3. Dimensions nominal unless otherwise noted 4. Contact areas gold plated (4) 0.100 0.075 BOTTOM VIEW SIDE VIEW Notes: (3) + + ANT (4) l 0.500 GND (2) en tia GND (3) 0.500 0.6 (0.80 MAX) PIN 1 MARK Pin Connections 1 Port 1 (TX/RX) 2, 3, 5 GND 4 Port 2 (ANT) EM 0.250 PAD DETAIL nM Test Circuit 1 2 3 H un te r 50Ω input 4 Su 5 50Ω output Copyright © 2015-2019 HunterSun-MEMS All Rights Reserved 5/5
HSM6524A 价格&库存
很抱歉,暂时无法提供与“HSM6524A”相匹配的价格&库存,您可以联系我们找货
